Do you guys have a case that I can print to house these cards for my mpcnc? What do you recommend? Just want one to sit on a desktop for the time being.
I like this one…
This one is just alright …
This is the one I use: http://www.thingiverse.com/thing:1029926
It works great, only caveat was I had to ditch the knob and use the one that came with the board (not really a big issue) and the hinge came out a little rough due to supports.
Is there something special about the ramps board from you guys? It seems that most cases I’ve tried, the power connector is in the wrong location. It’s a little too far to the outside edge of the board (to the right when looking at the connector).
Just wondering…
Make sure it is designed for the current ramps 1.4, there are still some earlier designs out there. We don’t use the mega power port just the ramps plug.
Figured it out. The connector is soldered on slightly skewed to the right.
So I’ve got lots of used plastic now. Fixed a few issues with my 3d prints along the way. But even though, many of the cases, even though they say they are for the RAMPS 1.4, don’t line up with my board at all. The connectors seem to be on the board in the appropriate positions as marked on the board, but don’t line up with most cases. Compared to my other RAMPS 1.4 board, the connectors are not in the same positions at all. My other board lines up perfectly.
What gives…? Any ideas Vicious1?
Are you sure your other board is a ramps 1.4?
Can you upload some pics please.
I have never noticed. All the cases I have made I used the arduino specs and they seemed to fit.
Feel free to send it back for a refund.
File 2
K, guess I’d have to make the files smaller. Stand by.
I just checked the adafruit specs and the holes match, (one doesn’t have dimensions).
I don’t have eagle so I can’t use the arduino layout.
Here are comparisons between my boards and the ones I got from you guys.
- connectors on 2560 don’t line up with original.
- reset switch on the Arduino doesn’t line up with original.
- screw holes on the Arduino don’t line up with Either 2560 or my Original Arduino.
So, put another way.
- 2560 connectors misaligned.
- Arduino reset misaligned.
- Arduino holes misaligned.
Please confirm this but that’s what I can tell with what I have here. I have a pile of plastic in the recycle parts bin to prove it :(. Those pieces btw fit my original h/w perfectly.
I’m not sure what you want me to do, You are welcome to return it, no problem. The specs match from what I can see, all soldered components have a tolerance and will always vary much more so in through hole mounts. The holes match on the board and the ramps.
If it’s just a case that doesn’t fit, what one is it?
Did you get your mega from arduino? The bottom will be white if it is.
Again, what would you like me to do?
All this was ordered from you guys. The mega is not from Arduino. It has the chinese chip on it. The RAMPS is also not from Arduino but rather www.bigtree-tech.com.
Electronically they work, but it’s annoying spending days trying to figure out why stuff don’t fit, second guessing your printer and so forth. If it doesn’t fit for me, it ain’t gonna fit any better for others. Just want people to know.
Tried the following from thingiverse:
and several others.
I don’t want you to do anything other than just let others know so they don’t end up wasting their time either. That’s all.
Other than that, loving my mpcnc. Not cutting anything yet but soon…
Most RAMPs and Arduino clones don’t exactly match the originals. I recently ordered a RAMPS clone from Amazon and the pins below the board are out of whack but they work
I’m currently using the Minions enclosure and I actually need to file/remove stuff to fit the boards which I expected before printing it.
I’m adding new hardware like the Pi and laser driver so I’m switching to the modular enclosure (http://www.thingiverse.com/thing:1045751) which doesn’t really need an exact placement of the ports
Sorry Vicious1. My 2560 is from Arduino yes. The bottom is white. Got it with my Ecksbot 2014 that I purchased from Ecketech in Toronto.
