I just read about Matt’s success w/ evening out his z-axis movement. Gives me hope. I went through a ton to get a reliable z-axis and it was working great for a couple months. Now it’s not.
I bought all the parts from Ryan. Using RC7 w/ modified speeds to stay safe. I’m using ESTLCAM 10.13 (latest) and have all the correct coordinates in setup, per Ryan’s post. The problems started last night, today I updated to the latest ESTLCAM and created the code again from scratch. Same problem.
I’m having the same issues as Matt, but without the Fusion360. I have a 30" x 30" sheet w/ a bunch of holes and parts. Some holes have a countersunk rim that’s supposed to be 1mm. It’s dipping to 2 or 3mm after a few minutes of cutting. It won’t do this every time or every test. It usually takes a while for it to catch.
Here’s my code from ESTLCAM - I haven’t been able to find it, but it could be tripping the speed barrier and losing steps, it shouldn’t tho, because I’m using the Rapid XY and Rapid Z settings to cap the speed.
Any thoughts? I’m in a bind to get these cuts done properly and any help would be awesome -
Thanks all
Code:
;Project Nagoya_Base_Pairs_CUTTING_FILES_Outer_Track_02_Inner_8_Top_Upper_Panels
;Created by Estlcam version 10 build 10.013
;Machining time about 00:46:24 hours
G90
M03 S24000
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z5.0000 F480
;No. 1: Hole 5
G00 X89.8917 Y56.9975 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180 S24000
G01 X95.5747 F1200
G01 X96.7676 Y58.4285 F1200
G01 X88.7009 F1200
G01 X88.2209 Y59.8595 F1200
G01 X97.2452 F1200
G01 X97.2471 Y61.2905 F1200
G01 X88.2218 F1200
G01 X88.7000 Y62.7215 F1200
G01 X96.7669 F1200
G01 X95.5751 Y64.1525 F1200
G01 X89.8932 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X89.6949 Y64.4008 F1200
G02 X96.5030 Y63.6847 I3.0395 J-3.8239 F1200
G02 X88.8778 Y57.5736 I-3.7692 J-3.1097 F1200
G02 X87.8475 Y60.5033 I3.8296 J2.9927 F1200
G01 X87.8477 Y60.6420 F1200
G02 X89.6949 Y64.4008 I4.8694 J-0.0597 F1200
G01 X89.8932 Y64.1525 F1200
G00 Z5.0000 F480
;No. 2: Hole 83
G00 X92.4596 Y59.1440 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X93.0106 F1200
G01 X94.1909 Y60.5750 F1200
G01 X91.2766 F1200
G01 X92.4569 Y62.0060 F1200
G01 X93.0079 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X93.0634 Y62.3188 F1200
G02 X93.5011 Y62.1768 I-0.3055 J-1.6877 F1200
G02 X91.9194 Y58.9965 I-0.7675 J-1.6018 F1200
G02 X90.9609 Y60.4768 I0.8171 J1.5796 F1200
G01 X90.9584 Y60.5827 F1200
G02 X93.0634 Y62.3188 I1.7743 J-0.0071 F1200
G01 X93.0079 Y62.0060 F1200
G00 Z5.0000 F480
;No. 3: Hole 6
G00 X140.9253 Y52.1790 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X146.6077 F1200
G01 X147.8010 Y53.6100 F1200
G01 X139.7344 F1200
G01 X139.2538 Y55.0410 F1200
G01 X148.2791 F1200
G01 X148.2805 Y56.4720 F1200
G01 X139.2552 F1200
G01 X139.7328 Y57.9030 F1200
G01 X147.8004 F1200
G01 X146.6087 Y59.3340 F1200
G01 X140.9264 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X140.7274 Y59.5816 F1200
G02 X145.7149 Y60.2400 I3.0413 J-3.8180 F1200
G02 X141.6799 Y51.3362 I-1.9480 J-4.4834 F1200
G02 X138.8805 Y55.7466 I2.0930 J4.4221 F1200
G01 X138.8813 Y55.8387 F1200
G02 X140.7274 Y59.5816 I4.8691 J-0.0748 F1200
G01 X140.9264 Y59.3340 F1200
G00 Z5.0000 F480
;No. 4: Hole 84
G00 X143.4941 Y54.3255 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X144.0435 F1200
G01 X145.2241 Y55.7565 F1200
G01 X142.3107 F1200
G01 X143.4913 Y57.1875 F1200
G01 X144.0402 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X144.0974 Y57.5002 F1200
G02 X144.6275 Y57.3101 I-0.3132 J-1.7067 F1200
G02 X142.8165 Y54.2567 I-0.8605 J-1.5534 F1200
G02 X141.9925 Y55.7111 I0.9515 J1.4996 F1200
G01 X141.9930 Y55.8142 F1200
G02 X144.0974 Y57.5002 I1.7735 J-0.0572 F1200
G01 X144.0402 Y57.1875 F1200
G00 Z5.0000 F480
;No. 5: Hole 17
G00 X109.9902 Y163.7828 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X104.3044 F1200
G01 X103.1115 Y165.2138 F1200
G01 X111.1801 F1200
G01 X111.6594 Y166.6448 F1200
G01 X102.6336 F1200
G01 X102.6324 Y168.0758 F1200
G01 X111.6581 F1200
G01 X111.1804 Y169.5068 F1200
G01 X103.1118 F1200
G01 X104.3023 Y170.9378 F1200
G01 X109.9876 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X110.1875 Y171.1851 F1200
G02 X110.9696 Y164.3175 I-3.0427 J-3.8248 F1200
G02 X104.1020 Y163.5354 I-3.8248 J3.0427 F1200
G02 X103.3199 Y170.4030 I3.0427 J3.8248 F1200
G02 X110.1875 Y171.1851 I3.8248 J-3.0427 F1200
G01 X109.9876 Y170.9378 F1200
G00 Z5.0000 F480
;No. 6: Hole 98
G00 X107.4187 Y165.9293 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X106.8707 F1200
G01 X105.6887 Y167.3603 F1200
G01 X108.6030 F1200
G01 X107.4212 Y168.7913 F1200
G01 X106.8733 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X106.8106 Y169.1030 F1200
G02 X108.8155 Y167.9647 I0.3368 J-1.7416 F1200
G02 X105.4435 Y166.8564 I-1.6695 J-0.6043 F1200
G02 X105.3727 Y167.2728 I1.7091 J0.5047 F1200
G01 X105.3706 Y167.3787 F1200
G02 X106.8106 Y169.1030 I1.7733 J-0.0175 F1200
G01 X106.8733 Y168.7913 F1200
G00 Z5.0000 F480
;No. 7: Hole 99
G00 X66.6935 Y155.0023 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X66.1425 F1200
G01 X64.9634 Y156.4333 F1200
G01 X67.8778 F1200
G01 X66.6965 Y157.8643 F1200
G01 X66.1482 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X66.0857 Y158.1760 F1200
G02 X68.0904 Y157.0373 I0.3365 J-1.7415 F1200
G02 X64.7183 Y155.9301 I-1.6695 J-0.6039 F1200
G02 X64.6456 Y156.3993 I1.7159 J0.5059 F1200
G01 X64.6453 Y156.4521 F1200
G02 X66.0857 Y158.1760 I1.7725 J-0.0172 F1200
G01 X66.1482 Y157.8643 F1200
G00 Z5.0000 F480
;No. 8: Hole 18
G00 X63.5785 Y152.8558 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X69.2654 F1200
G01 X70.4542 Y154.2868 F1200
G01 X62.3866 F1200
G01 X61.9086 Y155.7178 F1200
G01 X70.9348 F1200
G01 X70.9331 Y157.1488 F1200
G01 X61.9067 F1200
G01 X62.3876 Y158.5798 F1200
G01 X70.4551 F1200
G01 X69.2634 Y160.0108 F1200
G01 X63.5763 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X63.3758 Y160.2575 F1200
G02 X70.2438 Y159.4783 I3.0444 J-3.8236 F1200
G02 X69.4646 Y152.6103 I-3.8236 J-3.0444 F1200
G02 X62.5966 Y153.3895 I-3.0444 J3.8236 F1200
G02 X63.3758 Y160.2575 I3.8236 J3.0444 F1200
G01 X63.5763 Y160.0108 F1200
G00 Z5.0000 F480
;No. 9: Hole 19
G00 X59.9489 Y183.8714 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X54.2620 F1200
G01 X53.0699 Y185.3024 F1200
G01 X61.1378 F1200
G01 X61.6185 Y186.7334 F1200
G01 X52.5922 F1200
G01 X52.5902 Y188.1644 F1200
G01 X61.6165 F1200
G01 X61.1383 Y189.5954 F1200
G01 X53.0708 F1200
G01 X54.2604 Y191.0264 F1200
G01 X59.9463 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X60.1431 Y191.2762 F1200
G02 X60.9304 Y184.4091 I-3.0399 J-3.8272 F1200
G02 X54.0633 Y183.6218 I-3.8272 J3.0399 F1200
G02 X53.2760 Y190.4889 I3.0399 J3.8272 F1200
G02 X60.1431 Y191.2762 I3.8272 J-3.0399 F1200
G01 X59.9463 Y191.0264 F1200
G00 Z5.0000 F480
;No. 10: Hole 100
G00 X57.3770 Y186.0179 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X56.8257 F1200
G01 X55.6472 Y187.4489 F1200
G01 X58.5613 F1200
G01 X57.3800 Y188.8799 F1200
G01 X56.8317 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X56.7692 Y189.1916 F1200
G02 X58.7351 Y188.1513 I0.3365 J-1.7418 F1200
G02 X55.4348 Y186.8450 I-1.6307 J-0.7023 F1200
G02 X55.3310 Y187.3620 I1.6802 J0.6062 F1200
G01 X55.3288 Y187.4677 F1200
G02 X56.7692 Y189.1916 I1.7733 J-0.0180 F1200
G01 X56.8317 Y188.8799 F1200
G00 Z5.0000 F480
;No. 11: Hole 21
G00 X82.4510 Y271.0002 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X88.1381 F1200
G01 X89.3281 Y272.4312 F1200
G01 X81.2616 F1200
G01 X80.7805 Y273.8622 F1200
G01 X89.8078 F1200
G01 X89.8088 Y275.2932 F1200
G01 X80.7815 F1200
G01 X81.2616 Y276.7242 F1200
G01 X89.3277 F1200
G01 X88.1385 Y278.1552 F1200
G01 X82.4511 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X82.2563 Y278.4071 F1200
G02 X89.1238 Y277.6172 I3.0388 J-3.8286 F1200
G02 X88.3340 Y270.7498 I-3.8286 J-3.0388 F1200
G02 X81.4665 Y271.5396 I-3.0388 J3.8286 F1200
G02 X82.2563 Y278.4071 I3.8286 J3.0388 F1200
G01 X82.4511 Y278.1552 F1200
G00 Z5.0000 F480
;No. 12: Hole 102
G00 X85.0193 Y273.1467 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X85.5724 F1200
G01 X86.7520 Y274.5777 F1200
G01 X83.8369 F1200
G01 X85.0169 Y276.0087 F1200
G01 X85.5706 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X85.6283 Y276.3214 F1200
G02 X87.0480 Y274.8597 I-0.3319 J-1.7427 F1200
G02 X83.5336 Y274.3476 I-1.7534 J-0.2819 F1200
G01 X83.5231 Y274.4519 F1200
G01 X83.5188 Y274.5567 F1200
G01 X83.5190 Y274.6093 F1200
G02 X85.6283 Y276.3214 I1.7749 J-0.0313 F1200
G01 X85.5706 Y276.0087 F1200
G00 Z5.0000 F480
;No. 13: Hole 20
G00 X57.0254 Y279.9842 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X51.3372 F1200
G01 X50.1480 Y281.4152 F1200
G01 X58.2147 F1200
G01 X58.6942 Y282.8462 F1200
G01 X49.6670 F1200
G01 X49.6684 Y284.2772 F1200
G01 X58.6953 F1200
G01 X58.2146 Y285.7082 F1200
G01 X50.1481 F1200
G01 X51.3368 Y287.1392 F1200
G01 X57.0245 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X57.2214 Y287.3892 F1200
G02 X58.0087 Y280.5218 I-3.0400 J-3.8273 F1200
G02 X51.1414 Y279.7345 I-3.8273 J3.0400 F1200
G02 X50.3541 Y286.6019 I3.0400 J3.8273 F1200
G02 X57.2214 Y287.3892 I3.8273 J-3.0400 F1200
G01 X57.0245 Y287.1392 F1200
G00 Z5.0000 F480
;No. 14: Hole 101
G00 X54.4562 Y282.1307 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X53.9051 F1200
G01 X52.7237 Y283.5617 F1200
G01 X55.6385 F1200
G01 X54.4571 Y284.9927 F1200
G01 X53.9030 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X53.8382 Y285.3040 F1200
G02 X55.9231 Y283.9046 I0.3428 J-1.7422 F1200
G02 X54.5237 Y281.8197 I-1.7422 J-0.3428 F1200
G02 X52.4388 Y283.2190 I-0.3428 J1.7422 F1200
G02 X53.8382 Y285.3040 I1.7422 J0.3428 F1200
G01 X53.9030 Y284.9927 F1200
G00 Z5.0000 F480
;No. 15: Hole 22
G00 X61.8275 Y320.8239 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X67.5152 F1200
G01 X68.7049 Y322.2549 F1200
G01 X60.6382 F1200
G01 X60.1573 Y323.6859 F1200
G01 X69.1843 F1200
G01 X69.1855 Y325.1169 F1200
G01 X60.1587 F1200
G01 X60.6377 Y326.5479 F1200
G01 X68.7046 F1200
G01 X67.5159 Y327.9789 F1200
G01 X61.8286 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X61.6310 Y328.2282 F1200
G02 X68.4988 Y327.4427 I3.0412 J-3.8266 F1200
G02 X67.7134 Y320.5749 I-3.8266 J-3.0412 F1200
G02 X60.8456 Y321.3604 I-3.0412 J3.8266 F1200
G02 X61.6310 Y328.2282 I3.8266 J3.0412 F1200
G01 X61.8286 Y327.9789 F1200
G00 Z5.0000 F480
;No. 16: Hole 162
G00 X64.3968 Y322.9704 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X64.9498 F1200
G01 X66.1287 Y324.4014 F1200
G01 X63.2142 F1200
G01 X64.3958 Y325.8324 F1200
G01 X64.9469 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X65.0045 Y326.1451 F1200
G02 X66.4385 Y324.5799 I-0.3317 J-1.7434 F1200
G02 X62.8971 Y324.3276 I-1.7670 J-0.1781 F1200
G01 X62.8960 Y324.4328 F1200
G02 X65.0045 Y326.1451 I1.7751 J-0.0314 F1200
G01 X64.9469 Y325.8324 F1200
G00 Z5.0000 F480
;No. 17: Hole 60
G00 X142.8761 Y386.7204 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X148.5617 F1200
G01 X149.7549 Y388.1514 F1200
G01 X141.6863 F1200
G01 X141.2066 Y389.5824 F1200
G01 X150.2328 F1200
G01 X150.2335 Y391.0134 F1200
G01 X141.2078 F1200
G01 X141.6857 Y392.4444 F1200
G01 X149.7547 F1200
G01 X148.5644 Y393.8754 F1200
G01 X142.8788 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X142.6812 Y394.1248 F1200
G02 X149.5484 Y393.3361 I3.0392 J-3.8280 F1200
G02 X148.7596 Y386.4689 I-3.8280 J-3.0392 F1200
G02 X141.8924 Y387.2576 I-3.0392 J3.8280 F1200
G02 X142.6812 Y394.1248 I3.8280 J3.0392 F1200
G01 X142.8788 Y393.8754 F1200
G00 Z5.0000 F480
;No. 18: Hole 155
G00 X145.4478 Y388.8669 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X145.9952 F1200
G01 X147.1771 Y390.2979 F1200
G01 X144.2633 F1200
G01 X145.4420 Y391.7289 F1200
G01 X145.9953 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X146.0527 Y392.0417 F1200
G02 X147.4275 Y390.7875 I-0.3314 J-1.7438 F1200
G02 X143.9872 Y389.9102 I-1.7072 J-0.4893 F1200
G02 X143.9463 Y390.2235 I1.7327 J0.3853 F1200
G01 X143.9452 Y390.3295 F1200
G02 X146.0527 Y392.0417 I1.7754 J-0.0321 F1200
G01 X145.9953 Y391.7289 F1200
G00 Z5.0000 F480
;No. 19: Hole 61
G00 X144.4332 Y419.0681 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X150.1180 F1200
G01 X151.3112 Y420.4991 F1200
G01 X143.2421 F1200
G01 X142.7629 Y421.9301 F1200
G01 X151.7890 F1200
G01 X151.7898 Y423.3611 F1200
G01 X142.7642 F1200
G01 X143.2420 Y424.7921 F1200
G01 X151.3105 F1200
G01 X150.1206 Y426.2231 F1200
G01 X144.4351 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X144.2361 Y426.4710 F1200
G02 X151.1034 Y425.6849 I3.0406 J-3.8267 F1200
G02 X150.3173 Y418.8176 I-3.8267 J-3.0406 F1200
G02 X143.4500 Y419.6037 I-3.0406 J3.8267 F1200
G02 X144.2361 Y426.4710 I3.8267 J3.0406 F1200
G01 X144.4351 Y426.2231 F1200
G00 Z5.0000 F480
;No. 20: Hole 154
G00 X147.0023 Y421.2146 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X147.5515 F1200
G01 X148.7338 Y422.6456 F1200
G01 X145.8197 F1200
G01 X146.9983 Y424.0766 F1200
G01 X147.5516 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X147.6090 Y424.3894 F1200
G02 X148.9838 Y423.1351 I-0.3314 J-1.7438 F1200
G02 X145.5435 Y422.2578 I-1.7072 J-0.4893 F1200
G02 X145.5026 Y422.5712 I1.7327 J0.3853 F1200
G01 X145.5015 Y422.6771 F1200
G02 X147.6090 Y424.3894 I1.7754 J-0.0321 F1200
G01 X147.5516 Y424.0766 F1200
G00 Z5.0000 F480
;No. 21: Hole 62
G00 X83.3507 Y481.1262 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X77.6677 F1200
G01 X76.4763 Y482.5572 F1200
G01 X84.5441 F1200
G01 X85.0216 Y483.9882 F1200
G01 X75.9977 F1200
G01 X75.9982 Y485.4192 F1200
G01 X85.0227 F1200
G01 X84.5445 Y486.8502 F1200
G01 X76.4757 F1200
G01 X77.6691 Y488.2812 F1200
G01 X83.3525 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X83.5509 Y488.5298 F1200
G02 X84.3375 Y481.6630 I-3.0401 J-3.8267 F1200
G02 X77.4707 Y480.8763 I-3.8267 J3.0401 F1200
G02 X76.6841 Y487.7431 I3.0401 J3.8267 F1200
G02 X83.5509 Y488.5298 I3.8267 J-3.0401 F1200
G01 X83.3525 Y488.2812 F1200
G00 Z5.0000 F480
;No. 22: Hole 161
G00 X80.7850 Y483.2727 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X80.2379 F1200
G01 X79.0531 Y484.7037 F1200
G01 X81.9670 F1200
G01 X80.7822 Y486.1347 F1200
G01 X80.2340 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X80.1729 Y486.4467 F1200
G02 X82.2531 Y485.0409 I0.3372 J-1.7430 F1200
G02 X80.8474 Y482.9607 I-1.7430 J-0.3372 F1200
G02 X78.7672 Y484.3665 I-0.3372 J1.7430 F1200
G02 X80.1729 Y486.4467 I1.7430 J0.3372 F1200
G01 X80.2340 Y486.1347 F1200
G00 Z5.0000 F480
;No. 23: Hole 63
G00 X175.8014 Y522.2959 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X181.4865 F1200
G01 X182.6799 Y523.7269 F1200
G01 X174.6109 F1200
G01 X174.1318 Y525.1579 F1200
G01 X183.1575 F1200
G01 X183.1582 Y526.5889 F1200
G01 X174.1330 F1200
G01 X174.6103 Y528.0199 F1200
G01 X182.6793 F1200
G01 X181.4881 Y529.4509 F1200
G01 X175.8038 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X175.6036 Y529.6980 F1200
G02 X182.4712 Y528.9138 I3.0417 J-3.8259 F1200
G02 X181.6870 Y522.0462 I-3.8259 J-3.0417 F1200
G02 X174.8194 Y522.8304 I-3.0417 J3.8259 F1200
G02 X175.6036 Y529.6980 I3.8259 J3.0417 F1200
G01 X175.8038 Y529.4509 F1200
G00 Z5.0000 F480
;No. 24: Hole 153
G00 X178.3693 Y524.4424 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X178.9217 F1200
G01 X180.1020 Y525.8734 F1200
G01 X177.1879 F1200
G01 X178.3677 Y527.3044 F1200
G01 X178.9175 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X178.9774 Y527.6166 F1200
G02 X180.3960 Y526.1693 I-0.3306 J-1.7430 F1200
G02 X176.8799 Y525.6821 I-1.7508 J-0.2957 F1200
G01 X176.8717 Y525.7876 F1200
G01 X176.8700 Y525.8406 F1200
