Steppers wont move Mini Rambo
put every thin together and cannot get steppers to move , tried to re flash firmware ant would not upload
i get no movement nor any noise
Repitier host gives error // communication timeout - reset send buffer block
Arduino: 1.8.12 (Windows 10), Board: “RAMBo”
Sketch uses 103384 bytes (40%) of program storage space. Maximum is 258048 bytes.
Global variables use 4638 bytes of dynamic memory.
An error occurred while uploading the sketch
avrdude: ser_open(): can’t open device “\.\COM6”: Access is denied.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
COM6”: Access is denied. Your computer cannot communicate with the Rambo. Is com 6 the correct port? - check in windows devices/settings, look for your Rambo board and check which com port it is on. If that is correct have you got another application accessing that com port - prontaface perhaps?
also make sure repetier server isn’t installed.
And that repetier host isnt connected when trying to flash.
tried to flash again made sure repiter host ans server were off and not connected got same error
when i plug in the board port show that it is connected to port 6
You’re not using the windows store arduino app are you?
No it is not the Windows 10 app
Ok I remover repiter server and tried to flash again now in getting this error
Bootloader file specified but missing:
where do i find this
Pretty sure you can ignore that one.
Thanks All for the input
I uninstalled the repitier server and re booted computer i was able to get the sketch verified and ignored the error message about the boot-loader
uploaded successful and steppers now move
once again thanks
Jeff
