Hello,
I am very new to the MPCNC community, so I don’t know much, but I have run into a problem. Whenever I try to use my board in Repetier, it gives me a kill() error caused by the kill button. I have tried to flash the board (I got the Rambo 1.4 kit), following the instruction in this discussion: https://www.v1engineering.com/forum/topic/kill-caused-by-kill-button-pin/ but I am getting this error message on the Arduino software (note that I have followed the instructions step-by-step):
sketch\src\lcd\dogm\u8g_dev_ssd1306_sh1106_128x64_I2C.cpp: In function ‘uint8_t u8g_dev_sh1106_128x64_2x_2_wire_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_ssd1306_sh1106_128x64_I2C.cpp:117:29: error: ‘U8G_SPI_CLK_CYCLE_300NS’ was not declared in this scope
u8g_InitCom(u8g, dev, U8G_SPI_CLK_CYCLE_300NS);
sketch\src\lcd\dogm\u8g_dev_ssd1306_sh1106_128x64_I2C.cpp: In function ‘uint8_t u8g_dev_ssd1306_128x64_2x_2_wire_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_ssd1306_sh1106_128x64_I2C.cpp:185:29: error: ‘U8G_SPI_CLK_CYCLE_300NS’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp: In function ‘uint8_t u8g_dev_st7920_128x64_HAL_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp:111:29: error: ‘U8G_SPI_CLK_CYCLE_400NS’ was not declared in this scope
u8g_InitCom(u8g, dev, U8G_SPI_CLK_CYCLE_400NS);
sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp: In function ‘uint8_t u8g_dev_st7920_128x64_HAL_4x_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_st7920_128x64_HAL.cpp:154:29: error: ‘U8G_SPI_CLK_CYCLE_400NS’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function ‘int lcd_put_wchar_max(uint32_t, pixel_len_t)’:
sketch\src\lcd\dogm\lcdprint_u8g.cpp:36:24: error: ‘class U8GLIB_ST7920_128X64_RRD’ has no member named ‘getPrintCol’; did you mean ‘setPrintPos’?
unsigned int x = u8g.getPrintCol(),
setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:23: error: ‘ret’ was not declared in this scope
u8g.setPrintPos(x + ret, y);
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function ‘int lcd_put_u8str_max(const char*, pixel_len_t)’:
sketch\src\lcd\dogm\lcdprint_u8g.cpp:45:24: error: ‘class U8GLIB_ST7920_128X64_RRD’ has no member named ‘getPrintCol’; did you mean ‘setPrintPos’?
setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:23: error: ‘ret’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function ‘int lcd_put_u8str_max_P(const char*, pixel_len_t)’:
sketch\src\lcd\dogm\lcdprint_u8g.cpp:53:24: error: ‘class U8GLIB_ST7920_128X64_RRD’ has no member named ‘getPrintCol’; did you mean ‘setPrintPos’?
setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:23: error: ‘ret’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp: In function ‘uint8_t u8g_dev_uc1701_mini12864_HAL_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp:115:29: error: ‘U8G_SPI_CLK_CYCLE_300NS’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp: In function ‘uint8_t u8g_dev_uc1701_mini12864_HAL_2x_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_uc1701_mini12864_HAL.cpp:144:29: error: ‘U8G_SPI_CLK_CYCLE_300NS’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp: In function ‘uint8_t u8g_dev_st7565_64128n_HAL_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp:154:29: error: ‘U8G_SPI_CLK_CYCLE_400NS’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp: In function ‘uint8_t u8g_dev_st7565_64128n_HAL_2x_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp:188:29: error: ‘U8G_SPI_CLK_CYCLE_400NS’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_tft_320x240_upscale_from_128x64.cpp: In function ‘uint8_t u8g_dev_tft_320x240_upscale_from_128x64_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_tft_320x240_upscale_from_128x64.cpp:130:42: error: ‘U8G_SPI_CLK_CYCLE_NONE’ was not declared in this scope
dev->com_fn(u8g, U8G_COM_MSG_INIT, U8G_SPI_CLK_CYCLE_NONE, &lcd_id);
sketch\src\lcd\dogm\u8g_dev_tft_320x240_upscale_from_128x64.cpp:130:42: note: suggested alternative: ‘U8G_I2C_ERR_NONE’
U8G_I2C_ERR_NONE
Multiple libraries were found for “U8glib.h”
Used: C:\Users\colby\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\libraries\U8glib
Multiple libraries were found for “SPI.h”
Used: C:\Program
exit status 1
Error compiling for board RAMBo.
I have tried everything, downloading different Arduino versions, and even tried on an apple machine (currently on windows 10). What can I do from here?