G01 X176.8698 Y525.8936 F1200
G02 X178.9774 Y527.6166 I1.7749 J-0.0205 F1200
G01 X178.9175 Y527.3044 F1200
G00 Z5.0000 F480
;No. 25: Hole 64
G00 X208.1852 Y522.0707 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X213.8703 F1200
G01 X215.0638 Y523.5017 F1200
G01 X206.9947 F1200
G01 X206.5156 Y524.9327 F1200
G01 X215.5412 F1200
G01 X215.5419 Y526.3637 F1200
G01 X206.5167 F1200
G01 X206.9940 Y527.7947 F1200
G01 X215.0637 F1200
G01 X213.8726 Y529.2257 F1200
G01 X208.1888 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X207.9901 Y529.4740 F1200
G02 X215.9039 Y525.9956 I3.0410 J-3.8230 F1200
G02 X206.1455 Y525.4544 I-4.8749 J-0.3473 F1200
G01 X206.1428 Y525.5464 F1200
G01 X206.1420 Y525.6851 F1200
G02 X207.9901 Y529.4740 I4.8656 J-0.0282 F1200
G01 X208.1888 Y529.2257 F1200
G00 Z5.0000 F480
;No. 26: Hole 152
G00 X210.7531 Y524.2172 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X211.3055 F1200
G01 X212.4861 Y525.6482 F1200
G01 X209.5720 F1200
G01 X210.7516 Y527.0792 F1200
G01 X211.3013 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X211.3612 Y527.3914 F1200
G02 X212.7703 Y525.9960 I-0.3307 J-1.7432 F1200
G02 X209.2701 Y525.4045 I-1.7414 J-0.3475 F1200
G01 X209.2588 Y525.5096 F1200
G01 X209.2555 Y525.5624 F1200
G01 X209.2537 Y525.6684 F1200
G02 X211.3612 Y527.3914 I1.7749 J-0.0205 F1200
G01 X211.3013 Y527.0792 F1200
G00 Z5.0000 F480
;No. 27: Hole 65
G00 X279.3857 Y565.6306 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X285.0707 F1200
G01 X286.2633 Y567.0616 F1200
G01 X278.1936 F1200
G01 X277.7154 Y568.4926 F1200
G01 X286.7408 F1200
G01 X286.7413 Y569.9236 F1200
G01 X277.7165 F1200
G01 X278.1938 Y571.3546 F1200
G01 X286.2631 F1200
G01 X285.0713 Y572.7856 F1200
G01 X279.3864 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X279.1847 Y573.0314 F1200
G02 X286.0528 Y572.2508 I3.0438 J-3.8243 F1200
G02 X285.2722 Y565.3827 I-3.8243 J-3.0438 F1200
G02 X278.4041 Y566.1633 I-3.0438 J3.8243 F1200
G02 X279.1847 Y573.0314 I3.8243 J3.0438 F1200
G01 X279.3864 Y572.7856 F1200
G00 Z5.0000 F480
;No. 28: Hole 148
G00 X281.9558 Y567.7771 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X282.5033 F1200
G01 X283.6852 Y569.2081 F1200
G01 X280.7718 F1200
G01 X281.9537 Y570.6391 F1200
G01 X282.5013 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X282.5588 Y570.9517 F1200
G02 X283.9854 Y569.4651 I-0.3300 J-1.7445 F1200
G02 X280.4596 Y569.0563 I-1.7568 J-0.2568 F1200
G01 X280.4538 Y569.1621 F1200
G01 X280.4542 Y569.2678 F1200
G02 X282.5588 Y570.9517 I1.7733 J-0.0591 F1200
G01 X282.5013 Y570.6391 F1200
G00 Z5.0000 F480
;No. 29: Hole 66
G00 X311.7554 Y566.6128 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X317.4404 F1200
G01 X318.6330 Y568.0438 F1200
G01 X310.5637 F1200
G01 X310.0851 Y569.4748 F1200
G01 X319.1108 F1200
G01 X319.1113 Y570.9058 F1200
G01 X310.0857 F1200
G01 X310.5631 Y572.3368 F1200
G01 X318.6329 F1200
G01 X317.4411 Y573.7678 F1200
G01 X311.7570 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X311.5599 Y574.0181 F1200
G02 X318.4268 Y573.2275 I3.0381 J-3.8288 F1200
G02 X317.6362 Y566.3606 I-3.8288 J-3.0381 F1200
G02 X310.7693 Y567.1512 I-3.0381 J3.8288 F1200
G02 X311.5599 Y574.0181 I3.8288 J3.0381 F1200
G01 X311.7570 Y573.7678 F1200
G00 Z5.0000 F480
;No. 30: Hole 149
G00 X314.3235 Y568.7593 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X314.8731 F1200
G01 X316.0549 Y570.1903 F1200
G01 X313.1415 F1200
G01 X314.3234 Y571.6213 F1200
G01 X314.8710 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X314.9285 Y571.9340 F1200
G02 X316.2981 Y570.7044 I-0.3289 J-1.7439 F1200
G02 X312.8710 Y569.7779 I-1.6999 J-0.5137 F1200
G02 X312.8235 Y570.1443 I1.7365 J0.4116 F1200
G01 X312.8239 Y570.2501 F1200
G02 X314.9285 Y571.9340 I1.7733 J-0.0591 F1200
G01 X314.8710 Y571.6213 F1200
G00 Z5.0000 F480
;No. 31: Hole 150
G00 X316.8515 Y526.6697 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X317.4009 F1200
G01 X318.5836 Y528.1007 F1200
G01 X315.6702 F1200
G01 X316.8528 Y529.5317 F1200
G01 X317.4003 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X317.4578 Y529.8444 F1200
G02 X318.8753 Y528.4094 I-0.3313 J-1.7450 F1200
G02 X315.3633 Y527.8968 I-1.7484 J-0.3087 F1200
G01 X315.3543 Y528.0024 F1200
G01 X315.3521 Y528.0551 F1200
G01 X315.3526 Y528.1605 F1200
G02 X317.4578 Y529.8444 I1.7731 J-0.0589 F1200
G01 X317.4003 Y529.5317 F1200
G00 Z5.0000 F480
;No. 32: Hole 67
G00 X319.9691 Y524.5232 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X314.2851 F1200
G01 X313.0922 Y525.9542 F1200
G01 X321.1617 F1200
G01 X321.6395 Y527.3852 F1200
G01 X312.6143 F1200
G01 X312.6142 Y528.8162 F1200
G01 X321.6393 F1200
G01 X321.1616 Y530.2472 F1200
G01 X313.0921 F1200
G01 X314.2849 Y531.6782 F1200
G01 X319.9691 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X320.1662 Y531.9274 F1200
G02 X320.9536 Y525.0603 I-3.0399 J-3.8273 F1200
G02 X314.0865 Y524.2729 I-3.8273 J3.0399 F1200
G02 X313.2991 Y531.1400 I3.0399 J3.8273 F1200
G02 X320.1662 Y531.9274 I3.8273 J-3.0399 F1200
G01 X319.9691 Y531.6782 F1200
G00 Z5.0000 F480
;No. 33: Hole 113
G00 X352.5574 Y420.8281 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X353.1053 F1200
G01 X354.2889 Y422.2591 F1200
G01 X351.3748 F1200
G01 X352.5586 Y423.6901 F1200
G01 X353.1055 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X353.1681 Y424.0018 F1200
G02 X354.5535 Y422.6941 I-0.3348 J-1.7425 F1200
G02 X351.0877 Y421.9273 I-1.7216 J-0.4348 F1200
G02 X351.0567 Y422.2429 I1.7619 J0.3325 F1200
G01 X351.0570 Y422.2955 F1200
G02 X353.1681 Y424.0018 I1.7741 J-0.0359 F1200
G01 X353.1055 Y423.6901 F1200
G00 Z5.0000 F480
;No. 34: Hole 35
G00 X355.6740 Y418.6816 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X349.9899 F1200
G01 X348.7970 Y420.1126 F1200
G01 X356.8668 F1200
G01 X357.3445 Y421.5436 F1200
G01 X348.3193 F1200
G01 X348.3194 Y422.9746 F1200
G01 X357.3445 F1200
G01 X356.8669 Y424.4056 F1200
G01 X348.7971 F1200
G01 X349.9894 Y425.8366 F1200
G01 X355.6741 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X355.8708 Y426.0865 F1200
G02 X356.6597 Y419.2196 I-3.0389 J-3.8279 F1200
G02 X349.7929 Y418.4307 I-3.8279 J3.0389 F1200
G02 X349.0040 Y425.2975 I3.0389 J3.8279 F1200
G02 X355.8708 Y426.0865 I3.8279 J-3.0389 F1200
G01 X355.6741 Y425.8366 F1200
G00 Z5.0000 F480
;No. 35: Hole 112
G00 X355.4707 Y388.5301 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X354.9227 F1200
G01 X353.7403 Y389.9611 F1200
G01 X356.6541 F1200
G01 X355.4709 Y391.3921 F1200
G01 X354.9239 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X354.8649 Y391.7044 F1200
G02 X356.9581 Y390.1884 I0.3336 J-1.7424 F1200
G02 X353.4261 Y389.8392 I-1.7608 J-0.2273 F1200
G01 X353.4220 Y389.9448 F1200
G01 X353.4242 Y390.0503 F1200
G02 X354.8649 Y391.7044 I1.7715 J-0.0885 F1200
G01 X354.9239 Y391.3921 F1200
G00 Z5.0000 F480
;No. 36: Hole 34
G00 X352.3547 Y386.3836 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X358.0393 F1200
G01 X359.2322 Y387.8146 F1200
G01 X351.1624 F1200
G01 X350.6845 Y389.2456 F1200
G01 X359.7098 F1200
G01 X359.7099 Y390.6766 F1200
G01 X350.6849 F1200
G01 X351.1622 Y392.1076 F1200
G01 X359.2320 F1200
G01 X358.0397 Y393.5386 F1200
G01 X352.3548 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X352.1533 Y393.7845 F1200
G02 X359.0213 Y393.0039 I3.0436 J-3.8243 F1200
G02 X358.2406 Y386.1359 I-3.8243 J-3.0436 F1200
G02 X351.3727 Y386.9166 I-3.0436 J3.8243 F1200
G02 X352.1533 Y393.7845 I3.8243 J3.0436 F1200
G01 X352.3548 Y393.5386 F1200
G00 Z5.0000 F480
;No. 37: Hole 107
G00 X294.0702 Y314.9512 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X293.5196 F1200
G01 X292.3352 Y316.3822 F1200
G01 X295.2494 F1200
G01 X294.0650 Y317.8132 F1200
G01 X293.5144 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X293.4554 Y318.1251 F1200
G02 X295.5370 Y316.7139 I0.3382 J-1.7418 F1200
G02 X292.0312 Y316.1545 I-1.7447 J-0.3314 F1200
G01 X292.0209 Y316.2595 F1200
G01 X292.0169 Y316.3651 F1200
G01 X292.0172 Y316.4181 F1200
G02 X293.4554 Y318.1251 I1.7732 J-0.0345 F1200
G01 X293.5144 Y317.8132 F1200
G00 Z5.0000 F480
;No. 38: Hole 26
G00 X290.9486 Y312.8047 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X296.6336 F1200
G01 X297.8272 Y314.2357 F1200
G01 X289.7581 F1200
G01 X289.2784 Y315.6667 F1200
G01 X298.3048 F1200
G01 X298.3056 Y317.0977 F1200
G01 X289.2802 F1200
G01 X289.7574 Y318.5287 F1200
G01 X297.8259 F1200
G01 X296.6365 Y319.9597 F1200
G01 X290.9508 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X290.7557 Y320.2111 F1200
G02 X297.6225 Y319.4180 I3.0369 J-3.8299 F1200
G02 X296.8294 Y312.5512 I-3.8299 J-3.0369 F1200
G02 X289.9626 Y313.3443 I-3.0369 J3.8299 F1200
G02 X290.7557 Y320.2111 I3.8299 J3.0369 F1200
G01 X290.9508 Y319.9597 F1200
G00 Z5.0000 F480
;No. 39: Hole 106
G00 X290.9202 Y282.6707 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X291.4708 F1200
G01 X292.6497 Y284.1017 F1200
G01 X289.7360 F1200
G01 X290.9149 Y285.5327 F1200
G01 X291.4655 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X291.5284 Y285.8443 F1200
G02 X292.8863 Y284.6367 I-0.3323 J-1.7411 F1200
G02 X289.4707 Y283.6675 I-1.6935 J-0.5350 F1200
G02 X289.4187 Y284.0317 I1.7158 J0.4311 F1200
G01 X289.4178 Y284.1375 F1200
G02 X291.5284 Y285.8443 I1.7740 J-0.0354 F1200
G01 X291.4655 Y285.5327 F1200
G00 Z5.0000 F480
;No. 40: Hole 27
G00 X294.0344 Y280.5242 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X288.3487 F1200
G01 X287.1593 Y281.9552 F1200
G01 X295.2278 F1200
G01 X295.7053 Y283.3862 F1200
G01 X286.6790 F1200
G01 X286.6804 Y284.8172 F1200
G01 X295.7067 F1200
G01 X295.2269 Y286.2482 F1200
G01 X287.1579 F1200
G01 X288.3511 Y287.6792 F1200
G01 X294.0365 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X294.2336 Y287.9292 F1200
G02 X295.0218 Y281.0616 I-3.0397 J-3.8279 F1200
G02 X288.1542 Y280.2734 I-3.8279 J3.0397 F1200
G02 X287.3659 Y287.1410 I3.0397 J3.8279 F1200
G02 X294.2336 Y287.9292 I3.8279 J-3.0397 F1200
G01 X294.0365 Y287.6792 F1200
G00 Z5.0000 F480
;No. 41: Hole 28
G00 X330.2826 Y276.1080 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X335.9685 F1200
G01 X337.1605 Y277.5390 F1200
G01 X329.0928 F1200
G01 X328.6126 Y278.9700 F1200
G01 X337.6390 F1200
G01 X337.6404 Y280.4010 F1200
G01 X328.6140 F1200
G01 X329.0924 Y281.8320 F1200
G01 X337.1596 F1200
G01 X335.9704 Y283.2630 F1200
G01 X330.2845 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X330.0870 Y283.5126 F1200
G02 X336.9546 Y282.7250 I3.0400 J-3.8276 F1200
G02 X336.1670 Y275.8574 I-3.8276 J-3.0400 F1200
G02 X329.2994 Y276.6450 I-3.0400 J3.8276 F1200
G02 X330.0870 Y283.5126 I3.8276 J3.0400 F1200
G01 X330.2845 Y283.2630 F1200
G00 Z5.0000 F480
;No. 42: Hole 108
G00 X332.8526 Y278.2545 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X333.4047 F1200
G01 X334.5839 Y279.6855 F1200
G01 X331.6695 F1200
G01 X332.8507 Y281.1165 F1200
G01 X333.3992 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X333.4620 Y281.4281 F1200
G02 X334.8608 Y280.0682 I-0.3328 J-1.7416 F1200
G02 X331.3817 Y279.3542 I-1.7343 J-0.3826 F1200
G02 X331.3522 Y279.6153 I1.7355 J0.3282 F1200
G01 X331.3513 Y279.7209 F1200
G02 X333.4620 Y281.4281 I1.7742 J-0.0350 F1200
G01 X333.3992 Y281.1165 F1200
G00 Z5.0000 F480
;No. 43: Hole 32
G00 X416.3604 Y285.2073 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X422.0481 F1200
G01 X423.2381 Y286.6383 F1200
G01 X415.1715 F1200
G01 X414.6902 Y288.0693 F1200
G01 X423.7172 F1200
G01 X423.7185 Y289.5003 F1200
G01 X414.6919 F1200
G01 X415.1706 Y290.9313 F1200
G01 X423.2372 F1200
G01 X422.0483 Y292.3623 F1200
G01 X416.3606 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X416.1661 Y292.6136 F1200
G02 X423.0334 Y291.8243 I3.0390 J-3.8283 F1200
G02 X422.2441 Y284.9570 I-3.8283 J-3.0390 F1200
G02 X415.3768 Y285.7463 I-3.0390 J3.8283 F1200
G02 X416.1661 Y292.6136 I3.8283 J3.0390 F1200
G01 X416.3606 Y292.3623 F1200
G00 Z5.0000 F480
;No. 44: Hole 109
G00 X418.9314 Y287.3538 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X419.4824 F1200
G01 X420.6615 Y288.7848 F1200
G01 X417.7466 F1200
G01 X418.9263 Y290.2158 F1200
G01 X419.4773 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X419.5344 Y290.5285 F1200
G01 X419.5733 Y290.5214 F1200
G02 X418.7324 Y287.0733 I-0.3690 J-1.7366 F1200
G02 X417.4314 Y288.6816 I0.4716 J1.7118 F1200
G01 X417.4285 Y288.7867 F1200
G02 X419.5344 Y290.5285 I1.7746 J-0.0016 F1200
G01 X419.4773 Y290.2158 F1200
G00 Z5.0000 F480
;No. 45: Hole 31
G00 X447.8565 Y277.6734 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X453.5442 F1200
G01 X454.7342 Y279.1044 F1200
G01 X446.6675 F1200
G01 X446.1863 Y280.5354 F1200
G01 X455.2134 F1200
G01 X455.2142 Y281.9664 F1200
G01 X446.1875 F1200
G01 X446.6667 Y283.3974 F1200
G01 X454.7332 F1200
G01 X453.5443 Y284.8284 F1200
G01 X447.8567 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X447.6587 Y285.0768 F1200
G02 X454.5266 Y284.2939 I3.0425 J-3.8254 F1200
G02 X453.7438 Y277.4260 I-3.8254 J-3.0425 F1200
G02 X446.8759 Y278.2088 I-3.0425 J3.8254 F1200
G02 X447.6587 Y285.0768 I3.8254 J3.0425 F1200
G01 X447.8567 Y284.8284 F1200
G00 Z5.0000 F480
;No. 46: Hole 111
G00 X450.4263 Y279.8199 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X450.9768 F1200
G01 X452.1582 Y281.2509 F1200
G01 X449.2432 F1200
G01 X450.4223 Y282.6819 F1200
G01 X450.9734 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X451.0304 Y282.9946 F1200
G02 X451.9419 Y282.5209 I-0.3267 J-1.7422 F1200
G02 X449.3862 Y280.0564 I-1.2415 J-1.2700 F1200
G02 X448.9252 Y281.2002 I1.3207 J1.1971 F1200
G01 X448.9255 Y281.3054 F1200
G02 X451.0304 Y282.9946 I1.7737 J-0.0541 F1200
G01 X450.9734 Y282.6819 F1200
G00 Z5.0000 F480
;No. 47: Hole 33
G00 X430.6358 Y326.4889 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X424.9485 F1200
G01 X423.7599 Y327.9199 F1200
G01 X431.8268 F1200
G01 X432.3050 Y329.3509 F1200
G01 X423.2790 F1200
G01 X423.2805 Y330.7819 F1200
G01 X432.3067 F1200
G01 X431.8257 Y332.2129 F1200
G01 X423.7587 F1200
G01 X424.9497 Y333.6439 F1200
G01 X430.6370 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X430.8374 Y333.8908 F1200
G02 X431.6182 Y327.0225 I-3.0438 J-3.8246 F1200
G02 X424.7499 Y326.2417 I-3.8246 J3.0438 F1200
G02 X423.9691 Y333.1100 I3.0438 J3.8246 F1200
G02 X430.8374 Y333.8908 I3.8246 J-3.0438 F1200
G01 X430.6370 Y333.6439 F1200
G00 Z5.0000 F480
;No. 48: Hole 110
G00 X428.0695 Y328.6354 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X427.5188 F1200
G01 X426.3351 Y330.0664 F1200
G01 X429.2504 F1200
G01 X428.0668 Y331.4974 F1200
G01 X427.5161 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X427.4509 Y331.8086 F1200
G02 X427.6894 Y331.8393 I0.3284 J-1.6097 F1200
G02 X427.7909 Y328.2907 I0.1033 J-1.7728 F1200
G02 X426.0177 Y330.0156 I0.0015 J1.7754 F1200
G01 X426.0171 Y330.0683 F1200
G02 X427.4509 Y331.8086 I1.7741 J-0.0009 F1200
G01 X427.5161 Y331.4974 F1200
G00 Z5.0000 F480
;No. 49: Hole 36
G00 X510.4159 Y353.9759 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.1545 F1200
G01 X514.6170 Y355.4069 F1200
G01 X508.9536 F1200
G01 X508.6133 Y356.8379 F1200
G01 X514.9568 F1200
G01 X514.6170 Y358.2689 F1200
G01 X508.9536 F1200
G01 X510.4174 Y359.6999 F1200
G01 X513.1542 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.2881 Y359.9882 F1200
G02 X514.9353 Y355.3352 I-1.5029 J-3.1501 F1200
G02 X510.2822 Y353.6880 I-3.1501 J1.5029 F1200
G02 X508.6351 Y358.3410 I1.5029 J3.1501 F1200
G02 X513.2881 Y359.9882 I3.1501 J-1.5029 F1200
G01 X513.1542 Y359.6999 F1200
G00 Z5.0000 F480
;No. 50: Hole 116
G00 X512.4160 Y356.8379 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X511.1539 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X510.8363 Y356.8291 F1200
G01 X510.8358 Y356.8461 F1200
