so, as I figured, software/firmware is not going as easily as I hoped. I have installed the RAMBO drivers, followed step-by-step instructions on V1 site, open COM ports, installed Arduino libraries and boards, and tried on both Arduino IDE and Platformio. … keep getting the following message. Been trying to troubleshoot for a few hours so decided id take it to the forum. thanks in advance
Uploading .pio\build\rambo\firmware.hex
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
*** [upload] Error 1
=================================================== [FAILED] Took 68.86 seconds ===================================================
Environment Status Duration
rambo FAILED 00:01:08.862
============================================== 1 failed, 0 succeeded in 00:01:08.862 ==============================================
The terminal process “C:\Users\Juan Carlos.platformio\penv\Scripts\platformio.exe ‘run’, ‘–target’, ‘upload’” terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
