Whenever I send a manual control move command, it sometimes moves immediately, while taking close to 30+seconds sometimes to move. I also get a lot of
“communication timeout- reset send buffer block”
as well as
“No start signal detected -forcing start”
My log looks like:
14:33:07.102 : OpenGL version:4.6.0 NVIDIA 398.36
14:33:07.102 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NVX_blend_equation_advanced_multi_draw_buffers GL_NV_blend_minmax_factor GL_NV_blend_square GL_NV_clip_space_w_scaling GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_conservative_raster_pre_snap_triangles GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_float64 GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_stereo_view_rendering GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
14:33:07.103 : OpenGL renderer:GeForce GTX 1050 Ti/PCIe/SSE2
14:33:07.103 : Using fast VBOs for rendering is possible
14:34:03.264 : The parameter is incorrect.
14:34:03.264 :
14:34:13.299 : No start signal detected - forcing start
14:34:13.320 : N1 M11034
14:34:13.320 : N2 M11536
14:34:13.320 : N3 M10536
14:34:13.320 : N4 M11435
14:34:13.320 : N5 M111 S698
14:34:13.326 : N6 T060
14:34:13.326 : N7 M2022
14:34:13.326 : N8 M8019
14:34:13.326 : N9 M10546
14:34:16.363 : N10 M10522
14:34:56.391 : Communication timeout - reset send buffer block
14:34:56.391 : N11 M10523
14:34:56.394 : N12 G1 Y1 F210054
14:34:59.240 : N13 M10521
14:35:02.304 : N14 M10518
14:35:05.367 : N15 M10519
14:35:08.430 : N16 M10516
14:35:11.490 : N17 M10517
14:35:14.549 : N18 M10530
14:35:17.613 : N19 M10531
14:35:57.639 : Communication timeout - reset send buffer block
14:35:57.639 : N20 M10521
14:36:00.488 : N21 M10520
14:36:03.555 : N22 M10523
14:36:06.617 : N23 M10522
14:36:09.679 : N24 M10517
14:36:12.737 : N25 M10516
14:36:15.800 : N26 M10519
14:36:18.860 : N27 M10518
14:36:21.925 : N28 M10529
14:37:01.954 : Communication timeout - reset send buffer block
14:37:01.954 : N29 M10528
14:37:04.798 : N30 M10520
14:37:07.866 : N31 M10521
14:37:10.927 : N32 M10522
14:37:13.986 : N33 M10523
14:37:17.050 : N34 M10516
14:37:20.114 : N35 M10517
14:37:23.179 : N36 M10518
14:37:26.241 : N37 M10519
14:38:00.908 : No start signal detected - forcing start
14:38:00.910 : N1 M11034
14:38:00.910 : N2 M11536
14:38:00.910 : N3 M10536
14:38:00.910 : N4 M11435
14:38:00.962 : N5 M111 S698
14:38:18.559 : N6 T060
14:38:18.559 : N7 M2022
14:38:18.561 : N8 M8019
14:38:18.561 : N9 M10546
14:38:18.562 : N10 G1 Y10 F21004
14:38:58.661 : Communication timeout - reset send buffer block
14:38:58.661 : N11 M10523
14:38:58.661 : N12 G1 Y20 F21005
14:38:59.095 : N13 M10521
14:39:02.162 : N14 M10518
14:39:05.220 : N15 M10519
14:39:08.281 : N16 M10516
14:39:11.349 : N17 M10517
14:39:14.407 : N18 M10530
14:39:17.474 : N19 M10531
14:39:57.504 : Communication timeout - reset send buffer block
14:39:57.504 : N20 M10521
14:39:57.504 : N21 G1 Y70 F21000
14:40:00.347 : N22 M10523
14:40:03.409 : N23 M10522
14:40:06.470 : N24 M10517
14:40:09.535 : N25 M10516
14:40:12.600 : N26 M10519
14:40:15.661 : N27 M10518
14:40:18.725 : N28 M10529
14:40:58.754 : Communication timeout - reset send buffer block