G02 X512.1588 Y357.7112 I0.9498 J-0.0084 F1200
G02 X511.3626 Y355.9874 I-0.3735 J-0.8733 F1200
G02 X510.8363 Y356.8291 I0.4215 J0.8490 F1200
G01 X511.1539 Y356.8379 F1200
G00 Z5.0000 F480
;No. 51: Hole 37
G00 X511.0874 Y382.1902 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.8254 F1200
G01 X515.2881 Y383.6212 F1200
G01 X509.6252 F1200
G01 X509.2847 Y385.0522 F1200
G01 X515.6278 F1200
G01 X515.2880 Y386.4832 F1200
G01 X509.6244 F1200
G01 X511.0871 Y387.9142 F1200
G01 X513.8256 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.9595 Y388.2023 F1200
G02 X515.6059 Y383.5489 I-1.5035 J-3.1499 F1200
G02 X510.9526 Y381.9025 I-3.1499 J1.5035 F1200
G02 X509.3062 Y386.5559 I1.5035 J3.1499 F1200
G02 X513.9595 Y388.2023 I3.1499 J-1.5035 F1200
G01 X513.8256 Y387.9142 F1200
G00 Z5.0000 F480
;No. 52: Hole 117
G00 X513.0876 Y385.0522 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X511.8249 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X511.5071 Y385.0463 F1200
G01 X511.5068 Y385.0604 F1200
G02 X512.4511 Y386.0015 I0.9493 J-0.0082 F1200
G02 X512.3479 Y384.1091 I0.0055 J-0.9493 F1200
G02 X511.5071 Y385.0463 I0.1078 J0.9425 F1200
G01 X511.8249 Y385.0522 F1200
G00 Z5.0000 F480
;No. 53: Hole 38
G00 X513.0033 Y428.7169 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X507.3199 F1200
G01 X506.1272 Y430.1479 F1200
G01 X514.1960 F1200
G01 X514.6744 Y431.5789 F1200
G01 X505.6487 F1200
G01 Y433.0099 F1200
G01 X514.6743 F1200
G01 X514.1959 Y434.4409 F1200
G01 X506.1271 F1200
G01 X507.3201 Y435.8719 F1200
G01 X513.0028 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.2013 Y436.1202 F1200
G02 X513.9876 Y429.2527 I-3.0407 J-3.8269 F1200
G02 X507.1200 Y428.4665 I-3.8269 J3.0407 F1200
G02 X506.3338 Y435.3340 I3.0407 J3.8269 F1200
G02 X513.2013 Y436.1202 I3.8269 J-3.0407 F1200
G01 X513.0028 Y435.8719 F1200
G00 Z5.0000 F480
;No. 54: Hole 130
G00 X510.4360 Y430.8634 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X509.8865 F1200
G01 X508.7048 Y432.2944 F1200
G01 X511.6183 F1200
G01 X510.4366 Y433.7254 F1200
G01 X509.8871 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X509.8311 Y434.0383 F1200
G02 X511.8741 Y432.7645 I0.3314 J-1.7438 F1200
G02 X508.4244 Y431.9263 I-1.7125 J-0.4698 F1200
G02 X508.3865 Y432.2787 I1.7429 J0.3657 F1200
G01 X508.3903 Y432.4117 F1200
G02 X509.8311 Y434.0383 I1.7701 J-0.1165 F1200
G01 X509.8871 Y433.7254 F1200
G00 Z5.0000 F480
;No. 55: Hole 39
G00 X507.3199 Y456.9391 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X513.0027 F1200
G01 X514.1954 Y458.3701 F1200
G01 X506.1272 F1200
G01 X505.6488 Y459.8011 F1200
G01 X514.6749 F1200
G01 X514.6748 Y461.2321 F1200
G01 X505.6482 F1200
G01 X506.1271 Y462.6631 F1200
G01 X514.1959 F1200
G01 X513.0032 Y464.0941 F1200
G01 X507.3200 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X507.1246 Y464.3449 F1200
G02 X513.9907 Y463.5530 I3.0371 J-3.8290 F1200
G02 X513.1988 Y456.6869 I-3.8290 J-3.0371 F1200
G02 X506.3327 Y457.4788 I-3.0371 J3.8290 F1200
G02 X507.1246 Y464.3449 I3.8290 J3.0371 F1200
G01 X507.3200 Y464.0941 F1200
G00 Z5.0000 F480
;No. 56: Hole 131
G00 X509.8867 Y459.0856 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X510.4370 F1200
G01 X511.6183 Y460.5166 F1200
G01 X508.7048 F1200
G01 X509.8871 Y461.9476 F1200
G01 X510.4366 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X510.5007 Y462.2590 F1200
G02 X510.7749 Y462.1833 I-0.3081 J-1.6511 F1200
G02 X509.4509 Y458.8891 I-0.6135 J-1.6666 F1200
G02 X508.3865 Y460.5115 I0.7090 J1.6254 F1200
G01 X508.3896 Y460.6185 F1200
G02 X510.5007 Y462.2590 I1.7712 J-0.1006 F1200
G01 X510.4366 Y461.9476 F1200
G00 Z5.0000 F480
;No. 57: Hole 53
G00 X523.6286 Y508.5918 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X529.3140 F1200
G01 X530.5062 Y510.0228 F1200
G01 X522.4361 F1200
G01 X521.9586 Y511.4538 F1200
G01 X530.9841 F1200
G01 Y512.8848 F1200
G01 X521.9590 F1200
G01 X522.4367 Y514.3158 F1200
G01 X530.5066 F1200
G01 X529.3141 Y515.7468 F1200
G01 X523.6292 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X523.4289 Y515.9939 F1200
G02 X530.2965 Y515.2105 I3.0421 J-3.8256 F1200
G02 X529.5131 Y508.3428 I-3.8256 J-3.0421 F1200
G02 X522.6454 Y509.1263 I-3.0421 J3.8256 F1200
G02 X523.4289 Y515.9939 I3.8256 J3.0421 F1200
G01 X523.6292 Y515.7468 F1200
G00 Z5.0000 F480
;No. 58: Hole 132
G00 X526.1981 Y510.7383 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X526.7460 F1200
G01 X527.9281 Y512.1693 F1200
G01 X525.0146 F1200
G01 X526.1967 Y513.6003 F1200
G01 X526.7474 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X526.8155 Y513.9108 F1200
G02 X527.4768 Y513.6329 I-0.3332 J-1.7184 F1200
G02 X525.3808 Y510.7682 I-1.0054 J-1.4635 F1200
G02 X524.6983 Y512.0792 I1.0847 J1.3979 F1200
G01 X524.6960 Y512.1844 F1200
G02 X526.8155 Y513.9108 I1.7748 J-0.0147 F1200
G01 X526.7474 Y513.6003 F1200
G00 Z5.0000 F480
;No. 59: Hole 54
G00 X565.7290 Y510.9357 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X571.4130 F1200
G01 X572.6065 Y512.3667 F1200
G01 X564.5372 F1200
G01 X564.0588 Y513.7977 F1200
G01 X573.0839 F1200
G01 X573.0845 Y515.2287 F1200
G01 X564.0594 F1200
G01 X564.5365 Y516.6597 F1200
G01 X572.6062 F1200
G01 X571.4144 Y518.0907 F1200
G01 X565.7304 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X565.5292 Y518.3375 F1200
G02 X572.3970 Y517.5546 I3.0425 J-3.8253 F1200
G02 X571.6141 Y510.6868 I-3.8253 J-3.0425 F1200
G02 X564.7463 Y511.4696 I-3.0425 J3.8253 F1200
G02 X565.5292 Y518.3375 I3.8253 J3.0425 F1200
G01 X565.7304 Y518.0907 F1200
G00 Z5.0000 F480
;No. 60: Hole 133
G00 X568.2962 Y513.0822 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X568.8462 F1200
G01 X570.0287 Y514.5132 F1200
G01 X567.1149 F1200
G01 X568.2950 Y515.9442 F1200
G01 X568.8471 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X568.9153 Y516.2547 F1200
G02 X570.2225 Y515.1682 I-0.3433 J-1.7427 F1200
G02 X566.9022 Y513.9073 I-1.6508 J-0.6550 F1200
G02 X566.7967 Y514.4754 I1.6744 J0.6049 F1200
G01 X566.7976 Y514.5811 F1200
G02 X568.9153 Y516.2547 I1.7736 J-0.0676 F1200
G01 X568.8471 Y515.9442 F1200
G00 Z5.0000 F480
;No. 61: Hole 55
G00 X570.7384 Y543.3137 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X565.0538 F1200
G01 X563.8618 Y544.7447 F1200
G01 X571.9314 F1200
G01 X572.4088 Y546.1757 F1200
G01 X563.3837 F1200
G01 X563.3843 Y547.6067 F1200
G01 X572.4094 F1200
G01 X571.9313 Y549.0377 F1200
G01 X563.8616 F1200
G01 X565.0546 Y550.4687 F1200
G01 X570.7392 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X570.9408 Y550.7150 F1200
G02 X571.7209 Y543.8467 I-3.0442 J-3.8242 F1200
G02 X564.8525 Y543.0667 I-3.8242 J3.0442 F1200
G02 X564.0725 Y549.9350 I3.0442 J3.8242 F1200
G02 X570.9408 Y550.7150 I3.8242 J-3.0442 F1200
G01 X570.7392 Y550.4687 F1200
G00 Z5.0000 F480
;No. 62: Hole 134
G00 X568.1710 Y545.4602 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X567.6211 F1200
G01 X566.4398 Y546.8912 F1200
G01 X569.3535 F1200
G01 X568.1720 Y548.3222 F1200
G01 X567.6198 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X567.5664 Y548.6354 F1200
G02 X569.6545 Y547.1401 I0.3310 J-1.7434 F1200
G02 X566.1269 Y546.7476 I-1.7580 J-0.2487 F1200
G01 X566.1215 Y546.8534 F1200
G01 X566.1224 Y546.9591 F1200
G02 X567.5664 Y548.6354 I1.7734 J-0.0675 F1200
G01 X567.6198 Y548.3222 F1200
G00 Z5.0000 F480
;No. 63: Hole 57
G00 X648.2856 Y538.5237 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X653.9704 F1200
G01 X655.1637 Y539.9547 F1200
G01 X647.0954 F1200
G01 X646.6154 Y541.3857 F1200
G01 X655.6417 F1200
G01 X655.6429 Y542.8167 F1200
G01 X646.6167 F1200
G01 X647.0941 Y544.2477 F1200
G01 X655.1630 F1200
G01 X653.9728 Y545.6787 F1200
G01 X648.2876 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X648.0927 Y545.9301 F1200
G02 X654.9593 Y545.1367 I3.0366 J-3.8300 F1200
G02 X654.1659 Y538.2701 I-3.8300 J-3.0366 F1200
G02 X647.2993 Y539.0635 I-3.0366 J3.8300 F1200
G02 X648.0927 Y545.9301 I3.8300 J3.0366 F1200
G01 X648.2876 Y545.6787 F1200
G00 Z5.0000 F480
;No. 64: Hole 137
G00 X650.8541 Y540.6702 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X651.4050 F1200
G01 X652.5864 Y542.1012 F1200
G01 X649.6720 F1200
G01 X650.8514 Y543.5322 F1200
G01 X651.4036 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X651.4709 Y543.8429 F1200
G02 X652.3358 Y543.4039 I-0.3332 J-1.7282 F1200
G02 X649.8474 Y540.8727 I-1.2067 J-1.3025 F1200
G02 X649.3542 Y542.0569 I1.2749 J1.2257 F1200
G01 X649.3549 Y542.1628 F1200
G02 X651.4709 Y543.8429 I1.7742 J-0.0620 F1200
G01 X651.4036 Y543.5322 F1200
G00 Z5.0000 F480
;No. 65: Hole 135
G00 X649.4586 Y508.3442 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X648.9077 F1200
G01 X647.7255 Y509.7752 F1200
G01 X650.6400 F1200
G01 X649.4572 Y511.2062 F1200
G01 X648.9050 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X648.8458 Y511.5186 F1200
G01 X648.8761 Y511.5243 F1200
G02 X649.3852 Y508.0110 I0.3066 J-1.7491 F1200
G02 X647.4099 Y509.6780 I-0.2021 J1.7644 F1200
G01 X647.4074 Y509.7838 F1200
G02 X648.8458 Y511.5186 I1.7748 J-0.0078 F1200
G01 X648.9050 Y511.2062 F1200
G00 Z5.0000 F480
;No. 66: Hole 56
G00 X646.3392 Y506.1977 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X652.0242 F1200
G01 X653.2178 Y507.6287 F1200
G01 X645.1486 F1200
G01 X644.6696 Y509.0597 F1200
G01 X653.6948 F1200
G01 X653.6960 Y510.4907 F1200
G01 X644.6709 F1200
G01 X645.1477 Y511.9217 F1200
G01 X653.2169 F1200
G01 X652.0264 Y513.3527 F1200
G01 X646.3410 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X646.1424 Y513.6005 F1200
G02 X653.0098 Y512.8149 I3.0409 J-3.8265 F1200
G02 X652.2243 Y505.9475 I-3.8265 J-3.0409 F1200
G02 X645.3569 Y506.7331 I-3.0409 J3.8265 F1200
G02 X646.1424 Y513.6005 I3.8265 J3.0409 F1200
G01 X646.3410 Y513.3527 F1200
G00 Z5.0000 F480
;No. 67: Hole 58
G00 X688.3345 Y502.4159 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X694.0202 F1200
G01 X695.2125 Y503.8469 F1200
G01 X687.1446 F1200
G01 X686.6645 Y505.2779 F1200
G01 X695.6909 F1200
G01 X695.6919 Y506.7089 F1200
G01 X686.6658 F1200
G01 X687.1443 Y508.1399 F1200
G01 X695.2122 F1200
G01 X694.0231 Y509.5709 F1200
G01 X688.3367 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X688.1375 Y509.8188 F1200
G02 X695.0051 Y509.0346 I3.0416 J-3.8259 F1200
G02 X694.2208 Y502.1670 I-3.8259 J-3.0416 F1200
G02 X687.3532 Y502.9513 I-3.0416 J3.8259 F1200
G02 X688.1375 Y509.8188 I3.8259 J3.0416 F1200
G01 X688.3367 Y509.5709 F1200
G00 Z5.0000 F480
;No. 68: Hole 136
G00 X690.9039 Y504.5624 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X691.4547 F1200
G01 X692.6353 Y505.9934 F1200
G01 X689.7210 F1200
G01 X690.9001 Y507.4244 F1200
G01 X691.4508 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X691.5182 Y507.7355 F1200
G01 X691.6053 Y507.7166 F1200
G02 X690.7001 Y504.2837 I-0.4269 J-1.7233 F1200
G02 X689.4053 Y505.8959 I0.4788 J1.7105 F1200
G01 X689.4028 Y506.0015 F1200
G02 X691.5182 Y507.7355 I1.7749 J-0.0080 F1200
G01 X691.4508 Y507.4244 F1200
G00 Z5.0000 F480
;No. 69: Hole 125
G00 X684.5924 Y451.6939 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X683.3332 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X683.0156 Y451.6981 F1200
G01 X683.0166 Y451.7722 F1200
G02 X683.0720 Y452.0237 I0.9346 J-0.0742 F1200
G02 X684.8333 Y451.3138 I0.8908 J-0.3298 F1200
G02 X683.0148 Y451.6416 I-0.8704 J0.3796 F1200
G01 X683.3332 Y451.6939 F1200
G00 Z5.0000 F480
;No. 70: Hole 50
G00 X682.5941 Y448.8319 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X685.3325 F1200
G01 X686.7940 Y450.2629 F1200
G01 X681.1314 F1200
G01 X680.7915 Y451.6939 F1200
G01 X687.1341 F1200
G01 X686.7943 Y453.1249 F1200
G01 X681.1317 F1200
G01 X682.5932 Y454.5559 F1200
G01 X685.3327 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X685.4751 Y454.8400 F1200
G02 X687.1095 Y450.1822 I-1.5117 J-3.1461 F1200
G02 X682.4517 Y448.5478 I-3.1461 J1.5117 F1200
G02 X680.8173 Y453.2057 I1.5117 J3.1461 F1200
G02 X685.4751 Y454.8400 I3.1461 J-1.5117 F1200
G01 X685.3327 Y454.5559 F1200
G00 Z5.0000 F480
;No. 71: Hole 124
G00 X685.3213 Y423.4811 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X684.0619 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X683.7441 Y423.4875 F1200
G01 X683.7455 Y423.5594 F1200
G02 X683.8010 Y423.8109 I0.9346 J-0.0742 F1200
G02 X685.5540 Y423.0828 I0.8908 J-0.3297 F1200
G02 X683.7431 Y423.4422 I-0.8622 J0.3978 F1200
G01 X684.0619 Y423.4811 F1200
G00 Z5.0000 F480
;No. 72: Hole 49
G00 X683.3219 Y420.6191 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X686.0611 F1200
G01 X687.5232 Y422.0501 F1200
G01 X681.8603 F1200
G01 X681.5205 Y423.4811 F1200
G01 X687.8630 F1200
G01 X687.5232 Y424.9121 F1200
G01 X681.8603 F1200
G01 X683.3224 Y426.3431 F1200
G01 X686.0605 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X686.2031 Y426.6277 F1200
G02 X687.8390 Y421.9703 I-1.5108 J-3.1467 F1200
G02 X683.1816 Y420.3344 I-3.1467 J1.5108 F1200
G02 X681.5457 Y424.9918 I1.5108 J3.1467 F1200
G02 X686.2031 Y426.6277 I3.1467 J-1.5108 F1200
G01 X686.0605 Y426.3431 F1200
G00 Z5.0000 F480
;No. 73: Hole 123
G00 X685.9248 Y374.6424 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X687.1846 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X687.5028 Y374.6415 F1200
G02 X685.6072 Y374.5809 I-0.9488 J0.0003 F1200
G01 X685.6067 Y374.6946 F1200
G02 X687.5028 Y374.6415 I0.9474 J-0.0516 F1200
G01 X687.1846 Y374.6424 F1200
G00 Z5.0000 F480
;No. 74: Hole 48
G00 X687.9236 Y371.7804 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X685.1861 F1200
G01 X683.7226 Y373.2114 F1200
G01 X689.3858 F1200
G01 X689.7265 Y374.6424 F1200
G01 X683.3829 F1200
G01 X683.7232 Y376.0734 F1200
G01 X689.3861 F1200
G01 X687.9237 Y377.5044 F1200
G01 X685.1846 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X685.0525 Y377.7936 F1200
G02 X689.7055 Y376.1451 I1.5023 J-3.1508 F1200
G02 X688.0570 Y371.4921 I-3.1508 J-1.5023 F1200
G02 X683.4040 Y373.1406 I-1.5023 J3.1508 F1200
G02 X685.0525 Y377.7936 I3.1508 J1.5023 F1200
G01 X685.1846 Y377.5044 F1200
G00 Z5.0000 F480
;No. 75: Hole 122
G00 X686.9295 Y346.4380 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X688.1893 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X688.5076 Y346.4372 F1200
G02 X686.6119 Y346.3765 I-0.9488 J0.0003 F1200
G01 X686.6114 Y346.4903 F1200
G02 X688.5076 Y346.4372 I0.9474 J-0.0516 F1200
G01 X688.1893 Y346.4380 F1200
G00 Z5.0000 F480
;No. 76: Hole 47
G00 X688.9284 Y343.5760 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X686.1899 F1200
G01 X684.7280 Y345.0070 F1200
G01 X690.3910 F1200
G01 X690.7313 Y346.4380 F1200
G01 X684.3876 F1200
G01 X684.7283 Y347.8690 F1200
G01 X690.3908 F1200
G01 X688.9285 Y349.3000 F1200
G01 X686.1894 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X686.0518 Y349.5861 F1200
G02 X690.7075 Y347.9460 I1.5078 J-3.1479 F1200
G02 X689.0673 Y343.2903 I-3.1479 J-1.5078 F1200
G02 X684.4117 Y344.9304 I-1.5078 J3.1479 F1200
G02 X686.0518 Y349.5861 I3.1479 J1.5078 F1200
G01 X686.1894 Y349.3000 F1200
G00 Z5.0000 F480
;No. 77: Hole 120
G00 X630.1577 Y357.6574 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X628.8965 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X628.5790 Y357.6749 F1200
G02 X628.6484 Y358.0180 I0.9190 J-0.0072 F1200
G02 X630.3749 Y357.2294 I0.8787 J-0.3605 F1200
G02 X628.5778 Y357.6517 I-0.8477 J0.4276 F1200
G01 X628.8965 Y357.6574 F1200
G00 Z5.0000 F480
;No. 78: Hole 44
G00 X628.1582 Y354.7954 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X630.8968 F1200
G01 X632.3586 Y356.2264 F1200
G01 X626.6961 F1200
G01 X626.3557 Y357.6574 F1200
G01 X632.6985 F1200
G01 X632.3584 Y359.0884 F1200
G01 X626.6955 F1200
G01 X628.1574 Y360.5194 F1200
G01 X630.8968 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X631.0378 Y360.8041 F1200
