Driver is here and I’ve put into the remaining slot - C on the board.
[MSG:ERR: A Axis TMC driver not detected - expected 0x21 got 0x0]
Any ideas?
$ss
[MSG:INFO: FluidNC v3.9.5 https://github.com/bdring/FluidNC]
[MSG:INFO: Configuration file:config-PL.yaml]
[MSG:INFO: Machine LowRider]
[MSG:INFO: UART2 Tx:gpio.15 Rx:gpio.12 RTS:NO_PIN Baud:115200]
[MSG:INFO: uart_channel2 created at report interval: 75]
[MSG:INFO: I2SO BCK:gpio.22 WS:gpio.17 DATA:gpio.21Min Pulse:2us]
[MSG:INFO: Axis count 4]
[MSG:INFO: Axis X (3.000,1263.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis Y (3.000,2483.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Z Pos Limit gpio.32]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Pos Limit gpio.34]
[MSG:INFO: Axis A (-720.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:3 CS:I2SO.22 Step:I2SO.21 Dir:I2SO.20 Disable:I2SO.23 R:0.110]
[MSG:INFO: Connecting to STA SSID:xxxxxxxxx]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is xxxxxxxxxxx]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://fluidnc.local/]
[MSG:INFO: Laser Ena:NO_PIN Out:gpio.26 Freq:5000Hz Period:8191]
[MSG:INFO: Probe gpio.36:low]
ok
Heres my yaml for A:
#A
a:
steps_per_mm: 6.944
max_rate_mm_per_min: 20000
acceleration_mm_per_sec2: 500.00
max_travel_mm: 720.000
soft_limits: false
homing:
cycle: 0
positive_direction: true
mpos_mm: 0
feed_mm_per_min: 600.000
seek_mm_per_min: 300.000
settle_ms: 500
seek_scaler: 1.100
feed_scaler: 1.100
motor0:
limit_neg_pin: NO_PIN
limit_pos_pin: NO_PIN
limit_all_pin: NO_PIN
hard_limits: false
pulloff_mm: 0.1
tmc_2209:
uart_num: 1
addr: 3
cs_pin: I2SO.22
r_sense_ohms: 0.110
run_amps: 0.50
hold_amps: 0.40
homing_amps: 0.40
microsteps: 8
stallguard: 0
stallguard_debug: false
toff_disable: 0
toff_stealthchop: 5
toff_coolstep: 3
run_mode: StealthChop
homing_mode: StealthChop
use_enable: false
step_pin: I2SO.21
direction_pin: I2SO.20
disable_pin: I2SO.23
