Sloppy Z axis (Gantry) on 2nd hand unit
Ok to begin thanks to those that helped me previous with this on a real bad transport… I have been learning the CNC and found that the motor mount has slop when milling because the all the bearings are not in contact with the 3/4 in conduit 100% of the time and I am getting lateral movement because of this. Is this normal? Is there a way to adjust the position of the roller bearings or do I need to have the parts reprinted? If I need them reprinted which part names do I need? I am going to extend the size a little an now is the time to do it anyways.
any ideas would be appreciated.
Read through here for ideas. https://www.v1engineering.com/assembly/middle/
Some pictures of which bearings are loose would help.
pics showing actual slop are not ease , but attached… The bearing I am having issues with are the ones aon the XY part (red part in the link you gave) and I only have about 1/8" but it is enough that it is causing me to brake bits (.75mm endmill)