G02 X632.6743 Y356.1473 I-1.5102 J-3.1467 F1200
G02 X628.0174 Y354.5108 I-3.1467 J1.5102 F1200
G02 X626.3810 Y359.1676 I1.5102 J3.1467 F1200
G02 X631.0378 Y360.8041 I3.1467 J-1.5102 F1200
G01 X630.8968 Y360.5194 F1200
G00 Z5.0000 F480
;No. 79: Hole 45
G00 X631.1518 Y383.0165 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X628.4124 F1200
G01 X626.9511 Y384.4475 F1200
G01 X632.6133 F1200
G01 X632.9537 Y385.8785 F1200
G01 X626.6105 F1200
G01 X626.9509 Y387.3095 F1200
G01 X632.6134 F1200
G01 X631.1518 Y388.7405 F1200
G01 X628.4124 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X628.2705 Y389.0248 F1200
G02 X632.9279 Y387.3898 I1.5112 J-3.1462 F1200
G02 X631.2929 Y382.7325 I-3.1462 J-1.5112 F1200
G02 X626.6355 Y384.3675 I-1.5112 J3.1462 F1200
G02 X628.2705 Y389.0248 I3.1462 J1.5112 F1200
G01 X628.4124 Y388.7405 F1200
G00 Z5.0000 F480
;No. 80: Hole 121
G00 X629.1515 Y385.8785 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X630.4127 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X630.7296 Y385.8631 F1200
G02 X628.8329 Y385.8593 I-0.9484 J0.0144 F1200
G01 X628.8392 Y385.9897 F1200
G02 X630.7296 Y385.8631 I0.9421 J-0.1097 F1200
G01 X630.4127 Y385.8785 F1200
G00 Z5.0000 F480
;No. 81: Hole 51
G00 X626.1659 Y428.4066 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X623.4266 F1200
G01 X621.9649 Y429.8376 F1200
G01 X627.6277 F1200
G01 X627.9674 Y431.2686 F1200
G01 X621.6250 F1200
G01 X621.9647 Y432.6996 F1200
G01 X627.6273 F1200
G01 X626.1654 Y434.1306 F1200
G01 X623.4275 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X623.2860 Y434.4156 F1200
G02 X627.9426 Y432.7783 I1.5096 J-3.1470 F1200
G02 X626.3053 Y428.1217 I-3.1470 J-1.5096 F1200
G02 X621.6487 Y429.7590 I-1.5096 J3.1470 F1200
G02 X623.2860 Y434.4156 I3.1470 J1.5096 F1200
G01 X623.4275 Y434.1306 F1200
G00 Z5.0000 F480
;No. 82: Hole 126
G00 X624.1664 Y431.2686 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X625.4260 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X625.7443 Y431.2591 F1200
G02 X623.8471 Y431.2463 I-0.9487 J0.0087 F1200
G01 X623.8501 Y431.3466 F1200
G02 X625.7443 Y431.2591 I0.9456 J-0.0768 F1200
G01 X625.4260 Y431.2686 F1200
G00 Z5.0000 F480
;No. 83: Hole 52
G00 X625.9287 Y456.6278 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X623.1897 F1200
G01 X621.7274 Y458.0588 F1200
G01 X627.3904 F1200
G01 X627.7301 Y459.4898 F1200
G01 X621.3877 F1200
G01 X621.7274 Y460.9208 F1200
G01 X627.3901 F1200
G01 X625.9281 Y462.3518 F1200
G01 X623.1902 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X623.0488 Y462.6368 F1200
G02 X627.7054 Y460.9994 I1.5096 J-3.1470 F1200
G02 X626.0680 Y456.3428 I-3.1470 J-1.5096 F1200
G02 X621.4114 Y457.9802 I-1.5096 J3.1470 F1200
G02 X623.0488 Y462.6368 I3.1470 J1.5096 F1200
G01 X623.1902 Y462.3518 F1200
G00 Z5.0000 F480
;No. 84: Hole 127
G00 X623.9287 Y459.4898 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X625.1887 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X625.5071 Y459.4803 F1200
G02 X623.6099 Y459.4675 I-0.9487 J0.0087 F1200
G01 X623.6129 Y459.5678 F1200
G02 X625.5071 Y459.4803 I0.9456 J-0.0768 F1200
G01 X625.1887 Y459.4898 F1200
G00 Z5.0000 F480
;No. 85: Hole 128
G00 X567.7334 Y451.7822 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X566.4727 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X566.1548 Y451.7924 F1200
G01 X566.1571 Y451.8624 F1200
G02 X567.0128 Y452.7275 I0.9459 J-0.0798 F1200
G02 X567.1233 Y450.8329 I0.0900 J-0.9453 F1200
G02 X566.1538 Y451.7620 I-0.0203 J0.9491 F1200
G01 X566.4727 Y451.7822 F1200
G00 Z5.0000 F480
;No. 86: Hole 40
G00 X565.7341 Y448.9202 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X568.4725 F1200
G01 X569.9342 Y450.3512 F1200
G01 X564.2717 F1200
G01 X563.9316 Y451.7822 F1200
G01 X570.2745 F1200
G01 X569.9344 Y453.2132 F1200
G01 X564.2718 F1200
G01 X565.7336 Y454.6442 F1200
G01 X568.4720 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X568.6146 Y454.9289 F1200
G02 X570.2497 Y450.2712 I-1.5113 J-3.1464 F1200
G02 X565.5920 Y448.6361 I-3.1464 J1.5113 F1200
G02 X563.9569 Y453.2938 I1.5113 J3.1464 F1200
G02 X568.6146 Y454.9289 I3.1464 J-1.5113 F1200
G01 X568.4720 Y454.6442 F1200
G00 Z5.0000 F480
;No. 87: Hole 129
G00 X567.9068 Y423.5605 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X566.6463 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X566.3285 Y423.5707 F1200
G01 X566.3308 Y423.6407 F1200
G02 X567.6239 Y424.4448 I0.9463 J-0.0799 F1200
G02 X566.8797 Y422.6975 I-0.3473 J-0.8842 F1200
G02 X566.3275 Y423.5404 I0.3974 J0.8627 F1200
G01 X566.6463 Y423.5605 F1200
G00 Z5.0000 F480
;No. 88: Hole 41
G00 X565.9078 Y420.6985 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X568.6459 F1200
G01 X570.1082 Y422.1295 F1200
G01 X564.4454 F1200
G01 X564.1053 Y423.5605 F1200
G01 X570.4482 F1200
G01 X570.1081 Y424.9915 F1200
G01 X564.4452 F1200
G01 X565.9076 Y426.4225 F1200
G01 X568.6465 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X568.7831 Y426.7092 F1200
G02 X570.4255 Y422.0543 I-1.5063 J-3.1486 F1200
G02 X565.7706 Y420.4119 I-3.1486 J1.5063 F1200
G02 X564.1283 Y425.0668 I1.5063 J3.1486 F1200
G02 X568.7831 Y426.7092 I3.1486 J-1.5063 F1200
G01 X568.6465 Y426.4225 F1200
G00 Z5.0000 F480
;No. 89: Hole 118
G00 X570.7101 Y382.2537 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X571.9707 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X572.2887 Y382.2407 F1200
G02 X570.3911 Y382.2417 I-0.9488 J0.0123 F1200
G01 X570.3952 Y382.3421 F1200
G02 X572.2887 Y382.2407 I0.9448 J-0.0873 F1200
G01 X571.9707 Y382.2537 F1200
G00 Z5.0000 F480
;No. 90: Hole 42
G00 X572.7105 Y379.3917 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X569.9707 F1200
G01 X568.5093 Y380.8227 F1200
G01 X574.1721 F1200
G01 X574.5123 Y382.2537 F1200
G01 X568.1685 F1200
G01 X568.5087 Y383.6847 F1200
G01 X574.1722 F1200
G01 X572.7105 Y385.1157 F1200
G01 X569.9705 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X569.8325 Y385.4016 F1200
G02 X574.4880 Y383.7611 I1.5075 J-3.1480 F1200
G02 X572.8475 Y379.1055 I-3.1480 J-1.5075 F1200
G02 X568.1919 Y380.7461 I-1.5075 J3.1480 F1200
G02 X569.8325 Y385.4016 I3.1480 J1.5075 F1200
G01 X569.9705 Y385.1157 F1200
G00 Z5.0000 F480
;No. 91: Hole 119
G00 X570.6390 Y354.0316 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X571.8993 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X572.2166 Y354.0183 F1200
G02 X570.3201 Y354.0062 I-0.9484 J0.0122 F1200
G01 X570.3255 Y354.1368 F1200
G02 X572.2166 Y354.0183 I0.9428 J-0.1037 F1200
G01 X571.8993 Y354.0316 F1200
G00 Z5.0000 F480
;No. 92: Hole 43
G00 X572.6391 Y351.1696 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X569.8991 F1200
G01 X568.4380 Y352.6006 F1200
G01 X574.1004 F1200
G01 X574.4410 Y354.0316 F1200
G01 X568.0973 F1200
G01 X568.4380 Y355.4626 F1200
G01 X574.1010 F1200
G01 X572.6392 Y356.8936 F1200
G01 X569.8992 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X569.7667 Y357.1826 F1200
G02 X574.4196 Y355.5341 I1.5022 J-3.1507 F1200
G02 X572.7711 Y350.8812 I-3.1507 J-1.5022 F1200
G02 X568.1182 Y352.5297 I-1.5022 J3.1507 F1200
G02 X569.7667 Y357.1826 I3.1507 J1.5022 F1200
G01 X569.8992 Y356.8936 F1200
G00 Z5.0000 F480
;No. 93: Hole 114
G00 X546.9858 Y268.2499 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X546.4361 F1200
G01 X545.2555 Y269.6809 F1200
G01 X548.1689 F1200
G01 X546.9887 Y271.1119 F1200
G01 X546.4400 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X546.3777 Y271.4236 F1200
G01 X546.4146 Y271.4310 F1200
G02 X546.9051 Y267.9162 I0.2977 J-1.7501 F1200
G02 X544.9393 Y269.5933 I-0.1924 J1.7652 F1200
G01 X544.9372 Y269.6988 F1200
G02 X546.3777 Y271.4236 I1.7749 J-0.0183 F1200
G01 X546.4400 Y271.1119 F1200
G00 Z5.0000 F480
;No. 94: Hole 29
G00 X543.8712 Y266.1034 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X549.5536 F1200
G01 X550.7461 Y267.5344 F1200
G01 X542.6781 F1200
G01 X542.2000 Y268.9654 F1200
G01 X551.2243 F1200
G01 X551.2246 Y270.3964 F1200
G01 X542.1998 F1200
G01 X542.6786 Y271.8274 F1200
G01 X550.7466 F1200
G01 X549.5542 Y273.2584 F1200
G01 X543.8710 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X543.6720 Y273.5064 F1200
G02 X550.5386 Y272.7199 I3.0400 J-3.8266 F1200
G02 X549.7520 Y265.8532 I-3.8266 J-3.0400 F1200
G02 X542.8854 Y266.6398 I-3.0400 J3.8266 F1200
G02 X543.6720 Y273.5064 I3.8266 J3.0400 F1200
G01 X543.8710 Y273.2584 F1200
G00 Z5.0000 F480
;No. 95: Hole 30
G00 X631.7853 Y262.2718 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X637.4690 F1200
G01 X638.6607 Y263.7028 F1200
G01 X630.5927 F1200
G01 X630.1147 Y265.1338 F1200
G01 X639.1393 F1200
G01 X639.1388 Y266.5648 F1200
G01 X630.1150 F1200
G01 X630.5932 Y267.9958 F1200
G01 X638.6617 F1200
G01 X637.4687 Y269.4268 F1200
G01 X631.7850 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X631.5854 Y269.6740 F1200
G02 X638.4523 Y268.8894 I3.0412 J-3.8257 F1200
G02 X637.6678 Y262.0226 I-3.8257 J-3.0412 F1200
G02 X630.8009 Y262.8071 I-3.0412 J3.8257 F1200
G02 X631.5854 Y269.6740 I3.8257 J3.0412 F1200
G01 X631.7850 Y269.4268 F1200
G00 Z5.0000 F480
;No. 96: Hole 115
G00 X634.3539 Y264.4183 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X634.8993 F1200
G01 X636.0837 Y265.8493 F1200
G01 X633.1703 F1200
G01 X634.3546 Y267.2803 F1200
G01 X634.9033 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X634.9533 Y267.5943 F1200
G02 X635.3128 Y267.4875 I-0.3145 J-1.7160 F1200
G02 X633.8456 Y264.2545 I-0.6860 J-1.6381 F1200
G02 X632.8521 Y265.8142 I0.7803 J1.5933 F1200
G01 X632.8532 Y265.9202 F1200
G02 X634.9533 Y267.5943 I1.7734 J-0.0703 F1200
G01 X634.9033 Y267.2803 F1200
G00 Z5.0000 F480
;No. 97: Hole 93
G00 X563.8103 Y147.9350 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X563.2678 F1200
G01 X562.0781 Y149.3660 F1200
G01 X564.9916 F1200
G01 X563.8067 Y150.7970 F1200
G01 X563.2565 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X563.2046 Y151.1106 F1200
G02 X564.4548 Y150.8850 I0.3297 J-1.7498 F1200
G02 X562.5267 Y147.9041 I-0.9200 J-1.5189 F1200
G02 X561.7598 Y149.3365 I1.0093 J1.4620 F1200
G01 X561.7613 Y149.4425 F1200
G02 X563.2046 Y151.1106 I1.7743 J-0.0767 F1200
G01 X563.2565 Y150.7970 F1200
G00 Z5.0000 F480
;No. 98: Hole 12
G00 X560.6923 Y145.7885 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X566.3751 F1200
G01 X567.5690 Y147.2195 F1200
G01 X559.5022 F1200
G01 X559.0217 Y148.6505 F1200
G01 X568.0455 F1200
G01 X568.0480 Y150.0815 F1200
G01 X559.0235 F1200
G01 X559.5007 Y151.5125 F1200
G01 X567.5675 F1200
G01 X566.3770 Y152.9435 F1200
G01 X560.6945 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X560.4980 Y153.1934 F1200
G01 X560.5739 Y153.2531 F1200
G02 X566.3719 Y145.3875 I2.9609 J-3.8871 F1200
G02 X558.6480 Y149.3301 I-2.8387 J3.9760 F1200
G01 X558.6492 Y149.4686 F1200
G02 X560.4980 Y153.1934 I4.8693 J-0.0957 F1200
G01 X560.6945 Y152.9435 F1200
G00 Z5.0000 F480
;No. 99: Hole 92
G00 X544.4188 Y107.3848 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X543.8714 F1200
G01 X542.6865 Y108.8158 F1200
G01 X545.6001 F1200
G01 X544.4152 Y110.2468 F1200
G01 X543.8650 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X543.8131 Y110.5604 F1200
G01 X543.9044 Y110.5755 F1200
G02 X544.2779 Y107.0451 I0.2386 J-1.7597 F1200
G02 X542.3698 Y108.7336 I-0.1341 J1.7708 F1200
G01 X542.3683 Y108.8392 F1200
G02 X543.8131 Y110.5604 I1.7757 J-0.0236 F1200
G01 X543.8650 Y110.2468 F1200
G00 Z5.0000 F480
;No. 100: Hole 11
G00 X549.4655 Y61.8119 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X555.1480 F1200
G01 X556.3415 Y63.2429 F1200
G01 X548.2749 F1200
G01 X547.7944 Y64.6739 F1200
G01 X556.8189 F1200
G01 X556.8207 Y66.1049 F1200
G01 X547.7964 F1200
G01 X548.2732 Y67.5359 F1200
G01 X556.3404 F1200
G01 X555.1493 Y68.9669 F1200
G01 X549.4673 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X549.2703 Y69.2167 F1200
G01 X549.3345 Y69.2673 F1200
G02 X555.1570 Y61.4198 I2.9731 J-3.8779 F1200
G02 X547.4208 Y65.3385 I-2.8511 J3.9671 F1200
G01 X547.4219 Y65.4921 F1200
G02 X549.2703 Y69.2167 I4.8698 J-0.0958 F1200
G01 X549.4673 Y68.9669 F1200
G00 Z5.0000 F480
;No. 101: Hole 91
G00 X552.0356 Y63.9584 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X552.5830 F1200
G01 X553.7643 Y65.3894 F1200
G01 X550.8505 F1200
G01 X552.0321 Y66.8204 F1200
G01 X552.5794 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X552.6307 Y67.1340 F1200
G02 X553.1822 Y66.9350 I-0.3017 J-1.6999 F1200
G02 X551.3431 Y63.8983 I-0.8747 J-1.5455 F1200
G02 X550.5325 Y65.3600 I0.9663 J1.4916 F1200
G01 Y65.4129 F1200
G02 X552.6307 Y67.1340 I1.7737 J-0.0228 F1200
G01 X552.5794 Y66.8204 F1200
G00 Z5.0000 F480
;No. 102: Hole 90
G00 X474.9369 Y134.7085 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X474.3889 F1200
G01 X473.2038 Y136.1395 F1200
G01 X476.1184 F1200
G01 X474.9338 Y137.5705 F1200
G01 X474.3853 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X474.3281 Y137.8832 F1200
G02 X476.4048 Y136.4722 I0.3328 J-1.7439 F1200
G02 X474.9938 Y134.3955 I-1.7439 J-0.3328 F1200
G02 X472.9171 Y135.8065 I-0.3328 J1.7439 F1200
G02 X474.3281 Y137.8832 I1.7439 J0.3328 F1200
G01 X474.3853 Y137.5705 F1200
G00 Z5.0000 F480
;No. 103: Hole 88
G00 X401.6249 Y119.4468 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X401.0769 F1200
G01 X399.8918 Y120.8778 F1200
G01 X402.8064 F1200
G01 X401.6218 Y122.3088 F1200
G01 X401.0733 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X401.0161 Y122.6215 F1200
G02 X403.0928 Y121.2105 I0.3328 J-1.7439 F1200
G02 X401.6818 Y119.1338 I-1.7439 J-0.3328 F1200
G02 X399.6051 Y120.5448 I-0.3328 J1.7439 F1200
G02 X401.0161 Y122.6215 I1.7439 J0.3328 F1200
G01 X401.0733 Y122.3088 F1200
G00 Z5.0000 F480
;No. 104: Hole 10
G00 X398.5059 Y117.3003 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X404.1911 F1200
G01 X405.3828 Y118.7313 F1200
G01 X397.3170 F1200
G01 X396.8361 Y120.1623 F1200
G01 X405.8608 F1200
G01 X405.8622 Y121.5933 F1200
G01 X396.8375 F1200
G01 X397.3153 Y123.0243 F1200
G01 X405.3815 F1200
G01 X404.1921 Y124.4553 F1200
G01 X398.5070 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X398.3121 Y124.7065 F1200
G02 X405.1783 Y123.9156 I3.0376 J-3.8285 F1200
G02 X404.3874 Y117.0494 I-3.8285 J-3.0376 F1200
G02 X397.5212 Y117.8404 I-3.0376 J3.8285 F1200
G02 X398.3121 Y124.7065 I3.8285 J3.0376 F1200
G01 X398.5070 Y124.4553 F1200
G00 Z5.0000 F480
;No. 105: Hole 87
G00 X362.4361 Y122.2716 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X361.8865 F1200
G01 X360.7019 Y123.7026 F1200
G01 X363.6160 F1200
G01 X362.4319 Y125.1336 F1200
G01 X361.8822 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X361.8157 Y125.4445 F1200
G02 X362.0477 Y125.4749 I0.3300 J-1.6174 F1200
G02 X362.1654 Y121.9270 I0.1113 J-1.7722 F1200
G02 X360.3837 Y123.6966 I-0.0064 J1.7754 F1200
G01 X360.3866 Y123.8022 F1200
G02 X361.8157 Y125.4445 I1.7707 J-0.0979 F1200
G01 X361.8822 Y125.1336 F1200
G00 Z5.0000 F480
;No. 106: Hole 9
G00 X359.3162 Y120.1251 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X365.0013 F1200
G01 X366.1923 Y121.5561 F1200
G01 X358.1269 F1200
G01 X357.6461 Y122.9871 F1200
G01 X366.6713 F1200
G01 X366.6727 Y124.4181 F1200
G01 X357.6470 F1200
G01 X358.1260 Y125.8491 F1200
G01 X366.1913 F1200
G01 X365.0021 Y127.2801 F1200
G01 X359.3172 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X359.1185 Y127.5283 F1200
G02 X365.9853 Y126.7444 I3.0415 J-3.8253 F1200
G02 X365.2015 Y119.8776 I-3.8253 J-3.0415 F1200
G02 X358.3347 Y120.6614 I-3.0415 J3.8253 F1200
G02 X359.1185 Y127.5283 I3.8253 J3.0415 F1200
G01 X359.3172 Y127.2801 F1200
G00 Z5.0000 F480
;No. 107: Hole 15
G00 X358.3497 Y177.1349 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X364.0363 F1200
G01 X365.2277 Y178.5659 F1200
