If you do use the firmware from the git repository but with the above config file I found you got a number of errors on loading the config file with “Invalid Keyword”
Once I had the right firmware and right config.ini file it all looked a lot better and didn’t beep at me as much.
I hope this helps someone else. Thank you for all the helpful info and people on this forum
Thank you Hamish, for sharing your notes! so I also used the firmware.bin from git and flashed it, for me it all working good so far also with the TFT35 V3.
hopefully the next release will contain the Marlin files for the Turbo, then i will do some edits in the firmware, so i can also use the ESP3D Wi-Fi module.
for the M221 error i didn’t encounter this yet… if i did i will come back to your post and fix it, thanks mate!
