So I have a bit of a weird one. I was using ESTLcam and it’s a bit clunky but everything seemed to work. I did some work with it and things were good, everything was to scale, etc. But I usually do my designs in Fusion 360 for my 3d printer so I wanted to start using that. I loaded the post processing code from here and everything went to heck.
It turned out that the output from Fusion 360 is dramatically scaled up, about double. You can only imagine what that did to my feeds and speeds. I broke a few endmills and had some trouble before I realized what was going on. So I did a quick shallow cutout of a ruler and sure enough, scale was off by nearly double.
I’m having no issues exporting designs from fusion to ESTLcam but for some reason I can’t use the Cam software in fusion 360.
Is there any way to fix this? Has this happened before? Maybe a post processing glitch?