G01 X357.1605 F1200
G01 X356.6799 Y179.9969 F1200
G01 X365.7060 F1200
G01 X365.7073 Y181.4279 F1200
G01 X356.6813 F1200
G01 X357.1597 Y182.8589 F1200
G01 X365.2271 F1200
G01 X364.0378 Y184.2899 F1200
G01 X358.3520 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X358.1549 Y184.5394 F1200
G02 X365.0218 Y183.7520 I3.0398 J-3.8272 F1200
G02 X364.2344 Y176.8850 I-3.8272 J-3.0398 F1200
G02 X357.3675 Y177.6725 I-3.0398 J3.8272 F1200
G02 X358.1549 Y184.5394 I3.8272 J3.0398 F1200
G01 X358.3520 Y184.2899 F1200
G00 Z5.0000 F480
;No. 108: Hole 96
G00 X360.9183 Y179.2814 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X361.4723 F1200
G01 X362.6508 Y180.7124 F1200
G01 X359.7366 F1200
G01 X360.9179 Y182.1434 F1200
G01 X361.4661 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X361.5267 Y182.4554 F1200
G01 X361.5834 Y182.4444 F1200
G02 X360.7015 Y179.0066 I-0.3896 J-1.7321 F1200
G02 X359.4200 Y180.6295 I0.4926 J1.7064 F1200
G01 X359.4183 Y180.7350 F1200
G02 X361.5267 Y182.4554 I1.7743 J-0.0223 F1200
G01 X361.4661 Y182.1434 F1200
G00 Z5.0000 F480
;No. 109: Hole 14
G00 X399.9959 Y170.5372 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X405.6830 F1200
G01 X406.8735 Y171.9682 F1200
G01 X398.8069 F1200
G01 X398.3262 Y173.3992 F1200
G01 X407.3526 F1200
G01 X407.3541 Y174.8302 F1200
G01 X398.3277 F1200
G01 X398.8058 Y176.2612 F1200
G01 X406.8729 F1200
G01 X405.6842 Y177.6922 F1200
G01 X399.9973 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X399.7986 Y177.9404 F1200
G02 X406.6663 Y177.1572 I3.0423 J-3.8254 F1200
G02 X405.8831 Y170.2896 I-3.8254 J-3.0423 F1200
G02 X399.0155 Y171.0727 I-3.0423 J3.8254 F1200
G02 X399.7986 Y177.9404 I3.8254 J3.0423 F1200
G01 X399.9973 Y177.6922 F1200
G00 Z5.0000 F480
;No. 110: Hole 94
G00 X402.5644 Y172.6837 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X403.1158 F1200
G01 X404.2972 Y174.1147 F1200
G01 X401.3826 F1200
G01 X402.5640 Y175.5457 F1200
G01 X403.1154 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X403.1668 Y175.8594 F1200
G01 X403.1777 Y175.8576 F1200
G02 X402.3990 Y172.3949 I-0.3378 J-1.7429 F1200
G02 X401.0660 Y174.0318 I0.4403 J1.7198 F1200
G01 X401.0643 Y174.1371 F1200
G02 X403.1668 Y175.8594 I1.7750 J-0.0224 F1200
G01 X403.1154 Y175.5457 F1200
G00 Z5.0000 F480
;No. 111: Hole 13
G00 X406.1720 Y202.3279 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X411.8591 F1200
G01 X413.0496 Y203.7589 F1200
G01 X404.9836 F1200
G01 X404.5019 Y205.1899 F1200
G01 X413.5288 F1200
G01 X413.5298 Y206.6209 F1200
G01 X404.5034 F1200
G01 X404.9825 Y208.0519 F1200
G01 X413.0486 F1200
G01 X411.8601 Y209.4829 F1200
G01 X406.1736 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X405.9757 Y209.7317 F1200
G02 X412.8431 Y208.9470 I3.0414 J-3.8261 F1200
G02 X412.0584 Y202.0796 I-3.8261 J-3.0414 F1200
G02 X405.1910 Y202.8642 I-3.0414 J3.8261 F1200
G02 X405.9757 Y209.7317 I3.8261 J3.0414 F1200
G01 X406.1736 Y209.4829 F1200
G00 Z5.0000 F480
;No. 112: Hole 95
G00 X408.7437 Y204.4744 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X409.2948 F1200
G01 X410.4733 Y205.9054 F1200
G01 X407.5588 F1200
G01 X408.7402 Y207.3364 F1200
G01 X409.2916 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X409.3429 Y207.6501 F1200
G02 X410.1558 Y207.2674 I-0.3258 J-1.7467 F1200
G02 X407.7980 Y204.6129 I-1.1397 J-1.3621 F1200
G02 X407.2421 Y205.8224 I1.2245 J1.2953 F1200
G01 X407.2405 Y205.9278 F1200
G02 X409.3429 Y207.6501 I1.7750 J-0.0224 F1200
G01 X409.2916 Y207.3364 F1200
G00 Z5.0000 F480
;No. 113: Hole 89
G00 X446.0584 Y51.3956 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X446.6076 F1200
G01 X447.7875 Y52.8266 F1200
G01 X444.8733 F1200
G01 X446.0549 Y54.2576 F1200
G01 X446.6033 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X446.6681 Y54.5688 F1200
G02 X445.9690 Y51.0886 I-0.3372 J-1.7426 F1200
G02 X444.5552 Y52.8206 I0.3620 J1.7385 F1200
G01 X444.5581 Y52.9261 F1200
G02 X446.6681 Y54.5688 I1.7715 J-0.0990 F1200
G01 X446.6033 Y54.2576 F1200
G00 Z5.0000 F480
;No. 114: Hole 86
G00 X339.3299 Y35.9806 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X338.7809 F1200
G01 X337.5968 Y37.4116 F1200
G01 X340.5112 F1200
G01 X339.3270 Y38.8426 F1200
G01 X338.7776 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X338.7136 Y39.1539 F1200
G02 X340.7966 Y37.7521 I0.3406 J-1.7424 F1200
G02 X339.3948 Y35.6691 I-1.7424 J-0.3406 F1200
G02 X337.3118 Y37.0709 I-0.3406 J1.7424 F1200
G02 X338.7136 Y39.1539 I1.7424 J0.3406 F1200
G01 X338.7776 Y38.8426 F1200
G00 Z5.0000 F480
;No. 115: Hole 8
G00 X336.2121 Y33.8341 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X341.8954 F1200
G01 X343.0890 Y35.2651 F1200
G01 X335.0207 F1200
G01 X334.5400 Y36.6961 F1200
G01 X343.5660 F1200
G01 X343.5679 Y38.1271 F1200
G01 X334.5414 F1200
G01 X335.0196 Y39.5581 F1200
G01 X343.0872 F1200
G01 X341.8958 Y40.9891 F1200
G01 X336.2130 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X336.0141 Y41.2373 F1200
G02 X342.8816 Y40.4510 I3.0406 J-3.8269 F1200
G02 X342.0953 Y33.5836 I-3.8269 J-3.0406 F1200
G02 X335.2279 Y34.3698 I-3.0406 J3.8269 F1200
G02 X336.0141 Y41.2373 I3.8269 J3.0406 F1200
G01 X336.2130 Y40.9891 F1200
G00 Z5.0000 F480
;No. 116: Hole 85
G00 X311.2327 Y38.6335 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X310.6836 F1200
G01 X309.4995 Y40.0645 F1200
G01 X312.4140 F1200
G01 X311.2298 Y41.4955 F1200
G01 X310.6803 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X310.6164 Y41.8068 F1200
G02 X312.6994 Y40.4050 I0.3406 J-1.7424 F1200
G02 X311.2975 Y38.3220 I-1.7424 J-0.3406 F1200
G02 X309.2145 Y39.7238 I-0.3406 J1.7424 F1200
G02 X310.6164 Y41.8068 I1.7424 J0.3406 F1200
G01 X310.6803 Y41.4955 F1200
G00 Z5.0000 F480
;No. 117: Hole 7
G00 X308.1144 Y36.4870 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X313.7981 F1200
G01 X314.9917 Y37.9180 F1200
G01 X306.9229 F1200
G01 X306.4433 Y39.3490 F1200
G01 X315.4687 F1200
G01 X315.4707 Y40.7800 F1200
G01 X306.4446 F1200
G01 X306.9218 Y42.2110 F1200
G01 X314.9900 F1200
G01 X313.7985 Y43.6420 F1200
G01 X308.1158 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X307.9166 Y43.8899 F1200
G02 X314.7841 Y43.1042 I3.0409 J-3.8266 F1200
G02 X313.9984 Y36.2367 I-3.8266 J-3.0409 F1200
G02 X307.1309 Y37.0224 I-3.0409 J3.8266 F1200
G02 X307.9166 Y43.8899 I3.8266 J3.0409 F1200
G01 X308.1158 Y43.6420 F1200
G00 Z5.0000 F480
;No. 118: Hole 16
G00 X237.6352 Y179.7768 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X235.3545 F1200
G01 X233.0981 Y181.2078 F1200
G01 X239.8908 F1200
G01 X240.6999 Y182.6388 F1200
G01 X232.2884 F1200
G01 X232.0530 Y184.0698 F1200
G01 X240.9353 F1200
G01 X240.7002 Y185.5008 F1200
G01 X232.2886 F1200
G01 X233.0971 Y186.9318 F1200
G01 X239.8902 F1200
G01 X237.6337 Y188.3628 F1200
G01 X235.3530 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X235.2697 Y188.6696 F1200
G02 X241.0945 Y185.2948 I1.2250 J-4.5998 F1200
G02 X237.7197 Y179.4700 I-4.5998 J-1.2250 F1200
G02 X231.8949 Y182.8448 I-1.2250 J4.5998 F1200
G02 X235.2697 Y188.6696 I4.5998 J1.2250 F1200
G01 X235.3530 Y188.3628 F1200
G00 Z5.0000 F480
;No. 119: Hole 97
G00 X236.2230 Y182.6388 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X236.7690 F1200
G01 X237.9508 Y184.0698 F1200
G01 X235.0375 F1200
G01 X236.2193 Y185.5008 F1200
G01 X236.7653 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X236.8267 Y185.8127 F1200
G02 X237.0931 Y185.7412 I-0.3017 J-1.6559 F1200
G02 X235.8459 Y182.4168 I-0.5987 J-1.6715 F1200
G02 X234.7206 Y183.9936 I0.6480 J1.6524 F1200
G01 X234.7192 Y184.0992 F1200
G02 X236.8267 Y185.8127 I1.7738 J-0.0289 F1200
G01 X236.7653 Y185.5008 F1200
G00 Z5.0000 F480
;No. 120: Hole 24
G00 X215.7724 Y267.8230 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X210.0879 F1200
G01 X208.8952 Y269.2540 F1200
G01 X216.9651 F1200
G01 X217.4430 Y270.6850 F1200
G01 X208.4179 F1200
G01 X208.4182 Y272.1160 F1200
G01 X217.4429 F1200
G01 X216.9656 Y273.5470 F1200
G01 X208.8953 F1200
G01 X210.0884 Y274.9780 F1200
G01 X215.7728 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X215.9678 Y275.2296 F1200
G02 X216.7600 Y268.3628 I-3.0373 J-3.8295 F1200
G02 X209.8932 Y267.5706 I-3.8295 J3.0373 F1200
G02 X209.1010 Y274.4374 I3.0373 J3.8295 F1200
G02 X215.9678 Y275.2296 I3.8295 J-3.0373 F1200
G01 X215.7728 Y274.9780 F1200
G00 Z5.0000 F480
;No. 121: Hole 104
G00 X213.2043 Y269.9695 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X212.6575 F1200
G01 X211.4734 Y271.4005 F1200
G01 X214.3871 F1200
G01 X213.2066 Y272.8315 F1200
G01 X212.6548 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X212.6022 Y273.1450 F1200
G02 X214.6480 Y271.8513 I0.3293 J-1.7438 F1200
G02 X211.1892 Y271.0524 I-1.7176 J-0.4505 F1200
G02 X211.1571 Y271.3149 I1.7565 J0.3481 F1200
G01 X211.1551 Y271.4206 F1200
G02 X212.6022 Y273.1450 I1.7746 J-0.0198 F1200
G01 X212.6548 Y272.8315 F1200
G00 Z5.0000 F480
;No. 122: Hole 25
G00 X214.0685 Y300.1627 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X208.3837 F1200
G01 X207.1922 Y301.5937 F1200
G01 X215.2615 F1200
G01 X215.7394 Y303.0247 F1200
G01 X206.7141 F1200
G01 X206.7146 Y304.4557 F1200
G01 X215.7394 F1200
G01 X215.2619 Y305.8867 F1200
G01 X207.1915 F1200
G01 X208.3847 Y307.3177 F1200
G01 X214.0698 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X214.2716 Y307.5634 F1200
G02 X215.0504 Y300.6952 I-3.0447 J-3.8235 F1200
G02 X208.1822 Y299.9164 I-3.8235 J3.0447 F1200
G02 X207.4034 Y306.7847 I3.0447 J3.8235 F1200
G02 X214.2716 Y307.5634 I3.8235 J-3.0447 F1200
G01 X214.0698 Y307.3177 F1200
G00 Z5.0000 F480
;No. 123: Hole 105
G00 X211.5007 Y302.3092 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X210.9539 F1200
G01 X209.7696 Y303.7402 F1200
G01 X212.6837 F1200
G01 X211.5030 Y305.1712 F1200
G01 X210.9511 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X210.8985 Y305.4848 F1200
G02 X212.9854 Y303.9840 I0.3289 J-1.7439 F1200
G02 X209.4568 Y303.6018 I-1.7586 J-0.2437 F1200
G01 X209.4517 Y303.7077 F1200
G01 X209.4515 Y303.7604 F1200
G02 X210.8985 Y305.4848 I1.7746 J-0.0198 F1200
G01 X210.9511 Y305.1712 F1200
G00 Z5.0000 F480
;No. 124: Hole 103
G00 X171.1824 Y266.5031 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X170.6306 F1200
G01 X169.4506 Y267.9341 F1200
G01 X172.3645 F1200
G01 X171.1812 Y269.3651 F1200
G01 X170.6343 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X170.5725 Y269.6770 F1200
G02 X172.6582 Y268.2297 I0.3367 J-1.7414 F1200
G02 X169.1424 Y267.7436 I-1.7506 J-0.2955 F1200
G01 X169.1342 Y267.8489 F1200
G01 X169.1323 Y267.9544 F1200
G02 X170.5725 Y269.6770 I1.7747 J-0.0205 F1200
G01 X170.6343 Y269.3651 F1200
G00 Z5.0000 F480
;No. 125: Hole 23
G00 X168.0660 Y264.3566 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X173.7507 F1200
G01 X174.9420 Y265.7876 F1200
G01 X166.8729 F1200
G01 X166.3953 Y267.2186 F1200
G01 X175.4205 F1200
G01 X175.4203 Y268.6496 F1200
G01 X166.3949 F1200
G01 X166.8730 Y270.0806 F1200
G01 X174.9427 F1200
G01 X173.7492 Y271.5116 F1200
G01 X168.0651 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X167.8659 Y271.7597 F1200
G02 X174.7334 Y270.9747 I3.0412 J-3.8262 F1200
G02 X173.9484 Y264.1073 I-3.8262 J-3.0412 F1200
G02 X167.0810 Y264.8922 I-3.0412 J3.8262 F1200
G02 X167.8659 Y271.7597 I3.8262 J3.0412 F1200
G01 X168.0651 Y271.5116 F1200
G00 Z5.0000 F480
;No. 126: Hole 59
G00 X433.2283 Y488.1081 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X438.9118 F1200
G01 X440.1050 Y489.5391 F1200
G01 X432.0362 F1200
G01 X431.5579 Y490.9701 F1200
G01 X440.5825 F1200
G01 X440.5827 Y492.4011 F1200
G01 X431.5587 F1200
G01 X432.0359 Y493.8321 F1200
G01 X440.1047 F1200
G01 X438.9133 Y495.2631 F1200
G01 X433.2289 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X433.0329 Y495.5132 F1200
G02 X440.8688 Y492.6137 I3.0390 J-3.8251 F1200
G02 X431.2455 Y490.9089 I-4.7982 J-0.9281 F1200
G02 X431.1849 Y491.5823 I4.8589 J0.7764 F1200
G01 X431.1843 Y491.7510 F1200
G02 X433.0329 Y495.5132 I4.8694 J-0.0573 F1200
G01 X433.2289 Y495.2631 F1200
G00 Z5.0000 F480
;No. 127: Hole 151
G00 X435.7944 Y490.2546 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X436.3441 F1200
G01 X437.5272 Y491.6856 F1200
G01 X434.6137 F1200
G01 X435.7953 Y493.1166 F1200
G01 X436.3465 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X436.4153 Y493.4270 F1200
G02 X437.8352 Y491.8778 I-0.3455 J-1.7420 F1200
G02 X434.2974 Y491.5991 I-1.7647 J-0.1923 F1200
G01 X434.2954 Y491.7048 F1200
G02 X436.4153 Y493.4270 I1.7749 J-0.0190 F1200
G01 X436.3465 Y493.1166 F1200
G00 Z5.0000 F480
;No. 128: Hole 68
G00 X415.6244 Y640.7258 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X409.9387 F1200
G01 X408.7455 Y642.1568 F1200
G01 X416.8138 F1200
G01 X417.2937 Y643.5878 F1200
G01 X408.2676 F1200
G01 X408.2665 Y645.0188 F1200
G01 X417.2926 F1200
G01 X416.8141 Y646.4498 F1200
G01 X408.7464 F1200
G01 X409.9358 Y647.8808 F1200
G01 X415.6217 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X415.8165 Y648.1324 F1200
G02 X416.6080 Y641.2659 I-3.0375 J-3.8291 F1200
G02 X409.7414 Y640.4743 I-3.8291 J3.0375 F1200
G02 X408.9499 Y647.3409 I3.0375 J3.8291 F1200
G02 X415.8165 Y648.1324 I3.8291 J-3.0375 F1200
G01 X415.6217 Y647.8808 F1200
G00 Z5.0000 F480
;No. 129: Hole 144
G00 X413.0537 Y642.8723 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X412.5032 F1200
G01 X411.3232 Y644.3033 F1200
G01 X414.2375 F1200
G01 X413.0570 Y645.7343 F1200
G01 X412.5073 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X412.4466 Y646.0469 F1200
G02 X414.3595 Y645.1151 I0.3342 J-1.7433 F1200
G02 X411.1554 Y643.5868 I-1.5794 J-0.8116 F1200
G02 X411.0076 Y644.2010 I1.6335 J0.7180 F1200
G01 X411.0046 Y644.3067 F1200
G01 X411.0054 Y644.3596 F1200
G02 X412.4466 Y646.0469 I1.7737 J-0.0559 F1200
G01 X412.5073 Y645.7343 F1200
G00 Z5.0000 F480
;No. 130: Hole 69
G00 X403.1391 Y681.0007 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X397.4528 F1200
G01 X396.2614 Y682.4317 F1200
G01 X404.3287 F1200
G01 X404.8091 Y683.8627 F1200
G01 X395.7828 F1200
G01 X395.7812 Y685.2937 F1200
G01 X404.8074 F1200
G01 X404.3294 Y686.7247 F1200
G01 X396.2625 F1200
G01 X397.4515 Y688.1557 F1200
G01 X403.1379 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X403.3333 Y688.4065 F1200
G02 X404.1221 Y681.5396 I-3.0390 J-3.8279 F1200
G02 X397.2552 Y680.7507 I-3.8279 J3.0390 F1200
G02 X396.4664 Y687.6176 I3.0390 J3.8279 F1200
G02 X403.3333 Y688.4065 I3.8279 J-3.0390 F1200
G01 X403.1379 Y688.1557 F1200
G00 Z5.0000 F480
;No. 131: Hole 143
G00 X400.5701 Y683.1472 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X400.0183 F1200
G01 X398.8378 Y684.5782 F1200
G01 X401.7523 F1200
G01 X400.5724 Y686.0092 F1200
G01 X400.0205 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X399.9599 Y686.3214 F1200
G02 X402.0387 Y684.9133 I0.3354 J-1.7435 F1200
G02 X400.6306 Y682.8344 I-1.7435 J-0.3354 F1200
G02 X398.5518 Y684.2425 I-0.3354 J1.7435 F1200
G02 X399.9599 Y686.3214 I1.7435 J0.3354 F1200
G01 X400.0205 Y686.0092 F1200
G00 Z5.0000 F480
;No. 132: Hole 70
G00 X428.1410 Y691.3467 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X433.8271 F1200
G01 X435.0162 Y692.7777 F1200
G01 X426.9495 F1200
G01 X426.4707 Y694.2087 F1200
G01 X435.4971 F1200
G01 X435.4954 Y695.6397 F1200
G01 X426.4695 F1200
G01 X426.9498 Y697.0707 F1200
G01 X435.0174 F1200
G01 X433.8258 Y698.5017 F1200
G01 X428.1395 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X427.9414 Y698.7502 F1200
G02 X434.8085 Y697.9664 I3.0417 J-3.8255 F1200
G02 X434.0247 Y691.0992 I-3.8255 J-3.0417 F1200
G02 X427.1575 Y691.8831 I-3.0417 J3.8255 F1200
G02 X427.9414 Y698.7502 I3.8255 J3.0417 F1200
G01 X428.1395 Y698.5017 F1200
G00 Z5.0000 F480
;No. 133: Hole 142
G00 X430.7063 Y693.4932 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X431.2581 F1200
