SKR 1.4 Turbo No printer attached
My SKR 1.4 turbo still says no printer attached even though everything seems to be working properly. It’s also not showing the position when I manually move it around, x y and z all say 0.00 no matter what but it is showing in repetier host. Also my menus are missing on my TFT, is that because I need a specific MPCNC firmware on the TFT? I saw a post the other day where somebody had made one but I can’t find it now
This is the one I used a week or so ago
If it says, “no printer attached”, then don’t expect anything else to work.
The baud rate should be set, and the firmware needs to be the V1 firmware if you are using V1 firmware on the turbo.
Thank you that is the one
That makes sense, the menu data is stored to the motherboard, not the TFT. I used the V1 firmware but I made changes. Now that I know my original issues were caused by the missing pins and using sensorless I’ll go back and try it with no changes. For testing purposes will it work with no end stops installed and using G92?
I still run mine like that :slight_smile:
Word, thats what I’ll do then
