What would be a preferred method to secure thin plywood (3mm) to the bed for cutting out parts ?
I’ve tried a vacuum system and it works ok until there is enough cults to decrease the vacuum holding the ply to the bed, then the vacuum is lost and the ply will not stay secured in place.
I then added small screws to hold the ply to the bed, this appears to be the best method so far.
The size of the wood being routeted out is 12x36 with multiple parts (model aircraft ribs) being cut out.
Double sided tape was my first thought but your stock size is a bit big unless you can put the tape where the finished parts are going to be.
You have mentioned you have vacuum, if you search the internet for pictures of Wadkin CNC Router, these had a 2" thick nylon bed that a matrix was cut into, there were tapped holes that were used to allow the vac to areas of the bed where the finished part was going to be then sponge rubber was placed in the matrix within the perimeter of the finished part (to be) when the part was cut the vac still held the part, hard to explain fully but might give you some ideas.
What I do is secure the 4 corners with screws or clamps, then have a v bit mark some spots where I know the bit won’t cut, then put screws down there. In my case, I actually just drill holes where my spoilboard holes are so I can secure with a washer.
I do the screw method on thin plywood. I use the self tapping metal screws that hav the washer type head.
I put screws in the 4 corners. Then I use my end mill to punch holes all over the plywood where I won’t be cutting. I then add more screws to all the little holes.
I like the idea of the masking tape and CA glue. I might have to give that a try in the near future.
