I have a SKR 1.4 Turbo. I am running the firmware [Firmware 2.0.9.2]
My endstops don’t work at all. No matter what I do M119 reports
Send: M119
Recv: Reporting endstop status
Recv: x_min: open
Recv: x2_min: open
Recv: y_min: open
Recv: y2_min: open
Recv: z_min: TRIGGERED
Recv: ok
I have tried putting like suggested in this https://forum.v1e.com/t/mpcnc-duel-end-stops-always-triggered/30571/4
No matter M119 reports no change.
I also ran M43 and nothing would change either
Send: M43 I Recv: PIN: P0_00 <unused/unknown> Input = 1 Recv: PIN: P0_01 <unused/unknown> Input = 1 Recv: PIN: P0_02_A7 TXD0 Input = 1 Recv: PIN: P0_03_A6 RXD0 Input = 1 Recv: PIN: P0_04 <unused/unknown> Input = 1 Recv: PIN: P0_05 <unused/unknown> Input = 1 Recv: PIN: P0_06 <unused/unknown> Output = 1 Recv: PIN: P0_07 <unused/unknown> Input = 0 Recv: PIN: P0_08 <unused/unknown> Input = 1 Recv: PIN: P0_09 <unused/unknown> Input = 1 Recv: PIN: P0_10 <unused/unknown> Input = 1 Recv: PIN: P0_11 E0_DIR_PIN Output = 0 Recv: . X2_DIR_PIN Output = 0 Recv: PIN: P0_15 DOGLCD_SCK Input = 0 Recv: PIN: P0_16 LCD_SDSS Output = 1 Recv: . SDSS Output = 1 Recv: PIN: P0_17 <unused/unknown> Input = 1 Recv: PIN: P0_18 DOGLCD_MOSI Output = 1 Recv: PIN: P0_19 Y_STEP_PIN Output = 1 Recv: PIN: P0_20 Y_DIR_PIN Output = 1 Recv: PIN: P0_21 Z_ENABLE_PIN Output = 1 Recv: PIN: P0_22 Z_STEP_PIN Output = 1 Recv: PIN: P0_23_A0 TEMP_1_PIN Analog in = 0 Recv: PIN: P0_24_A1 TEMP_0_PIN Analog in = 1023 Recv: PIN: P0_25_A2 TEMP_BED_PIN Analog in = 1023 Recv: PIN: P0_26_A3 <unused/unknown> Analog in = 842 Input = 0 Recv: PIN: P0_27 <unused/unknown> Input = 1 Recv: PIN: P0_28 BTN_ENC Input = 1 Recv: PIN: P0_29 <unused/unknown> Input = 1 Recv: PIN: P0_30 <unused/unknown> Input = 0 Recv: PIN: P1_00 POWER_LOSS_PIN Input = 1 Recv: PIN: P1_01 E1_CS_PIN Input = 1 Recv: . Y2_SERIAL_TX_PIN Input = 1 Recv: . Y2_SERIAL_RX_PIN Input = 1 Recv: . E1_SERIAL_TX_PIN Input = 1 Recv: . E1_SERIAL_RX_PIN Input = 1 Recv: PIN: P1_04 E0_CS_PIN Input = 1 Recv: . X2_SERIAL_TX_PIN Input = 1 Recv: . X2_SERIAL_RX_PIN Input = 1 Recv: . E0_SERIAL_TX_PIN Input = 1 Recv: . E0_SERIAL_RX_PIN Input = 1 Recv: PIN: P1_08 Z_SERIAL_TX_PIN Input = 1 Recv: . Z_SERIAL_RX_PIN Input = 1 Recv: PIN: P1_09 Y_SERIAL_TX_PIN Input = 1 Recv: . Y_SERIAL_RX_PIN Input = 1 Recv: PIN: P1_10 X_SERIAL_TX_PIN Input = 1 Recv: . X_SERIAL_RX_PIN Input = 