G01 X432.4403 Y694.9242 F1200
G01 X429.5258 F1200
G01 X430.7085 Y696.3552 F1200
G01 X431.2603 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X431.3264 Y696.6661 F1200
G02 X432.7396 Y695.1841 I-0.3410 J-1.7399 F1200
G02 X429.2200 Y694.7169 I-1.7563 J-0.2600 F1200
G01 X429.2107 Y694.8223 F1200
G01 X429.2076 Y694.9279 F1200
G02 X431.3264 Y696.6661 I1.7747 J-0.0028 F1200
G01 X431.2603 Y696.3552 F1200
G00 Z5.0000 F480
;No. 134: Hole 80
G00 X517.8838 Y671.6129 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X523.5683 F1200
G01 X524.7618 Y673.0439 F1200
G01 X516.6925 F1200
G01 X516.2141 Y674.4749 F1200
G01 X525.2392 F1200
G01 X525.2401 Y675.9059 F1200
G01 X516.2151 F1200
G01 X516.6921 Y677.3369 F1200
G01 X524.7614 F1200
G01 X523.5704 Y678.7679 F1200
G01 X517.8861 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X517.6889 Y679.0173 F1200
G02 X525.5946 Y675.6320 I3.0396 J-3.8252 F1200
G02 X515.8483 Y674.9020 I-4.8674 J-0.4414 F1200
G01 X515.8413 Y675.0708 F1200
G01 X515.8401 Y675.1477 F1200
G01 X515.8409 Y675.2864 F1200
G02 X517.6889 Y679.0173 I4.8663 J-0.0873 F1200
G01 X517.8861 Y678.7679 F1200
G00 Z5.0000 F480
;No. 135: Hole 141
G00 X520.4541 Y673.7594 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X521.0039 F1200
G01 X522.1838 Y675.1904 F1200
G01 X519.2703 F1200
G01 X520.4524 Y676.6214 F1200
G01 X521.0001 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X521.0638 Y676.9328 F1200
G02 X522.4945 Y675.3603 I-0.3361 J-1.7429 F1200
G02 X518.9528 Y675.1261 I-1.7674 J-0.1698 F1200
G01 X518.9522 Y675.2321 F1200
G02 X521.0638 Y676.9328 I1.7743 J-0.0416 F1200
G01 X521.0001 Y676.6214 F1200
G00 Z5.0000 F480
;No. 136: Hole 140
G00 X520.2266 Y641.3836 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X519.6786 F1200
G01 X518.4951 Y642.8146 F1200
G01 X521.4086 F1200
G01 X520.2249 Y644.2456 F1200
G01 X519.6772 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X519.6191 Y644.5581 F1200
G02 X521.7235 Y642.9318 I0.3338 J-1.7427 F1200
G02 X518.1765 Y642.8032 I-1.7716 J-0.1171 F1200
G01 X518.1790 Y642.9093 F1200
G02 X519.6191 Y644.5581 I1.7712 J-0.0937 F1200
G01 X519.6772 Y644.2456 F1200
G00 Z5.0000 F480
;No. 137: Hole 79
G00 X517.1086 Y639.2371 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X522.7928 F1200
G01 X523.9868 Y640.6681 F1200
G01 X515.9176 F1200
G01 X515.4386 Y642.0991 F1200
G01 X524.4641 F1200
G01 X524.4649 Y643.5301 F1200
G01 X515.4394 F1200
G01 X515.9169 Y644.9611 F1200
G01 X523.9861 F1200
G01 X522.7951 Y646.3921 F1200
G01 X517.1116 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X516.9142 Y646.6419 F1200
G02 X524.8119 Y643.3327 I3.0392 J-3.8257 F1200
G02 X515.0781 Y642.4495 I-4.8600 J-0.5178 F1200
G01 X515.0686 Y642.6182 F1200
G01 X515.0661 Y642.6950 F1200
G01 X515.0648 Y642.8337 F1200
G02 X516.9142 Y646.6419 I4.8681 J-0.0110 F1200
G01 X517.1116 Y646.3921 F1200
G00 Z5.0000 F480
;No. 138: Hole 81
G00 X698.5437 Y612.3120 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X704.2288 F1200
G01 X705.4223 Y613.7430 F1200
G01 X697.3535 F1200
G01 X696.8735 Y615.1740 F1200
G01 X705.8992 F1200
G01 X705.9004 Y616.6050 F1200
G01 X696.8753 F1200
G01 X697.3528 Y618.0360 F1200
G01 X705.4214 F1200
G01 X704.2308 Y619.4670 F1200
G01 X698.5455 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X698.3504 Y619.7178 F1200
G02 X705.2171 Y618.9254 I3.0371 J-3.8296 F1200
G02 X704.4246 Y612.0587 I-3.8296 J-3.0371 F1200
G02 X697.5579 Y612.8511 I-3.0371 J3.8296 F1200
G02 X698.3504 Y619.7178 I3.8296 J3.0371 F1200
G01 X698.5455 Y619.4670 F1200
G00 Z5.0000 F480
;No. 139: Hole 138
G00 X701.1150 Y614.4585 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X701.6635 F1200
G01 X702.8445 Y615.8895 F1200
G01 X699.9300 F1200
G01 X701.1095 Y617.3205 F1200
G01 X701.6617 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X701.7289 Y617.6312 F1200
G02 X702.6691 Y617.1180 I-0.3332 J-1.7282 F1200
G02 X700.0363 Y614.7375 I-1.2818 J-1.2285 F1200
G02 X699.6123 Y615.8452 I1.3421 J1.1488 F1200
G01 X699.6129 Y615.9511 F1200
G02 X701.7289 Y617.6312 I1.7742 J-0.0620 F1200
G01 X701.6617 Y617.3205 F1200
G00 Z5.0000 F480
;No. 140: Hole 82
G00 X700.4896 Y644.6380 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X706.1750 F1200
G01 X707.3681 Y646.0690 F1200
G01 X699.2995 F1200
G01 X698.8205 Y647.5000 F1200
G01 X707.8462 F1200
G01 X707.8469 Y648.9310 F1200
G01 X698.8212 F1200
G01 X699.2986 Y650.3620 F1200
G01 X707.3678 F1200
G01 X706.1777 Y651.7930 F1200
G01 X700.4919 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X700.2937 Y652.0412 F1200
G02 X708.2152 Y648.4570 I3.0413 J-3.8242 F1200
G02 X698.4471 Y648.1278 I-4.8815 J-0.2412 F1200
G01 Y648.2967 F1200
G02 X700.2937 Y652.0412 I4.8723 J-0.0752 F1200
G01 X700.4919 Y651.7930 F1200
G00 Z5.0000 F480
;No. 141: Hole 139
G00 X703.0614 Y646.7845 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X703.6099 F1200
G01 X704.7909 Y648.2155 F1200
G01 X701.8764 F1200
G01 X703.0559 Y649.6465 F1200
G01 X703.6081 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X703.6753 Y649.9572 F1200
G02 X704.6155 Y649.4441 I-0.3332 J-1.7282 F1200
G02 X701.9828 Y647.0635 I-1.2818 J-1.2285 F1200
G02 X701.5587 Y648.1712 I1.3421 J1.1488 F1200
G01 X701.5593 Y648.2771 F1200
G02 X703.6753 Y649.9572 I1.7742 J-0.0620 F1200
G01 X703.6081 Y649.6465 F1200
G00 Z5.0000 F480
;No. 142: Hole 146
G00 X330.3996 Y686.9404 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X329.8456 F1200
G01 X328.6637 Y688.3714 F1200
G01 X331.5778 F1200
G01 X330.3959 Y689.8024 F1200
G01 X329.8418 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X329.7715 Y690.1125 F1200
G02 X331.8617 Y688.7209 I0.3493 J-1.7409 F1200
G02 X330.4701 Y686.6307 I-1.7409 J-0.3493 F1200
G02 X328.3799 Y688.0223 I-0.3493 J1.7409 F1200
G02 X329.7715 Y690.1125 I1.7409 J0.3493 F1200
G01 X329.8418 Y689.8024 F1200
G00 Z5.0000 F480
;No. 143: Hole 73
G00 X327.2762 Y684.7939 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X332.9625 F1200
G01 X334.1551 Y686.2249 F1200
G01 X326.0876 F1200
G01 X325.6071 Y687.6559 F1200
G01 X334.6331 F1200
G01 X334.6344 Y689.0869 F1200
G01 X325.6085 F1200
G01 X326.0868 Y690.5179 F1200
G01 X334.1541 F1200
G01 X332.9650 Y691.9489 F1200
G01 X327.2782 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X327.0795 Y692.1971 F1200
G02 X333.9474 Y691.4125 I3.0417 J-3.8263 F1200
G02 X333.1629 Y684.5446 I-3.8263 J-3.0417 F1200
G02 X326.2949 Y685.3292 I-3.0417 J3.8263 F1200
G02 X327.0795 Y692.1971 I3.8263 J3.0417 F1200
G01 X327.2782 Y691.9489 F1200
G00 Z5.0000 F480
;No. 144: Hole 145
G00 X326.2185 Y644.9826 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X325.6654 F1200
G01 X324.4834 Y646.4136 F1200
G01 X327.3973 F1200
G01 X326.2153 Y647.8446 F1200
G01 X325.6618 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X325.6056 Y648.1576 F1200
G02 X327.6844 Y646.7485 I0.3349 J-1.7439 F1200
G02 X326.2753 Y644.6697 I-1.7439 J-0.3349 F1200
G02 X324.1966 Y646.0788 I-0.3349 J1.7439 F1200
G02 X325.6056 Y648.1576 I1.7439 J0.3349 F1200
G01 X325.6618 Y647.8446 F1200
G00 Z5.0000 F480
;No. 145: Hole 72
G00 X323.0960 Y642.8361 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X328.7821 F1200
G01 X329.9749 Y644.2671 F1200
G01 X321.9061 F1200
G01 X321.4266 Y645.6981 F1200
G01 X330.4527 F1200
G01 X330.4536 Y647.1291 F1200
G01 X321.4281 F1200
G01 X321.9054 Y648.5601 F1200
G01 X329.9740 F1200
G01 X328.7846 Y649.9911 F1200
G01 X323.0984 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X322.9021 Y650.2409 F1200
G02 X329.7690 Y649.4508 I3.0384 J-3.8285 F1200
G02 X328.9789 Y642.5838 I-3.8285 J-3.0384 F1200
G02 X322.1120 Y643.3740 I-3.0384 J3.8285 F1200
G02 X322.9021 Y650.2409 I3.8285 J3.0384 F1200
G01 X323.0984 Y649.9911 F1200
G00 Z5.0000 F480
;No. 146: Hole 147
G00 X293.9124 Y647.2359 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X293.3619 F1200
G01 X292.1772 Y648.6669 F1200
G01 X295.0911 F1200
G01 X293.9092 Y650.0979 F1200
G01 X293.3557 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X293.2995 Y650.4109 F1200
G02 X295.3940 Y648.9049 I0.3350 J-1.7435 F1200
G02 X291.8636 Y648.5338 I-1.7597 J-0.2377 F1200
G01 X291.8589 Y648.6394 F1200
G01 Y648.6924 F1200
G02 X293.2995 Y650.4109 I1.7753 J-0.0251 F1200
G01 X293.3557 Y650.0979 F1200
G00 Z5.0000 F480
;No. 147: Hole 71
G00 X290.7899 Y645.0894 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X296.4760 F1200
G01 X297.6688 Y646.5204 F1200
G01 X289.6000 F1200
G01 X289.1209 Y647.9514 F1200
G01 X298.1466 F1200
G01 X298.1477 Y649.3824 F1200
G01 X289.1219 F1200
G01 X289.5993 Y650.8134 F1200
G01 X297.6683 F1200
G01 X296.4778 Y652.2444 F1200
G01 X290.7923 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X290.5962 Y652.4941 F1200
G02 X298.4783 Y649.3209 I3.0392 J-3.8267 F1200
G02 X288.7721 Y648.1654 I-4.8441 J-0.6535 F1200
G02 X288.7479 Y648.5638 I4.8779 J0.4968 F1200
G01 X288.7471 Y648.7025 F1200
G02 X290.5962 Y652.4941 I4.8729 J-0.0298 F1200
G01 X290.7923 Y652.2444 F1200
G00 Z5.0000 F480
;No. 148: Hole 74
G00 X236.7362 Y696.9555 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X231.0513 F1200
G01 X229.8606 Y698.3865 F1200
G01 X237.9298 F1200
G01 X238.4073 Y699.8175 F1200
G01 X229.3811 F1200
G01 X229.3825 Y701.2485 F1200
G01 X238.4085 F1200
G01 X237.9286 Y702.6795 F1200
G01 X229.8603 F1200
G01 X231.0530 Y704.1105 F1200
G01 X236.7389 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X236.9337 Y704.3620 F1200
G02 X237.7252 Y697.4948 I-3.0378 J-3.8294 F1200
G02 X230.8580 Y696.7032 I-3.8294 J3.0378 F1200
G02 X230.0664 Y703.5705 I3.0378 J3.8294 F1200
G02 X236.9337 Y704.3620 I3.8294 J-3.0378 F1200
G01 X236.7389 Y704.1105 F1200
G00 Z5.0000 F480
;No. 149: Hole 160
G00 X234.1709 Y699.1020 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X233.6225 F1200
G01 X232.4380 Y700.5330 F1200
G01 X235.3521 F1200
G01 X234.1698 Y701.9640 F1200
G01 X233.6171 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X233.5576 Y702.2764 F1200
G02 X235.6383 Y700.8704 I0.3374 J-1.7434 F1200
G02 X234.2323 Y698.7896 I-1.7434 J-0.3374 F1200
G02 X232.1516 Y700.1956 I-0.3374 J1.7434 F1200
G02 X233.5576 Y702.2764 I1.7434 J0.3374 F1200
G01 X233.6171 Y701.9640 F1200
G00 Z5.0000 F480
;No. 150: Hole 159
G00 X201.8444 Y701.0134 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X201.2924 F1200
G01 X200.1094 Y702.4444 F1200
G01 X203.0240 F1200
G01 X201.8417 Y703.8754 F1200
G01 X201.2890 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X201.2294 Y704.1878 F1200
G02 X203.2670 Y702.9573 I0.3377 J-1.7430 F1200
G02 X199.8390 Y702.0329 I-1.7004 J-0.5127 F1200
G02 X199.7939 Y702.3453 I1.7228 J0.4085 F1200
G01 X199.7912 Y702.4511 F1200
G02 X201.2294 Y704.1878 I1.7748 J-0.0059 F1200
G01 X201.2890 Y703.8754 F1200
G00 Z5.0000 F480
;No. 151: Hole 75
G00 X198.7231 Y698.8669 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X204.4082 F1200
G01 X205.6012 Y700.2979 F1200
G01 X197.5329 F1200
G01 X197.0535 Y701.7289 F1200
G01 X206.0792 F1200
G01 X206.0799 Y703.1599 F1200
G01 X197.0542 F1200
G01 X197.5317 Y704.5909 F1200
G01 X205.6009 F1200
G01 X204.4102 Y706.0219 F1200
G01 X198.7250 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X198.5299 Y706.2730 F1200
G02 X205.3966 Y705.4802 I3.0370 J-3.8298 F1200
G02 X204.6039 Y698.6135 I-3.8298 J-3.0370 F1200
G02 X197.7371 Y699.4063 I-3.0370 J3.8298 F1200
G02 X198.5299 Y706.2730 I3.8298 J3.0370 F1200
G01 X198.7250 Y706.0219 F1200
G00 Z5.0000 F480
;No. 152: Hole 158
G00 X80.8114 Y701.2207 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X80.2623 F1200
G01 X79.0814 Y702.6517 F1200
G01 X81.9965 F1200
G01 X80.8154 Y704.0827 F1200
G01 X80.2651 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X80.1990 Y704.3936 F1200
G02 X82.1159 Y703.4680 I0.3409 J-1.7417 F1200
G02 X78.9164 Y701.9305 I-1.5769 J-0.8162 F1200
G02 X78.7633 Y702.6500 I1.6339 J0.7237 F1200
G01 X78.7662 Y702.7554 F1200
G02 X80.1990 Y704.3936 I1.7707 J-0.1030 F1200
G01 X80.2651 Y704.0827 F1200
G00 Z5.0000 F480
;No. 153: Hole 78
G00 X77.6969 Y699.0742 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X83.3835 F1200
G01 X84.5723 Y700.5052 F1200
G01 X76.5045 F1200
G01 X76.0268 Y701.9362 F1200
G01 X85.0532 F1200
G01 X85.0514 Y703.3672 F1200
G01 X76.0247 F1200
G01 X76.5058 Y704.7982 F1200
G01 X84.5732 F1200
G01 X83.3817 Y706.2292 F1200
G01 X77.6944 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X77.4951 Y706.4766 F1200
G02 X84.3629 Y705.6951 I3.0432 J-3.8246 F1200
G02 X83.5814 Y698.8274 I-3.8246 J-3.0432 F1200
G02 X76.7136 Y699.6088 I-3.0432 J3.8246 F1200
G02 X77.4951 Y706.4766 I3.8246 J3.0432 F1200
G01 X77.6944 Y706.2292 F1200
G00 Z5.0000 F480
;No. 154: Hole 157
G00 X49.9066 Y691.5477 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X49.3562 F1200
G01 X48.1758 Y692.9787 F1200
G01 X51.0896 F1200
G01 X49.9094 Y694.4097 F1200
G01 X49.3602 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X49.3033 Y694.7225 F1200
G02 X51.1847 Y693.8416 I0.3309 J-1.7428 F1200
G02 X48.0323 Y692.2096 I-1.5520 J-0.8627 F1200
G02 X47.8580 Y692.9242 I1.6102 J0.7713 F1200
G01 X47.8577 Y693.0298 F1200
G02 X49.3033 Y694.7225 I1.7724 J-0.0501 F1200
G01 X49.3602 Y694.4097 F1200
G00 Z5.0000 F480
;No. 155: Hole 77
G00 X46.7900 Y689.4012 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X52.4772 F1200
G01 X53.6659 Y690.8322 F1200
G01 X45.5983 F1200
G01 X45.1207 Y692.2632 F1200
G01 X54.1470 F1200
G01 X54.1452 Y693.6942 F1200
G01 X45.1184 F1200
G01 X45.5994 Y695.1252 F1200
G01 X53.6666 F1200
G01 X52.4754 Y696.5562 F1200
G01 X46.7881 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X46.5927 Y696.8069 F1200
G02 X53.4599 Y696.0181 I3.0392 J-3.8279 F1200
G02 X52.6712 Y689.1510 I-3.8279 J-3.0392 F1200
G02 X45.8040 Y689.9397 I-3.0392 J3.8279 F1200
G02 X46.5927 Y696.8069 I3.8279 J3.0392 F1200
G01 X46.7881 Y696.5562 F1200
G00 Z5.0000 F480
;No. 156: Hole 156
G00 X60.7514 Y650.9511 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X61.3017 F1200
G01 X62.4846 Y652.3821 F1200
G01 X59.5710 F1200
G01 X60.7538 Y653.8131 F1200
G01 X61.3057 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X61.3660 Y654.1253 F1200
G02 X62.7710 Y652.0442 I-0.3380 J-1.7431 F1200
G02 X60.6899 Y650.6391 I-1.7431 J0.3380 F1200
G02 X59.2849 Y652.7203 I0.3380 J1.7431 F1200
G02 X61.3660 Y654.1253 I1.7431 J-0.3380 F1200
G01 X61.3057 Y653.8131 F1200
G00 Z5.0000 F480
;No. 157: Hole 76
G00 X63.8717 Y648.8046 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X58.1857 F1200
G01 X56.9932 Y650.2356 F1200
G01 X65.0616 F1200
G01 X65.5417 Y651.6666 F1200
G01 X56.5154 F1200
G01 X56.5139 Y653.0976 F1200
G01 X65.5398 F1200
G01 X65.0620 Y654.5286 F1200
G01 X56.9938 F1200
G01 X58.1839 Y655.9596 F1200
G01 X63.8691 F1200
G00 Z5.0000 F480
G00 Z0.5000 F480
G01 Z-1.0000 F180
G01 X64.0662 Y656.2092 F1200
G02 X64.8541 Y649.3423 I-3.0395 J-3.8274 F1200
G02 X57.9873 Y648.5544 I-3.8274 J3.0395 F1200
G02 X57.1993 Y655.4212 I3.0395 J3.8274 F1200
G02 X64.0662 Y656.2092 I3.8274 J-3.0395 F1200
G01 X63.8691 Y655.9596 F1200
G00 Z5.0000 F480
;No. 158: Part 11
G00 X141.0159 Y362.5703 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G03 X153.6581 Y350.5829 I6567.6318 J6913.7625 F1200
G03 X164.4457 Y340.3840 I6357.4043 J6713.5087 F1200
G03 X167.9297 Y338.2350 I6.3576 J6.4086 F1200
G03 X173.7965 Y340.1279 I1.6606 J4.8915 F1200
G01 X173.9029 Y340.2722 F1200
G01 X174.0062 Y340.4208 F1200
G03 X175.4955 Y345.0966 I-8.3103 J5.2219 F1200
G03 X175.5477 Y346.2844 I-14.9902 J1.2540 F1200
G01 X175.7077 Y379.6154 F1200
G01 X175.6226 Y396.4559 F1200
G00 Z-3.5000 F480
G01 X175.5985 Y401.2259 F1200
G01 Z-6.5000 F180
G01 X175.5620 Y408.4536 F1200
G01 X175.8327 Y465.9875 F1200
G03 X167.4663 Y474.6855 I-8.6551 J0.0477 F1200
G02 X131.4169 Y476.1803 I9.7813 J671.3383 F1200
