Hi ! I need your help ! I had build my Mpcnc with rambo 1.3 and titan E3D extrudeur.
I use Repetier to print but I had some problem :
I have a bed, all is leveled, but when i’m printing there is no adherence… I try with more ° to print…no difference… I use 1.75mm PLA from 3motions tech, and I have 0.4 nozzle
I copy to you my config in repetier : (Cura engine ) I think the problem is from here !
and when, why lot of luck,it’s “good” my print is wrong size… ( all my motor are well calibrated,my extrudeur to ! )
[print]
name = new
defaultQuality = MB4qEmF2LxIlvcZWD6Nygqpc2jaeb0vX
travelSpeedMin = 20
travelSpeedMax = 35
firstLayerSpeedMin = 15
firstLayerSpeedMax = 15
infillSpeedMin = 20
infillSpeedMax = 35
skinSpeedMin = 20
skinSpeedMax = 35
infillType = 1
innerPerimeterMin = 20
innerPerimeterMax = 35
outerPerimeterMin = 20
outerPerimeterMax = 35
printSpeedMin = 20
printSpeedMax = 35
nozzleDiameter = 0.4
gcodeFlavour = 0
retractionCombing = True
combing = 1
multiVolumeOverlap = 0
cutOffObjectBottom = 0
shellThickness = 0.2752
infillTopBottomThickness = 0.26
infillDensityPercent = 20
supportType = 0
platformAdhesion = 0
dualExtrusion = 0
wipeAndPrimeTower = True
oozeShield = False
enableRetraction = True
retractionSpeed = 30
retractionDistance = 1
multiExtruderSwitchAmount = 16
startGCode = “”"
; Default start code
G28 ; Home extruder
G1 Z15 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
{IF_BED}M190 S{BED}
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
endGCode = “”"
; Default end code
;G1 X0 Y0 Z130 ; Get extruder out of way. Uncomment to use!
M107 ; Turn off fan
; Disable all extruder
G91 ; Relative positioning
{IF_EXT0}T0
{IF_EXT0}G1 E-1 ; Reduce filament pressure
M104 T0 S0
M140 S0 ; Disable heated bed
M84 ; Turn steppers off
preSwitchExtruderCode =
postSwitchExtruderCode =
wipeAndPrimeTowerVolume = 15
retractionMinimumTravel = 1.5
minimumExtrusionBeforeRetract = 1.5
zhop = 0
skirtLineCount = 3
skirtDistance = 0
skirtMinimumLength = 150
solidInfillTop = True
solidInfillBottom = True
infillOverlapPercent = 50
supportStructureType = 0
supportOverhang = 50
supportFillPercent = 35
supportDistanceXY = 0.8
supportDistanceZ = 0.16
supportExtruder = -1
spiralizeOuterContour = False
brimWidth = 3
raftExtraMargin = 5
raftLineSpacing = 0.8
raftBaseThickness = 0.12
raftBaseWidth = 0.8
raftInterfaceThickness = 0.2
raftInterfaceLineWidth = 0.8
raftAirGap = 0
raftAirGapLayer0 = 0
raftSurfaceLayer = 1
fixCombineEverythingA = True
fixCombineEverythingB = False
fixKeepOpenFaces = False
fixExtensiveStitching = False
fanFullAtHeight = 1
perimeterBeforeInfill = True
minimumSpeed = 10
coolHeadLift = False
numQuality = 1
[quality_0]
name = 1 mm
signature = MB4qEmF2LxIlvcZWD6Nygqpc2jaeb0vX
layerHeight = 0.1
layer0widthPercent = 20
firstLayerHeight = 0.1