14:40:58.754 : N29 M10528
14:41:01.597 : N30 M10520
14:41:04.658 : N31 M10521
14:41:07.721 : N32 M10522
14:41:10.786 : N33 M10523
14:41:13.850 : N34 M10516
14:41:16.912 : N35 M10517
14:41:19.972 : N36 M10518
14:41:23.033 : N37 M10519
14:42:03.065 : Communication timeout - reset send buffer block
14:42:03.065 : N38 M10528
14:42:05.909 : N39 M10529
14:42:08.969 : N40 M10519
14:42:12.033 : N41 M10518
14:42:15.096 : N42 M10517
14:42:18.160 : N43 M10516
14:42:21.226 : N44 M10523
14:42:24.282 : N45 M10522
14:42:27.346 : N46 M10521
14:43:07.376 : Communication timeout - reset send buffer block
14:43:07.376 : N47 M10520
14:43:10.227 : N48 M10527
14:43:13.286 : N49 M10526
14:43:16.349 : N50 M10518
14:43:19.414 : N51 M10519
14:43:19.599 : N52 G1 Y80 F210011
14:43:21.735 : N53 G1 X10 F21002
14:43:22.470 : N54 M10522
14:44:02.504 : Communication timeout - reset send buffer block
14:44:02.504 : N55 G1 X11 F21005
14:44:02.504 : N56 M10520
14:44:02.504 : N57 G1 X60 F21001
14:44:05.347 : N58 M10526
14:44:08.410 : N59 M10527
14:44:11.475 : N60 M10517
14:44:14.532 : N61 M10516
14:44:17.596 : N62 M10519
14:44:57.629 : Communication timeout - reset send buffer block
14:44:57.629 : N63 M10518
14:45:00.471 : N64 M10521
14:45:03.534 : N65 M10520
14:45:06.601 : N66 M10523
14:45:09.658 : N67 M10522
14:45:12.721 : N68 M10525
14:45:15.787 : N69 M10524
14:45:18.851 : N70 M10516
14:45:21.911 : N71 M10517
14:46:01.939 : Communication timeout - reset send buffer block
14:54:08.249 : No start signal detected - forcing start
14:54:08.250 : N1 M11034
14:54:08.250 : N2 M11536
14:54:08.250 : N3 M10536
14:54:08.250 : N4 M11435
14:54:08.333 : N5 M111 S698
14:54:08.335 : N6 T060
14:54:08.335 : N7 M2022
14:54:08.335 : N8 M8019
14:54:08.335 : N9 M10546
14:54:11.429 : N10 M10522
14:54:51.452 : Communication timeout - reset send buffer block
14:54:51.452 : N11 M10523
14:54:51.453 : N12 G1 X10 F21007
14:54:54.303 : N13 M10521
14:54:57.365 : N14 M10518
14:55:00.423 : N15 M10519
14:55:03.486 : N16 M10516
14:55:06.548 : N17 M10517
14:55:09.610 : N18 M10530
14:55:12.675 : N19 M10531
14:55:52.704 : Communication timeout - reset send buffer block
14:55:52.704 : N20 M10521
14:55:55.555 : N21 M10520
14:55:58.612 : N22 M10523
14:56:01.675 : N23 M10522
14:56:04.736 : N24 M10517
14:56:05.600 : N25 G1 X11 F21002
14:56:07.764 : N26 G1 X21 F21002
14:56:07.802 : N27 M10518
14:56:47.833 : Communication timeout - reset send buffer block
14:56:47.833 : N28 G1 Y10 F210015
14:56:47.833 : N29 M10528
14:56:50.677 : N30 M10520
14:56:53.740 : N31 M10521
14:56:56.798 : N32 M10522
14:56:59.863 : N33 M10523
14:57:02.928 : N34 M10516
14:57:05.991 : N35 M10517
14:57:09.048 : N36 M10518
14:57:49.077 : Communication timeout - reset send buffer block
14:57:49.077 : N37 M10519
14:57:51.928 : N38 M10528
14:57:54.990 : N39 M10529
14:57:58.050 : N40 M10519
14:58:01.112 : N41 M10518
14:58:04.176 : N42 M10517
14:58:07.237 : N43 M10516
14:58:10.302 : N44 M10523
14:58:13.364 : N45 M105*22
The machine works, but I’d love to iron out the kinks of the constant communication timeouts and forced starts.
Any ideas as to what the issue is?