G03 X122.3330 Y468.1981 I-0.4537 J-8.6437 F1200
G01 X120.7671 Y448.5860 F1200
G00 Z-3.5000 F480
G01 X120.3874 Y443.8311 F1200
G01 Z-6.5000 F180
G01 X119.6994 Y435.2137 F1200
G01 X117.8053 Y400.8624 F1200
G01 X116.9529 Y390.1879 F1200
G03 X116.9203 Y389.5497 I10.8194 J-0.8731 F1200
G01 X116.9187 Y389.3068 F1200
G01 X116.9205 Y389.1834 F1200
G03 X117.9902 Y385.5834 I7.2460 J0.1941 F1200
G03 X121.2873 Y381.4859 I15.3080 J8.9421 F1200
G03 X137.5588 Y365.8568 I911.4248 J932.6113 F1200
G00 Z-3.5000 F480
G01 X140.3231 Y363.2283 F1200
G01 X141.0159 Y362.5703 F1200
G00 Z5.0000 F480
;No. 159: Part 12
G00 X151.2627 Y550.8812 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X134.1501 Y549.6600 F1200
G03 X126.1059 Y541.0491 I0.6096 J-8.6323 F1200
G02 X125.8912 Y509.6593 I-697.2421 J-10.9274 F1200
G03 X134.1949 Y501.2049 I8.6544 J0.1951 F1200
G01 X167.3227 Y499.8810 F1200
G01 X180.1702 Y499.3493 F1200
G00 Z-3.5000 F480
G01 X184.9361 Y499.1521 F1200
G01 Z-6.5000 F180
G01 X197.7836 Y498.6204 F1200
G01 X256.3905 Y496.2285 F1200
G03 X261.1599 Y496.9268 I0.7557 J11.4744 F1200
G03 X262.4382 Y497.6000 I-2.5717 J6.4339 F1200
G03 X264.4729 Y503.1213 I-2.5709 J4.0830 F1200
G03 X262.1510 Y506.8495 I-8.5452 J-2.7346 F1200
G03 X261.6162 Y507.3696 I-10.3536 J-10.1111 F1200
G01 X233.7827 Y536.0316 F1200
G00 Z-3.5000 F480
G01 X230.4596 Y539.4536 F1200
G01 Z-6.5000 F180
G01 X217.3736 Y552.9291 F1200
G03 X210.7997 Y555.2533 I-5.9275 J-6.3066 F1200
G01 X163.3875 Y551.7464 F1200
G01 X156.0206 Y551.2207 F1200
G00 Z-3.5000 F480
G01 X151.2627 Y550.8812 F1200
G00 Z5.0000 F480
;No. 160: Part 10
G00 X92.3478 Y243.1832 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G03 X102.9364 Y248.9473 I2.3103 J8.3636 F1200
G03 X121.7145 Y319.8147 I-718.3116 J228.2569 F1200
G03 X120.3650 Y325.9220 I-8.5781 J1.3073 F1200
G01 X90.3942 Y371.3297 F1200
G02 X89.4875 Y374.2967 I4.5561 J3.0144 F1200
G01 X89.4882 Y374.4519 F1200
G02 X89.5272 Y375.0116 I5.5253 J-0.1039 F1200
G03 X87.8903 Y597.0777 I-713.4999 J105.7796 F1200
G02 X87.8613 Y597.5425 I5.4891 J0.5760 F1200
G01 X87.8611 Y597.7577 F1200
G02 X88.5765 Y600.3611 I5.4565 J-0.0993 F1200
G01 X117.3688 Y649.3644 F1200
G03 X118.3954 Y655.4826 I-7.4800 J4.4004 F1200
G03 X96.7401 Y730.7686 I-754.6702 J-176.3166 F1200
G03 X85.6755 Y736.1535 I-8.2093 J-2.8081 F1200
G01 X53.2936 Y724.3954 F1200
G01 X30.3686 Y716.2620 F1200
G03 X24.6072 Y708.2223 I2.8975 J-8.1606 F1200
G01 X24.6067 Y708.0424 F1200
G03 X25.0746 Y705.3023 I8.6563 J0.0679 F1200
G02 X28.2410 Y695.8768 I-658.6642 J-226.5199 F1200
G02 X58.5933 Y554.9886 I-659.4029 J-215.7718 F1200
G03 X58.8128 Y554.3293 I1.6887 J0.1961 F1200
G02 X59.3124 Y549.5405 I-662.4423 J-71.5376 F1200
G02 X30.4128 Y272.1789 I-685.6711 J-68.7431 F1200
G03 X30.0821 Y269.9089 I8.3103 J-2.3697 F1200
G01 X30.0818 Y269.7736 F1200
G03 X36.0738 Y261.5819 I8.6651 J0.0510 F1200
G01 X59.1844 Y254.0233 F1200
G01 X91.9668 Y243.2981 F1200
G01 X92.2082 Y243.2232 F1200
G01 X92.3478 Y243.1832 F1200
G00 Z5.0000 F480
;No. 161: Part 27
G00 X194.6743 Y730.9692 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X158.7095 Y731.7172 F1200
G03 X149.8725 Y723.3573 I-0.1871 J-8.6528 F1200
G02 X147.7885 Y687.2023 I-684.5656 J21.3218 F1200
G01 X147.7843 Y687.0677 F1200
G01 X147.7820 Y686.8882 F1200
G01 X147.7841 Y686.6632 F1200
G03 X155.6383 Y678.2600 I8.6566 J0.2189 F1200
G01 X188.6349 Y675.0914 F1200
G01 X197.6752 Y674.4470 F1200
G00 Z-3.5000 F480
G01 X202.4331 Y674.1078 F1200
G01 Z-6.5000 F180
G01 X222.8925 Y672.6494 F1200
G01 X233.5518 Y671.6254 F1200
G03 X238.0697 Y672.5335 I0.9068 J7.1812 F1200
G03 X241.8717 Y675.3824 I-8.0858 J14.7522 F1200
G01 X242.3425 Y675.8387 F1200
G03 X261.9308 Y695.6259 I-1242.6955 J1249.7925 F1200
G00 Z-3.5000 F480
G01 X262.6001 Y696.3080 F1200
G01 X265.2702 Y699.0320 F1200
G01 Z-6.5000 F180
G01 X265.6018 Y699.3703 F1200
G01 X269.0305 Y702.8718 F1200
G01 X272.8858 Y706.8126 F1200
G01 X276.7393 Y710.7552 F1200
G01 X280.5911 Y714.6995 F1200
G01 X284.0134 Y718.2072 F1200
G03 X286.3183 Y721.7596 I-6.4384 J6.7011 F1200
G03 X284.5200 Y727.6562 I-4.8650 J1.7388 F1200
G03 X284.0330 Y728.0036 I-4.2486 J-5.4409 F1200
G03 X279.3093 Y729.4595 I-5.2688 J-8.7038 F1200
G03 X278.3609 Y729.5068 I-1.2318 J-15.1830 F1200
G01 X245.0360 Y730.1130 F1200
G01 X216.2335 Y730.5208 F1200
G01 X199.4433 Y730.8700 F1200
G00 Z-3.5000 F480
G01 X194.6743 Y730.9692 F1200
G00 Z5.0000 F480
;No. 162: Part 14
G00 X191.1546 Y650.4772 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X159.0387 Y649.6027 F1200
G03 X129.3136 Y635.7625 I4.2268 J-47.9188 F1200
G03 X128.7440 Y635.0276 I5.5656 J-4.9026 F1200
G03 X125.8551 Y628.1306 I18.0766 J-11.6250 F1200
G03 X125.7150 Y626.7612 I6.8178 J-1.3895 F1200
G03 X125.7951 Y625.9925 I3.7755 J0.0048 F1200
G03 X127.9806 Y624.1214 I2.2005 J0.3583 F1200
G01 X298.1233 Y618.8728 F1200
G00 Z-3.5000 F480
G01 X302.8910 Y618.7257 F1200
G01 Z-6.5000 F180
G01 X335.3796 Y617.7235 F1200
G03 X344.1897 Y625.8087 I0.3066 J8.5084 F1200
G02 X353.7584 Y714.7415 I694.7451 J-29.7703 F1200
G02 X354.7457 Y720.3614 I734.9499 J-126.2190 F1200
G03 X354.6223 Y724.0670 I-8.5082 J1.5715 F1200
G03 X343.8571 Y730.3242 I-8.5457 J-2.3134 F1200
G03 X340.9022 Y728.8667 I2.3286 J-8.4452 F1200
G01 X322.6235 Y715.2074 F1200
G00 Z-3.5000 F480
G01 X318.8025 Y712.3521 F1200
G01 Z-6.5000 F180
G01 X300.5238 Y698.6928 F1200
G03 X297.0159 Y693.6201 I5.3586 J-7.4550 F1200
G03 X296.9131 Y693.1183 I7.0252 J-1.6995 F1200
G03 X295.7084 Y683.6555 I500.4842 J-68.5274 F1200
G02 X294.4971 Y679.5017 I-11.3168 J1.0465 F1200
G02 X293.9369 Y678.6649 I-4.8761 J2.6588 F1200
G02 X291.8669 Y677.4791 I-2.3745 J1.7453 F1200
G03 X290.0471 Y676.8545 I1.7638 J-8.1015 F1200
G03 X285.8819 Y673.8702 I7.8628 J-15.3730 F1200
G03 X282.3210 Y670.2133 I46.1628 J-48.5143 F1200
G01 X282.0893 Y669.9755 F1200
G03 X266.1694 Y654.0085 I3094.6134 J-3101.3895 F1200
G02 X262.5388 Y652.4210 I-3.8648 J3.8935 F1200
G01 X195.9229 Y650.6070 F1200
G00 Z-3.5000 F480
G01 X191.1546 Y650.4772 F1200
G00 Z5.0000 F480
;No. 163: Part 13
G00 X308.3111 Y504.3044 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X325.9912 Y490.0963 F1200
G03 X328.8652 Y488.5484 I5.5300 J6.8258 F1200
G03 X339.9993 Y495.5729 I2.5184 J8.3445 F1200
G03 X340.0289 Y497.8353 I-8.8420 J1.2468 F1200
G02 X333.5794 Y588.1315 I695.6193 J95.0633 F1200
G03 X324.9535 Y596.5868 I-8.6530 J-0.2000 F1200
G01 X294.9076 Y596.6809 F1200
G00 Z-3.5000 F480
G01 X290.1376 Y596.6959 F1200
G01 Z-6.5000 F180
G01 X117.2931 Y597.2373 F1200
G03 X115.0291 Y595.1545 I-0.0194 J-2.2509 F1200
G03 X115.0026 Y594.7794 I3.5453 J-0.4386 F1200
G01 X115.0020 Y594.6955 F1200
G03 X115.2678 Y593.0045 I6.7095 J0.1881 F1200
G03 X118.3217 Y586.9107 I19.0094 J5.7146 F1200
G01 X118.4535 Y586.7509 F1200
G03 X143.2432 Y572.4593 I35.2608 J32.5165 F1200
G03 X144.1246 Y572.3473 I1.5222 J8.4554 F1200
G01 X176.7234 Y570.5682 F1200
G00 Z-3.5000 F480
G01 X181.4863 Y570.3083 F1200
G01 Z-6.5000 F180
G01 X249.0655 Y566.6202 F1200
G02 X252.0503 Y565.3530 I-0.5041 J-5.3362 F1200
G01 X268.2270 Y550.0038 F1200
G01 X268.5368 Y549.7301 F1200
G02 X275.5336 Y543.0144 I-244.1015 J-261.3200 F1200
G01 X276.0736 Y542.4978 F1200
G01 X276.4384 Y542.1523 F1200
G03 X279.4098 Y540.1850 I5.9984 J5.8321 F1200
G02 X282.0020 Y538.0892 I-1.1743 J-4.1036 F1200
G02 X283.1088 Y534.4330 I-8.3394 J-4.5200 F1200
G01 X283.1358 Y534.1662 F1200
G01 X283.6871 Y527.5211 F1200
G03 X286.9128 Y521.5004 I8.6375 J0.7532 F1200
G01 X304.5929 Y507.2924 F1200
G00 Z-3.5000 F480
G01 X308.3111 Y504.3044 F1200
G00 Z5.0000 F480
;No. 164: Part 5
G00 X146.9268 Y276.2746 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X133.1193 Y258.2799 F1200
G03 X131.3064 Y253.1081 I6.7392 J-5.2660 F1200
G01 X131.3073 Y252.8980 F1200
G03 X131.3692 Y252.0098 I8.4720 J0.1434 F1200
G03 X141.3693 Y244.4484 I8.6205 J1.0074 F1200
G02 X231.3002 Y252.8949 I110.4199 J-692.6773 F1200
G03 X239.5596 Y261.7085 I-0.3936 J8.6457 F1200
G01 X238.9011 Y295.7858 F1200
G00 Z-3.5000 F480
G01 X238.8089 Y300.5549 F1200
G01 Z-6.5000 F180
G01 X236.9308 Y397.7390 F1200
G00 Z-3.5000 F480
G01 X236.8386 Y402.5081 F1200
G01 Z-6.5000 F180
G01 X235.5472 Y469.3311 F1200
G03 X233.4141 Y471.5478 I-2.2507 J-0.0312 F1200
G03 X231.4203 Y471.3046 I-0.3356 J-5.5425 F1200
G03 X225.2806 Y468.0996 I5.9971 J-18.9721 F1200
G01 X225.1497 Y467.9883 F1200
G03 X211.3581 Y442.8312 I33.2022 J-34.5610 F1200
G03 X211.2659 Y441.9476 I8.4837 J-1.3316 F1200
G01 X210.2193 Y409.3170 F1200
G00 Z-3.5000 F480
G01 X210.0664 Y404.5494 F1200
G01 Z-6.5000 F180
G01 X207.8966 Y336.9045 F1200
G02 X206.6967 Y333.8920 I-5.3368 J0.3804 F1200
G01 X191.7147 Y317.3747 F1200
G01 X191.4480 Y317.0589 F1200
G02 X184.8911 Y309.9131 I-266.7352 J238.1724 F1200
G01 X184.3867 Y309.3616 F1200
G01 X184.0495 Y308.9891 F1200
G03 X182.1494 Y305.9743 I5.9653 J-5.8659 F1200
G02 X180.1123 Y303.3356 I-4.1289 J1.0819 F1200
G02 X176.4819 Y302.1471 I-4.7062 J8.2358 F1200
G01 X176.2158 Y302.1141 F1200
G01 X169.5848 Y301.4137 F1200
G03 X163.6380 Y298.0537 I0.9483 J-8.6207 F1200
G01 X149.8305 Y280.0590 F1200
G00 Z-3.5000 F480
G01 X146.9268 Y276.2746 F1200
G00 Z5.0000 F480
;No. 165: Part 6
G00 X263.5649 Y304.7485 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X262.4730 Y274.8034 F1200
G01 X262.4673 Y274.5507 F1200
G01 X262.4677 Y274.3738 F1200
G03 X270.5086 Y265.9482 I8.5112 J0.0729 F1200
G02 X361.2583 Y255.5461 I-33.7202 J-695.2387 F1200
G01 X363.1294 Y255.2065 F1200
G01 X365.0006 Y254.8620 F1200
G03 X368.7069 Y254.9646 I1.6192 J8.4992 F1200
G03 X375.0392 Y265.6384 I-2.2665 J8.5599 F1200
G03 X373.5834 Y268.6576 I-8.4595 J-2.2184 F1200
G01 X360.0269 Y287.0126 F1200
G00 Z-3.5000 F480
G01 X357.1930 Y290.8496 F1200
G01 Z-6.5000 F180
G01 X343.6364 Y309.2046 F1200
G03 X338.5835 Y312.7409 I-7.4850 J-5.3167 F1200
G03 X338.0823 Y312.8465 I-1.7389 J-7.0155 F1200
G03 X328.6263 Y314.1043 I-71.3331 J-500.0920 F1200
G02 X324.4794 Y315.3388 I1.1099 J11.3108 F1200
G02 X323.6458 Y315.9037 I2.6861 J4.8611 F1200
G02 X322.4716 Y317.9804 I1.7586 J2.3647 F1200
G03 X321.8572 Y319.8036 I-8.1113 J-1.7184 F1200
G03 X318.8963 Y323.9854 I-15.4168 J-7.7765 F1200
G03 X315.2595 Y327.5669 I-48.7724 J-45.8900 F1200
G01 X315.0230 Y327.7999 F1200
G03 X299.1455 Y343.8091 I-3118.6949 J-3077.1716 F1200
G02 X297.5783 Y347.4485 I3.9152 J3.8430 F1200
G01 X296.1380 Y414.0736 F1200
G00 Z-3.5000 F480
G01 X296.0349 Y418.8425 F1200
G01 Z-6.5000 F180
G01 X295.3406 Y450.9628 F1200
G03 X281.6673 Y480.7650 I-47.9417 J-3.9580 F1200
G03 X280.9356 Y481.3388 I-5.0728 J-5.7153 F1200
G03 X274.0549 Y484.2662 I-11.7311 J-18.0227 F1200
G03 X271.9172 Y484.3383 I-1.2415 J-5.0850 F1200
G03 X270.0357 Y482.2126 I0.3432 J-2.1993 F1200
G01 X267.6017 Y415.4596 F1200
G00 Z-3.5000 F480
G01 X267.4279 Y410.6928 F1200
G01 Z-6.5000 F180
G01 X263.7387 Y309.5153 F1200
G00 Z-3.5000 F480
G01 X263.5649 Y304.7485 F1200
G00 Z5.0000 F480
;No. 166: Part 8
G00 X337.5865 Y338.8622 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G03 X344.2862 Y336.4428 I6.0117 J6.1615 F1200
G02 X375.2808 Y338.7185 I64.6891 J-668.8510 F1200
G03 X383.3541 Y347.6987 I-0.5746 J8.6356 F1200
G01 X382.0191 Y380.8260 F1200
G01 X380.8346 Y411.2900 F1200
G01 X378.5224 Y469.9001 F1200
G01 X378.5075 Y470.1996 F1200
G03 X377.3654 Y474.7513 I-11.0212 J-0.3461 F1200
G03 X376.6707 Y475.8185 I-6.0077 J-3.1514 F1200
G03 X371.0041 Y477.4041 I-3.8638 J-2.8898 F1200
G03 X367.4739 Y474.7910 I3.4106 J-8.2986 F1200
G03 X366.9984 Y474.2162 I10.7293 J-9.3620 F1200
G01 X325.1307 Y426.4650 F1200
G03 X323.2388 Y421.2247 I6.7539 J-5.4000 F1200
G01 X323.2374 Y421.0598 F1200
G01 X323.2397 Y420.8573 F1200
G03 X323.3240 Y419.8393 I8.6364 J0.2028 F1200
G01 X330.6358 Y372.7473 F1200
G01 X335.0654 Y343.7284 F1200
G03 X337.5865 Y338.8622 I8.5517 J1.3444 F1200
G00 Z5.0000 F480
;No. 167: Part 7
G00 X393.4358 Y712.3220 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X380.5852 Y707.3598 F1200
G03 X375.0471 Y699.4794 I3.1185 J-8.0777 F1200
G01 X375.0448 Y699.2524 F1200
G03 X375.6166 Y696.1985 I8.6464 J0.0384 F1200
G02 X381.4147 Y680.5210 I-462.9964 J-180.1427 F1200
G02 X413.2932 Y546.5226 I-657.0035 J-227.0940 F1200
G03 X413.5001 Y546.0240 I1.8710 J0.4841 F1200
G02 X415.6642 Y528.0642 I-671.0999 J-89.9747 F1200
G03 X415.3895 Y527.2441 I1.3785 J-0.9178 F1200
G01 X415.3887 Y527.0852 F1200
G02 X418.3773 Y489.4299 I-693.5130 J-73.9878 F1200
G02 X396.1288 Y276.2745 I-687.5679 J-35.9726 F1200
G03 X395.9158 Y274.5329 I8.4626 J-1.9185 F1200
G01 X395.9143 Y274.3536 F1200
G03 X402.3009 Y266.0043 I8.6686 J0.0135 F1200
G01 X428.2833 Y258.8515 F1200
G00 Z-3.5000 F480
G01 X432.8822 Y257.5855 F1200
G01 Z-6.5000 F180
G01 X458.8646 Y250.4328 F1200
G03 X461.2141 Y250.1373 I2.1931 J7.9485 F1200
G03 X469.5739 Y256.7085 I-0.3116 J8.9997 F1200
G03 X481.6489 Y309.4041 I-734.6918 J196.0835 F1200
G00 Z-3.5000 F480
G03 X482.5342 Y314.0912 I-657.6947 J126.6487 F1200
G01 Z-6.5000 F180
G03 X484.9801 Y327.9909 I-742.6899 J137.8584 F1200
G03 X483.4155 Y334.5373 I-8.5553 J1.4154 F1200
G01 X451.3945 Y378.4359 F1200
G02 X450.3427 Y381.5810 I4.4142 J3.2246 F1200
G01 X450.3420 Y381.6763 F1200
G01 X450.3445 Y381.8316 F1200
G01 X450.3503 Y381.9692 F1200
G03 X453.7277 Y467.4805 I-720.7301 J71.2880 F1200
G00 Z-3.5000 F480
G03 X453.6185 Y472.2493 I-684.7352 J-13.2839 F1200
G01 Z-6.5000 F180
G03 X451.8742 Y507.0624 I-728.0615 J-19.0301 F1200
G01 X451.8975 Y506.7492 F1200
G01 X451.9335 Y507.1508 F1200
G03 X452.1902 Y508.0549 I-1.3329 J0.8668 F1200
G03 X441.4504 Y589.5315 I-720.9362 J-53.5832 F1200
G02 X441.4036 Y590.2105 I5.4722 J0.7186 F1200
G01 X441.4047 Y590.3657 F1200
G02 X442.0507 Y592.8320 I5.4561 J-0.1113 F1200
G01 X469.5414 Y642.5651 F1200
G03 X470.3687 Y648.8680 I-7.5849 J4.2012 F1200
G03 X468.3274 Y656.5038 I-725.4809 J-189.8481 F1200
G00 Z-3.5000 F480
G03 X467.0574 Y661.1016 I-741.5842 J-202.3604 F1200
G01 Z-6.5000 F180
G03 X446.6821 Y723.7140 I-754.1679 J-210.7999 F1200
G03 X435.4745 Y728.8048 I-8.1328 J-3.0224 F1200
G01 X403.1985 Y716.0919 F1200
G01 X397.8856 Y714.0403 F1200
G00 Z-3.5000 F480
G01 X393.4358 Y712.3220 F1200
G00 Z5.0000 F480
;No. 168: Part 15
G00 X493.0141 Y640.8679 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X493.8377 Y627.4193 F1200
G01 X495.5538 Y598.1579 F1200
G03 X504.1060 Y590.0049 I8.6368 J0.4978 F1200
G02 X535.1342 Y589.3964 I2.3637 J-670.8400 F1200
G03 X544.0055 Y597.5891 I0.2285 J8.6520 F1200
G01 X545.7488 Y630.6975 F1200
G01 X546.7175 Y648.6110 F1200
G00 Z-3.5000 F480
G01 X546.9751 Y653.3740 F1200
G01 Z-6.5000 F180
G01 X547.3950 Y661.1400 F1200
G01 X550.5289 Y719.7119 F1200
G03 X550.5331 Y721.2660 I-14.9043 J0.8178 F1200
G03 X549.4289 Y725.4595 I-9.2757 J-0.2003 F1200
G01 X549.3364 Y725.6154 F1200
G01 X549.2341 Y725.7765 F1200
G03 X543.7390 Y727.8809 I-4.1152 J-2.5190 F1200
G03 X543.2047 Y727.7125 I1.6512 J-6.1712 F1200
G03 X539.4548 Y725.0783 I3.7903 J-9.3817 F1200
G01 X518.1286 Y704.8869 F1200
G00 Z-3.5000 F480
G01 X514.6648 Y701.6074 F1200
G01 Z-6.5000 F180
G01 X493.3387 Y681.4161 F1200
G03 X490.9156 Y675.5186 I6.2285 J-6.0056 F1200
G01 X490.9152 Y675.3537 F1200
G01 X490.9187 Y675.1512 F1200
G01 X490.9294 Y674.9066 F1200
G01 X492.7225 Y645.6289 F1200
G00 Z-3.5000 F480
G01 X493.0141 Y640.8679 F1200
G00 Z5.0000 F480
;No. 169: Part 18
G00 X673.4461 Y637.7999 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X673.3169 Y630.5853 F1200
G01 X672.2251 Y573.0212 F1200
G01 X672.2234 Y572.8597 F1200
G01 X672.2255 Y572.6347 F1200
G03 X680.4855 Y564.1835 I8.6519 J0.1941 F1200
G02 X716.4596 Y562.0723 I-21.2893 J-670.2956 F1200
G03 X725.6759 Y569.8649 I0.6024 J8.6340 F1200
G01 X727.5803 Y589.4690 F1200
G00 Z-3.5000 F480
G01 X728.0415 Y594.2166 F1200
G01 Z-6.5000 F180
G01 X728.8784 Y602.8317 F1200
