Sculpfun s9 laser
Hi there
I’m haveing a problem with my laser machine which is sculpfun s9
The problem is that the machine doesn’t complete any work at all and it stop working in the middle
It starts like for less than minute then stop in some point and don’t complete until I reset it then get back to the same problem but it doesn’t stop all time in same place
I am using lightburn software and i used lasergrbl and both has the same issue
It stop as in this photo and the laser still burning
I have had this problem - laser stopping in the middle of the burn. I think it might be caused by a flaky USB cable, or maybe just some strong interference near the laser. My solution on my MPCNC is to run from an SD card. I do my design, burn setup, and framing on the PC, but when I’m ready to burn, I use the Save to Gcode function in Lightburn to save the file to an SD card, and I do the actual burn from that.
I had the same issue when I received mine. Sculpfun had to send me a new board, and the problem was resolved.
