powered up the board, got a green light, Repetier says it can’t connect doesn’t see the “printer”. I’ve looked on the setup page here but the software has changed so I can’t tell if I have the settings correct.
any ideas?
thank you!
UPDATE!
I realize now the instructions for the Repetier settings are for a PC, so I hooked up my PC and the board works fine and my stepper motors move as commanded???
so I’m still perplexed as to why my Mac doesn’t see it, secondly can I spit out the gcode from Fusion on my Mac and use it in Repetier on my PC?
Yeah. Gcode is windows/mac/linux/[gcode sender] agnostic. Gcode is tailored to the device that interprets the gcode which in most of our cases is marlin (rambo/ramps/etc).
Thanks guys for your responses, reflashing the board seems like a long convoluted process, so I might just go with spitting the gcode out and using it on the PC
