cfg
August 14, 2022, 8:49am
1
Hi Guys
Just completing my first build. Bought all parts from V1.
My screen starts showing gibberish after a few moves in the menu. Seems to be different each time it happens. See pictures below.
Also when homing z axis only 1 side homes. Both move when I independently move the z axis.
azab2c
(Aza B2C)
August 14, 2022, 1:32pm
2
Hello @cfg ,
Using a SKR Pro board? If so, is the JST shield for the TFT’s serial cable removed to help serial cable make better connection?
Triple check grub screws
jeffeb3
(Jeffeb3)
August 14, 2022, 3:16pm
3
It isn’t the black cable causing this. You can remove it. I have seen this, a while ago. I can’t remember the cause. If you are using our firmware, then it must be something w.r.t. the hardware.
Check the endstop status with M119.
cfg
August 14, 2022, 6:45pm
4
Yes using the skr pro. I removed the black plug below the black wire but now the screen just shows Marlin Mode. Nothing else.
jeffeb3
(Jeffeb3)
August 14, 2022, 7:31pm
5
Marlin mode comes over the two gray cables. The black cable is only for tft mode.
cfg
August 14, 2022, 7:44pm
6
Ok so do I unplug the black cable?
jeffeb3
(Jeffeb3)
August 14, 2022, 9:01pm
7
Did unplugging the black cable make the noise in marlin mode go away?
cfg
August 15, 2022, 4:48pm
8
No change. Shows the following on the screen. Does
Not change.
cfg
August 16, 2022, 8:02pm
9
How do I figure out if the problem is my control board?
jeffeb3
(Jeffeb3)
August 16, 2022, 10:18pm
10
It is one of these things:
The skr board
The skr firmware
The cable
The screen hardware
The screen firmware
The cables are the most common place to have problems. They can be plugged in backwards or swapped.
The firmware is easy enough to flash the skr and the screen. The tested firmware in MarlinBuilder releases is known to work.
After that, you need to test by replacing either the screen or the control board. I don’t know of a way to test it without more hardware.
cfg
August 17, 2022, 7:30am
11
Thanks, J, appreciate it. I’ll start looking into those. Ill need to see where in South Africa I can source those parts.
