I have purchased the kit with the full Rambo, and was trying to manually move it via the Repetier software. The axis did’t move when I tried, so I unplugged the Rambo and plugged it back in. However, the Rambo didn’t turn back on. I have checked everything, the connections and outlet, and nothing seems out of the ordinary. Is there a way to get it back on?
Edit: I just checked the voltage of the connector to the Rambo, and it was correct. This leads me to believe that it is a problem with the Rambo. I know about this other topic: https://www.v1engineering.com/forum/topic/rambo-does-not-power-up/ however, I have tried the solution and it sadly did not work for me. Maybe a fuse is out?
