I currently have a Burley with a Full RAMBo controller and I have a few questions for myself and for a friend that is looking into building a MPCNC to be used with a diode laser.
Will the my existing Burley (with auto homing) work with the newer SKM controller ?, I am thinking it will be ok
Will the SKM controller work with Lightburn software for laser use or is there updates that will be needed to be able to have Lightburn run the laser ?
Does the SKM require any updates to be able to use it with a NEJE diode laser ?
Is the full RAMBo still a board that is obtainable or is it obsolete ?, don’t see an option for it
I have read in a previous post the differences from the RAMBo to the SKM was thinking of updating to the SKM due to using the laser 99% of the time, but not sure if it’s worth it.
The skr pro v1.2 has the laser enabled (IIRC). It will work with the burly.
The rambo is a good board, but lasers require a lot of gcode parsing to do grayscale laser engraving. So the 8bit micro doesn’t do as well as the 32bit skr pro.
To the best of my knowledge, there is zero reason why you cannot use a new controller with your Burly. The Primo still has the same 5 motors, and if you are already using dual endstops, you don’t need to make any workflow changes.
I believe that the RAMBo board is supply limited, they haven’t been in the shop for quite some time. The SKR Pro is a good board, and has everything for a diode laser in the firmware already. It will work with the touchscreen, or can still use the 12864 LCD like the RAMBo.
The Jackpot controller is a little different for workflow, it’s FluidNC, rather than Marlin firmware, and headless control is via wifi rather than LCD, so you can use a phone or tablet. The Gcode is slightly different, but the machine works the same way.
The Jackpot is probably a better option, lower cost and aimed straight at what we need, but the SKR is also a solid decision. The SKR has the advantage of an LCD controller which the Javkpot still lacks.
Any idea if the SKR will work with the Lightburn laser program as the RAMBo already does ?
This would be my main concern as all my laser work is done with Lightburn
The SKR will work with Lightburn. But I believe the Jackpot works better/faster according to Ryan. When I switched my Primo over to be a dedicated laser machine I also switched it from the SKR to Jackpot board. Its been running great!
If I was to use the Jackpot can an external LCD interface (in the case of the SKR or my older RAMBo) be used ?
Or is the Jackpot strictly USB or WiFi ?
Asking this because I the case I had to go back to using my router and the EstlCAM software.
Ok, I did some searching and found that the Jackpot does not have the ability for an external LCD controller.
How does the Lightburn on the PC interface with the Jackpot ?
Can Estlcam interface via wifi or usb ?
I run lightburn over USB but it can also run it over Wifi. If using WiFi best to save the gcode to the SD card and then run the gcode from the FluidNC Web UI. that’s also the way you run normal router stuff. Use Estlcam to create the gcode and save to SD card then run the file from the sd card on the webui
The Jackpot is still new to me as well. So far the only thing I have used it on is the laser but will be running my first CNC job on the lowrider today with it as well. I think it will run just fine. I always used the attached LCD screen so its a little getting used to but not bad so far.
I’m using the NEJE A40640 laser. It has its own 12v power supply and I run a 24v power supply to the jackpot. Now that I am running the jackpot over usb from lightburn I don’t run the fluid. Mine is set up as a dedicated laser so it might be different from how you need to run it.
I will be running my A40640 the exact same as you just on my burley with Lightburn.
I thought that if the USB cable was used that would eliminate the need for the FluidNC software.
AWESOM and thank you so much
Going to pull the trigger on the Jackpot controller now
FluidNC is the firmware running on the board (rather than Marlin as the SKR board runs). It includes a web interface you can use to control the board and start jobs. This is the only way currently to interact with it.