G01 X731.3617 Y637.1455 F1200
G01 X732.3971 Y647.8038 F1200
G03 X731.4939 Y652.3227 I-7.1740 J0.9157 F1200
G03 X728.2127 Y656.5790 I-15.5745 J-8.6133 F1200
G03 X712.1131 Y672.5823 I-931.9776 J-921.4870 F1200
G01 X709.5919 Y675.0631 F1200
G00 Z-3.5000 F480
G01 X709.0563 Y675.5901 F1200
G01 X706.1900 Y678.4067 F1200
G01 Z-6.5000 F180
G03 X698.5645 Y685.8892 I-6665.0288 J-6784.8246 F1200
G01 X694.1889 Y690.1760 F1200
G01 X689.3735 Y694.8891 F1200
G01 X685.8694 Y698.3153 F1200
G03 X682.3194 Y700.6239 I-6.7080 J-6.4312 F1200
G03 X676.3828 Y698.7827 I-1.7441 J-4.8678 F1200
G03 X674.6918 Y694.3542 I7.5615 J-5.4245 F1200
G03 X674.5638 Y692.6791 I14.5321 J-1.9530 F1200
G01 X673.8324 Y659.3830 F1200
G01 X673.5314 Y642.5691 F1200
G00 Z-3.5000 F480
G01 X673.4461 Y637.7999 F1200
G00 Z5.0000 F480
;No. 170: Part 17
G00 X621.2837 Y532.8562 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X620.5811 Y499.9134 F1200
G01 X620.5815 Y499.7384 F1200
G03 X628.7514 Y491.3023 I8.5115 J0.0689 F1200
G02 X719.6480 Y482.2732 I-23.2068 J-695.6691 F1200
G01 X721.5240 Y481.9620 F1200
G01 X723.4002 Y481.6458 F1200
G03 X727.1045 Y481.8044 I1.4906 J8.5227 F1200
G03 X733.2747 Y492.5727 I-2.3957 J8.5247 F1200
G03 X731.7735 Y495.5696 I-8.4250 J-2.3460 F1200
G01 X717.9410 Y513.7175 F1200
G00 Z-3.5000 F480
G01 X715.0494 Y517.5112 F1200
G01 Z-6.5000 F180
G01 X701.2169 Y535.6592 F1200
G03 X696.1112 Y539.1188 I-7.4037 J-5.4293 F1200
G03 X695.6084 Y539.2167 I-1.6327 J-7.0410 F1200
G03 X686.1345 Y540.3314 I-63.7653 J-501.1133 F1200
G02 X681.9694 Y541.5031 I0.9388 J11.3263 F1200
G02 X681.1274 Y542.0554 I2.6124 J4.9012 F1200
G02 X679.9219 Y544.1140 I1.7227 J2.3910 F1200
G03 X679.2800 Y545.9277 I-8.0844 J-1.8408 F1200
G03 X676.2562 Y550.0644 I-15.2975 J-8.0087 F1200
G03 X672.5657 Y553.5904 I-48.0731 J-46.6221 F1200
G01 X672.3257 Y553.8199 F1200
G03 X656.2080 Y569.5872 I-3071.8227 J-3123.9641 F1200
G02 X654.5860 Y573.2025 I3.8566 J3.9017 F1200
G01 X650.8697 Y674.3304 F1200
G00 Z-3.5000 F480
G01 X650.7837 Y676.6711 F1200
G03 X650.4864 Y679.0802 I-44.4297 J-4.2600 F1200
G01 Z-6.5000 F180
G03 X636.6615 Y706.2633 I-47.5703 J-7.0865 F1200
G03 X635.9213 Y706.8259 I-4.9858 J-5.7913 F1200
G03 X629.1150 Y709.6270 I-11.5172 J-18.3154 F1200
G03 X626.8585 Y709.6887 I-1.2727 J-5.2503 F1200
G03 X625.0088 Y707.5110 I0.3767 J-2.1944 F1200
G01 X623.5837 Y640.6963 F1200
G00 Z-3.5000 F480
G01 X623.4820 Y635.9273 F1200
G01 Z-6.5000 F180
G01 X621.3854 Y537.6251 F1200
G00 Z-3.5000 F480
G01 X621.2837 Y532.8562 F1200
G00 Z5.0000 F480
;No. 171: Part 16
G00 X502.6899 Y520.6722 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X488.3908 Y503.0657 F1200
G03 X486.4309 Y497.7359 I6.5858 J-5.4470 F1200
G01 X486.4313 Y497.5276 F1200
G03 X486.4627 Y496.9042 I8.3771 J0.1100 F1200
G03 X496.2556 Y489.0116 I8.6511 J0.7123 F1200
G02 X586.3855 Y494.9714 I91.2493 J-695.4625 F1200
G03 X594.8852 Y503.5535 I-0.1545 J8.6531 F1200
G01 X595.1354 Y533.7133 F1200
G00 Z-3.5000 F480
G01 X595.1750 Y538.4831 F1200
G01 Z-6.5000 F180
G01 X596.0139 Y639.6048 F1200
G00 Z-3.5000 F480
G01 X596.0535 Y644.3746 F1200
G01 Z-6.5000 F180
G01 X596.6079 Y711.2078 F1200
G03 X594.5368 Y713.4826 I-2.2507 J0.0310 F1200
G03 X592.4219 Y713.2647 I-0.4951 J-5.5691 F1200
G03 X586.3111 Y710.2603 I5.6420 J-19.1919 F1200
G01 X586.1772 Y710.1526 F1200
G03 X571.6820 Y685.3073 I32.2020 J-35.4383 F1200
G03 X571.5797 Y684.5052 I8.4528 J-1.4862 F1200
G01 X569.6323 Y651.9160 F1200
G00 Z-3.5000 F480
G01 X569.3478 Y647.1545 F1200
G01 Z-6.5000 F180
G01 X565.3108 Y579.5952 F1200
G02 X564.0282 Y576.6170 I-5.3232 J0.5272 F1200
G01 X548.5957 Y560.5198 F1200
G01 X548.3205 Y560.2114 F1200
G02 X541.5687 Y553.2494 I-260.0563 J245.4475 F1200
G01 X541.0493 Y552.7121 F1200
G01 X540.7019 Y552.3491 F1200
G03 X538.7193 Y549.3878 I5.8010 J-6.0284 F1200
G02 X536.6101 Y546.8065 I-4.0974 J1.1955 F1200
G02 X532.9483 Y545.7186 I-4.4769 J8.3626 F1200
G01 X532.6813 Y545.6930 F1200
G01 X526.0335 Y545.1760 F1200
G03 X519.9963 Y541.9815 I0.7099 J-8.6436 F1200
G01 X505.6971 Y524.3749 F1200
G00 Z-3.5000 F480
G01 X502.6899 Y520.6722 F1200
G00 Z5.0000 F480
;No. 172: Part 23
G00 X492.8933 Y366.6318 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X495.8703 Y346.5164 F1200
G03 X501.4731 Y342.1710 I5.0764 J0.7605 F1200
G02 X521.5395 Y341.6994 I8.1942 J-78.4945 F1200
G03 X527.3665 Y345.7902 I0.7893 J5.0711 F1200
G01 X531.2924 Y365.7184 F1200
G00 Z-3.5000 F480
G01 X532.2144 Y370.3985 F1200
G01 Z-6.5000 F180
G01 X536.1403 Y390.3266 F1200
G03 X531.9357 Y396.3847 I-5.0362 J0.9928 F1200
G03 X493.6892 Y397.2919 I-22.2914 J-133.1109 F1200
G03 X489.1674 Y392.3302 I0.6096 J-5.0969 F1200
G01 X489.1657 Y392.1853 F1200
G03 X489.2179 Y391.4659 I5.2589 J0.0201 F1200
G01 X492.1949 Y371.3504 F1200
G00 Z-3.5000 F480
G01 X492.8933 Y366.6318 F1200
G00 Z5.0000 F480
;No. 173: Part 22
G00 X490.8738 Y439.7146 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X494.3282 Y419.6756 F1200
G03 X500.0327 Y415.4647 I5.0569 J0.8810 F1200
G02 X520.1046 Y415.4703 I10.0580 J-78.2775 F1200
G03 X525.8327 Y419.6985 I0.6686 J5.0884 F1200
G01 X529.2837 Y439.7144 F1200
G00 Z-3.5000 F480
G01 X530.0942 Y444.4150 F1200
G01 Z-6.5000 F180
G01 X533.5452 Y464.4309 F1200
G03 X529.5256 Y470.3306 I-5.0586 J0.8727 F1200
G03 X490.5866 Y470.3215 I-19.4383 J-132.5317 F1200
G03 X486.5379 Y465.3172 I1.0848 J-5.0176 F1200
G01 X486.5397 Y465.1723 F1200
G03 X486.6090 Y464.4543 I5.1792 J0.1376 F1200
G01 X490.0635 Y444.4153 F1200
G00 Z-3.5000 F480
G01 X490.8738 Y439.7146 F1200
G00 Z5.0000 F480
;No. 174: Part 21
G00 X547.1611 Y438.6732 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X543.8297 Y418.6152 F1200
G03 X543.7604 Y417.8264 I5.1056 J-0.8459 F1200
G01 X543.7609 Y417.6815 F1200
G03 X547.8072 Y412.7567 I5.1327 J0.0925 F1200
G03 X586.8237 Y412.9891 I18.7203 J132.3862 F1200
G03 X590.7577 Y418.9232 I-1.1162 J5.0110 F1200
G01 X587.1837 Y438.9193 F1200
G00 Z-3.5000 F480
G01 X586.3445 Y443.6149 F1200
G01 Z-6.5000 F180
G01 X582.7705 Y463.6110 F1200
G03 X577.0402 Y467.7868 I-5.0508 J-0.9113 F1200
G02 X556.9277 Y467.6621 I-10.5417 J78.2447 F1200
G03 X551.2740 Y463.4368 I-0.5975 J-5.0956 F1200
G01 X547.9426 Y443.3788 F1200
G00 Z-3.5000 F480
G01 X547.1611 Y438.6732 F1200
G00 Z5.0000 F480
;No. 175: Part 24
G00 X551.2997 Y369.1497 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X547.7982 Y349.1426 F1200
G03 X547.7213 Y348.2896 I5.0757 J-0.8871 F1200
G01 Y348.2096 F1200
G03 X552.2986 Y343.1509 I5.1392 J0.0500 F1200
G03 X590.3877 Y343.0811 I19.2896 J133.5797 F1200
G03 X594.7342 Y349.0007 I-0.7178 J5.0826 F1200
G01 X591.3303 Y369.0484 F1200
G00 Z-3.5000 F480
G01 X590.5319 Y373.7511 F1200
G01 Z-6.5000 F180
G01 X587.1281 Y393.7987 F1200
G03 X581.4342 Y398.0241 I-5.0585 J-0.8675 F1200
G02 X561.3624 Y398.0691 I-9.8603 J78.3024 F1200
G03 X555.6236 Y393.8554 I-0.6814 J-5.0867 F1200
G01 X552.1220 Y373.8483 F1200
G00 Z-3.5000 F480
G01 X551.2997 Y369.1497 F1200
G00 Z5.0000 F480
;No. 176: Part 25
G00 X610.3948 Y366.2635 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X613.6646 Y346.2154 F1200
G03 X619.3308 Y341.9531 I5.0640 J0.8345 F1200
G02 X639.4019 Y341.7773 I9.3503 J-78.3652 F1200
G03 X645.1680 Y345.9536 I0.7145 J5.0822 F1200
G01 X648.7998 Y365.9375 F1200
G00 Z-3.5000 F480
G01 X649.6527 Y370.6306 F1200
G01 Z-6.5000 F180
G01 X653.2844 Y390.6145 F1200
G03 X649.3183 Y396.5503 I-5.0505 J0.9183 F1200
G03 X610.3808 Y396.8930 I-20.6350 J-132.3390 F1200
G03 X606.2887 Y392.0055 I1.0391 J-5.0268 F1200
G01 X606.2869 Y391.8606 F1200
G03 X606.3571 Y391.0194 I5.2510 J0.0147 F1200
G01 X609.6269 Y370.9713 F1200
G00 Z-3.5000 F480
G01 X610.3948 Y366.2635 F1200
G00 Z5.0000 F480
;No. 177: Part 20
G00 X605.5364 Y439.3926 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X609.1554 Y419.4046 F1200
G03 X614.8951 Y415.2417 I5.0487 J0.9227 F1200
G02 X634.9662 Y415.4160 I10.7156 J-78.1902 F1200
G03 X640.6586 Y419.6922 I0.6258 J5.0939 F1200
G01 X643.9412 Y439.7364 F1200
G00 Z-3.5000 F480
G01 X644.7121 Y444.4437 F1200
G01 Z-6.5000 F180
G01 X647.9948 Y464.4879 F1200
G03 X643.9257 Y470.3536 I-5.0658 J0.8301 F1200
G03 X604.9882 Y470.0171 I-18.3235 J-132.6952 F1200
G03 X600.9828 Y465.1240 I1.1269 J-5.0083 F1200
G01 X600.9817 Y464.9790 F1200
G03 X601.0676 Y464.0743 I5.2006 J0.0371 F1200
G01 X604.6865 Y444.0863 F1200
G00 Z-3.5000 F480
G01 X605.5364 Y439.3926 F1200
G00 Z5.0000 F480
;No. 178: Part 19
G00 X664.2790 Y438.1665 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X661.3391 Y418.0183 F1200
G03 X661.2929 Y417.3654 I4.9809 J-0.6810 F1200
G01 X661.2928 Y417.2854 F1200
G03 X665.5172 Y412.2815 I5.1333 J0.0486 F1200
G03 X704.4429 Y413.2963 I16.0089 J132.9864 F1200
G03 X708.2594 Y419.3066 I-1.2150 J4.9884 F1200
G01 X704.2927 Y439.2285 F1200
G00 Z-3.5000 F480
G01 X703.3613 Y443.9067 F1200
G01 Z-6.5000 F180
G01 X699.3946 Y463.8286 F1200
G03 X693.5832 Y467.8909 I-5.0319 J-1.0105 F1200
G02 X673.4742 Y467.3708 I-12.0794 J78.0251 F1200
G03 X667.9075 Y463.0348 I-0.4939 J-5.1073 F1200
G01 X664.9677 Y442.8866 F1200
G00 Z-3.5000 F480
G01 X664.2790 Y438.1665 F1200
G00 Z5.0000 F480
;No. 179: Part 26
G00 X667.0692 Y361.8412 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X664.3299 Y341.6937 F1200
G03 X664.2833 Y341.0479 I5.1446 J-0.6963 F1200
G01 X664.2839 Y340.9032 F1200
G03 X668.5570 Y335.9409 I5.1325 J0.0987 F1200
G03 X707.4710 Y337.3363 I14.7077 J133.1407 F1200
G03 X711.2285 Y343.3836 I-1.2632 J4.9760 F1200
G01 X707.0672 Y363.2658 F1200
G00 Z-3.5000 F480
G01 X706.0900 Y367.9346 F1200
G01 Z-6.5000 F180
G01 X701.9287 Y387.8168 F1200
G03 X696.0779 Y391.8220 I-5.0218 J-1.0597 F1200
G02 X676.0190 Y391.1018 I-12.8384 J77.8700 F1200
G03 X670.4510 Y386.7151 I-0.4870 J-5.1088 F1200
G01 X667.7118 Y366.5677 F1200
G00 Z-3.5000 F480
G01 X667.0692 Y361.8412 F1200
G00 Z5.0000 F480
;No. 180: Part 9
G00 X542.4711 Y298.5657 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X508.0857 Y296.3618 F1200
G03 X499.9727 Y287.7311 I0.5367 J-8.6330 F1200
G02 X498.7898 Y253.3982 I-242.9861 J-8.8145 F1200
G01 X498.7804 Y253.1766 F1200
G01 X498.7775 Y253.0433 F1200
G01 X498.7767 Y252.9100 F1200
G03 X506.3101 Y244.3814 I8.6577 J0.0560 F1200
G01 X540.0246 Y239.8388 F1200
G00 Z-3.5000 F480
G01 X544.7519 Y239.2018 F1200
G01 Z-6.5000 F180
G01 X680.3412 Y220.9325 F1200
G00 Z-3.5000 F480
G01 X685.0685 Y220.2956 F1200
G01 Z-6.5000 F180
G01 X720.6292 Y215.5041 F1200
G03 X730.4028 Y223.1032 I1.1559 J8.5980 F1200
G03 X733.1247 Y301.9578 I-471.5146 J55.7501 F1200
G03 X723.8874 Y310.1931 I-8.6647 J-0.4208 F1200
G01 X692.7820 Y308.1995 F1200
G00 Z-3.5000 F480
G01 X688.0218 Y307.8944 F1200
G01 Z-6.5000 F180
G01 X547.2313 Y298.8708 F1200
G00 Z-3.5000 F480
G01 X542.4711 Y298.5657 F1200
G00 Z5.0000 F480
;No. 181: Part 3
G00 X503.9370 Y195.4079 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X499.3109 Y192.9567 F1200
G03 X495.1350 Y187.9382 I4.0749 J-7.6374 F1200
G01 X493.7706 Y183.5833 F1200
G03 X493.3852 Y181.1280 I8.2812 J-2.5578 F1200
G01 X493.3847 Y180.9893 F1200
G03 X499.7469 Y172.6735 I8.6790 J0.0484 F1200
G01 X532.6940 Y163.6084 F1200
G02 X536.5982 Y157.1338 I-1.4480 J-5.2876 F1200
G03 X524.1791 Y63.6599 I351.1898 J-94.2215 F1200
G01 X524.1797 Y62.2429 F1200
G03 X524.9748 Y39.2162 I358.3047 J0.8456 F1200
G03 X534.4070 Y31.1773 I8.6456 J0.5911 F1200
G01 X551.6113 Y32.6932 F1200
G00 Z-3.5000 F480
G01 X556.3628 Y33.1118 F1200
G01 Z-6.5000 F180
G01 X573.5671 Y34.6277 F1200
G03 X581.4535 Y43.7295 I-0.7667 J8.6318 F1200
G02 X580.8296 Y62.3745 I301.8468 J19.4319 F1200
G01 X580.8289 Y63.5717 F1200
G02 X599.1381 Y167.2354 I305.4822 J-0.5057 F1200
G03 X593.9936 Y177.8803 I-8.2802 J2.5638 F1200
G01 X573.7956 Y185.7499 F1200
G00 Z-3.5000 F480
G01 X569.3510 Y187.4816 F1200
G01 Z-6.5000 F180
G01 X526.7327 Y204.0867 F1200
G03 X519.5115 Y203.6602 I-3.1462 J-8.0754 F1200
G01 X508.1519 Y197.6412 F1200
G00 Z-3.5000 F480
G01 X503.9370 Y195.4079 F1200
G00 Z5.0000 F480
;No. 182: Part 2
G00 X284.0276 Y119.6059 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X276.6482 Y110.1496 F1200
G03 X274.7886 Y104.8275 I6.6888 J-5.3231 F1200
G03 X281.5743 Y96.3321 I8.7792 J0.0546 F1200
G03 X285.1752 Y96.3206 I1.8275 J8.4831 F1200
G02 X436.7798 Y94.5032 I72.0452 J-314.3230 F1200
G02 X440.7318 Y87.1406 I-1.8528 J-5.7365 F1200
G01 X434.3705 Y64.2632 F1200
G00 Z-3.5000 F480
G01 X433.0926 Y59.6675 F1200
G01 Z-6.5000 F180
G01 X426.7313 Y36.7902 F1200
G03 X426.3930 Y34.3802 I8.9070 J-2.4789 F1200
G01 X426.3944 Y34.1416 F1200
G03 X432.8421 Y25.5374 I9.1861 J0.1658 F1200
G02 X441.8601 Y22.5681 I-75.8137 J-245.4345 F1200
G03 X453.4777 Y27.9969 I3.0166 J8.6895 F1200
G01 X480.4602 Y98.4534 F1200
G00 Z-3.5000 F480
G01 X482.1662 Y102.9079 F1200
G01 Z-6.5000 F180
G01 X495.2309 Y137.0225 F1200
G03 X489.7624 Y148.9805 I-8.6026 J3.2953 F1200
G03 X469.5263 Y155.6439 I-132.8400 J-369.3629 F1200
G03 X458.0154 Y149.2980 I-2.6388 J-8.8262 F1200
G01 X453.6436 Y133.5783 F1200
G02 X446.4529 Y129.4149 I-5.7866 J1.7029 F1200
G03 X299.5890 Y136.0307 I-89.2555 J-347.9589 F1200
G03 X294.3417 Y132.8226 I1.5991 J-8.5111 F1200
G01 X286.9622 Y123.3663 F1200
G00 Z-3.5000 F480
G01 X284.0276 Y119.6059 F1200
G00 Z5.0000 F480
;No. 183: Part 4
G00 X35.6011 Y158.7890 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X42.9268 Y137.4427 F1200
G03 X53.8177 Y132.0226 I8.1899 J2.8046 F1200
G02 X67.9801 Y136.5490 I220.8460 J-666.5744 F1200
G02 X204.6997 Y163.8315 I203.6675 J-664.4204 F1200
G03 X205.1971 Y164.0185 I-0.3556 J1.7010 F1200
G02 X272.9622 Y167.1484 I65.2042 J-676.5673 F1200
G01 X273.1201 Y167.1303 F1200
G02 X416.0661 Y151.6253 I-1.9744 J-684.8899 F1200
G03 X426.3333 Y158.2162 I1.8157 J8.4640 F1200
G01 X432.2541 Y184.5603 F1200
G00 Z-3.5000 F480
G01 X433.3000 Y189.2142 F1200
G01 Z-6.5000 F180
G01 X439.2209 Y215.5582 F1200
G03 X432.5615 Y225.9448 I-8.4657 J1.9003 F1200
G03 X376.1221 Y235.9372 I-160.7929 J-743.8061 F1200
G00 Z-3.5000 F480
G03 X371.3952 Y236.5767 I-87.6306 J-629.9669 F1200
G01 Z-6.5000 F180
G03 X360.7499 Y237.9066 I-98.0908 J-741.8780 F1200
G03 X354.2855 Y236.0316 I-1.0058 J-8.6131 F1200
G01 X311.9709 Y201.9593 F1200
G02 X308.5447 Y200.7469 I-3.4340 J4.2574 F1200
G03 X162.7868 Y193.5950 I-37.6789 J-720.9572 F1200
G02 X159.5116 Y194.3192 I-0.5138 J5.4443 F1200
G01 X110.8528 Y223.6715 F1200
G03 X104.5843 Y224.7361 I-4.4858 J-7.4265 F1200
G03 X97.1976 Y223.0603 I160.7860 J-725.8518 F1200
G00 Z-3.5000 F480
G03 X92.5544 Y221.9678 I164.6609 J-710.2715 F1200
G01 Z-6.5000 F180
G03 X29.2927 Y203.9977 I178.5909 J-749.0436 F1200
G03 X23.4449 Y195.8408 I2.8398 J-8.2105 F1200
G01 X23.4462 Y195.6560 F1200
G03 X23.9193 Y192.9769 I8.6835 J0.1521 F1200
G01 X34.9690 Y160.6673 F1200
G00 Z-3.5000 F480
G01 X34.9709 Y160.6617 F1200
G01 X34.5198 Y161.9808 F1200
G03 X35.6011 Y158.7890 I195.6704 J64.5146 F1200
G00 Z5.0000 F480
;No. 184: Part 1
G00 X71.1618 Y94.4983 Z5.0000 F2100
G00 Z0.5000 F480
G01 Z-6.5000 F180
G01 X40.9992 Y99.8672 F1200
G03 X30.9125 Y92.6801 I-1.5215 J-8.5362 F1200
G03 X25.8732 Y35.3910 I405.5576 J-64.5401 F1200
G03 X34.5329 Y26.8266 I8.6700 J0.1062 F1200
G01 X68.3290 Y26.8282 F1200
G00 Z-3.5000 F480
G01 X73.0990 Y26.8284 F1200
G01 Z-6.5000 F180
G01 X286.9160 Y26.8382 F1200
G00 Z-3.5000 F480
G01 X291.6860 Y26.8384 F1200
G01 Z-6.5000 F180
G01 X346.5670 Y26.8410 F1200
G03 X355.0687 Y34.6285 I-0.1030 J8.6469 F1200
G01 X355.1816 Y35.9099 F1200
G03 X348.1153 Y45.2015 I-8.5739 J0.8123 F1200
G01 X293.5441 Y54.9150 F1200
G00 Z-3.5000 F480
G01 X288.8479 Y55.7509 F1200
G01 Z-6.5000 F180
G01 X75.8580 Y93.6624 F1200
G00 Z-3.5000 F480
G01 X71.1618 Y94.4983 F1200
G00 Z5.0000 F480
G00 X0.0000 Y0.0000 F2100
M05
I tried attaching a .nc file last time and it was denied by the server, I could probably change the extension to .txt next time.