1 Recv: PIN: P1_14 E1_DIR_PIN Input = 0 Recv: . Y2_DIR_PIN Input = 0 Recv: PIN: P1_15 E1_STEP_PIN Input = 1 Recv: . Y2_STEP_PIN Input = 1 Recv: PIN: P1_16 E1_ENABLE_PIN Output = 1 Recv: . Y2_ENABLE_PIN Output = 1 Recv: PIN: P1_17 <unused/unknown> Input = 1 Recv: PIN: P1_18 LCD_PINS_ENABLE Output = 0 Recv: PIN: P1_19 LCD_PINS_RS Output = 0 Recv: PIN: P1_20 LCD_PINS_D4 Output = 0 Recv: PIN: P1_21 LCD_PINS_D5 Output = 1 Recv: PIN: P1_22 LCD_PINS_D6 Input = 1 Recv: PIN: P1_23 BTN_ENC_EN Input = 1 Recv: . LCD_PINS_D7 Input = 1 Recv: PIN: P1_24 NEOPIXEL_PIN Input = 0 Recv: PIN: P1_25 FIL_RUNOUT2_PIN Input = 0 Recv: . Y_MAX_PIN Input = 0 Recv: . Y2_MIN_PIN Input = 0 Recv: . E1_DIAG_PIN Input = 0 Recv: PIN: P1_26 X_MAX_PIN Input = 0 Recv: . X2_MIN_PIN Input = 0 Recv: . E0_DIAG_PIN Input = 0 Recv: PIN: P1_27 Z_MIN_PIN Input = 0 Recv: . Z_DIAG_PIN Input = 0 Recv: . Z_STOP_PIN Input = 0 Recv: PIN: P1_28 Y_MIN_PIN Input = 0 Recv: . Y_DIAG_PIN Input = 0 Recv: . Y_STOP_PIN Input = 0 Recv: PIN: P1_29 X_MIN_PIN Input = 0 Recv: . X_DIAG_PIN Input = 0 Recv: . X_STOP_PIN Input = 0 Recv: PIN: P1_30_A4 BEEPER_PIN Output = 0 Recv: PIN: P1_31_A5 SD_DETECT_PIN Input = 1 Recv: PIN: P2_00 SERVO0_PIN Input = 1 Recv: PIN: P2_01 X_ENABLE_PIN Input = 1 Recv: PIN: P2_02 X_STEP_PIN Input = 1 Recv: PIN: P2_03 FAN_PIN Output = 0 Recv: PIN: P2_04 HEATER_1_PIN Input = 0 Recv: PIN: P2_05 HEATER_BED_PIN Input = 0 Recv: PIN: P2_06 X_DIR_PIN Input = 1 Recv: PIN: P2_07 HEATER_0_PIN Input = 0 Recv: PIN: P2_08 Y_ENABLE_PIN Input = 1 Recv: PIN: P2_09 <unused/unknown> Input = 0 Recv: PIN: P2_10 <unused/unknown> Input = 1 Recv: PIN: P2_11 Z_DIR_PIN Input = 1 Recv: PIN: P2_12 E0_ENABLE_PIN Input = 1 Recv: . X2_ENABLE_PIN Input = 1 Recv: PIN: P2_13 E0_STEP_PIN Input = 1 Recv: . X2_STEP_PIN Input = 1 Recv: PIN: P3_25 BTN_EN2 Input = 1 Recv: PIN: P3_26 BTN_EN1 Input = 1 Recv: PIN: P4_28 <unused/unknown> Input = 1 Recv: PIN: P4_29 <unused/unknown> Input = 1
Recv: PIN: P1_25 FIL_RUNOUT2_PIN Recv: PIN: P1_26 X_MAX_PIN Recv: PIN: P1_27 Z_MIN_PIN Recv: PIN: P1_28 Y_MIN_PIN Recv: PIN: P1_29 X_MIN_PIN
This does not appear to match up with the M43 dump, but I would still expect some sort of change.
I am just wanting to know if there is another way to test if I have managed to kill the board or if I have some sort of config issue?
Any help or suggestions is very much welcomed.
