Racking in Y Axis Travel
Afternoon All,
I believe i have already undertaken the obvious steps but I’m not getting anywhere so far.
New build LR4 with Jackpot 3 CNC Controller, I’m using the pre-loaded Yaml file from Ryan. Bed is 1220 x 2440 on 30mm tube. Initially I was setup with a the same controller I flashed myself from Elecrow.
Yet to make a cut! When trying to get set-up the Y travel on x min is travelling the correct distance, consistantly. Y travel on X max side is gaining with each travel, ie. if I request g0 y500 travel is going 525. follow this with G0 Y10 and the machine hits the belt mount for the Y axis on the X max side. So looks to be gaining in both directions of travel. If it was steps per mm travelling to Y10 should return the gantry to Y10.
I’ve checked grub screws on the motor pulley. Any other suggestions please? This is my first machine on a Fluid NC controller, although not my first cnc.
Thanks in advance
Are the pulleys on your Ymin and Ymax both the same size and teeth count? We’ve seen occasional mix-ups in the supplier parts.
Solved this one and created another issue…
The issue came down to travel rates, the default in the Yaml was 9500m/min obviously too fast therefore missing steps unevenly between the two sides.
New issue - Travel is over-travelling but not an obvious scaling issue. Ignoring scaling for a moment if i run a g28 x 1000 command, machine should run out to x1000 and return to X0, system says x0 reality is x-3 on the first run, X-6 on the second, x-9 on the third. Y axis is similar, rate of travel at 3500mm/min on both.
Any suggestions? Thanks
This does not make sense. What exact code are you running?
G28, are you running a Marlin board? If you are not using a V1 kit and board please save us lot of questions and tellus or show us what you are using.
9500 should actually be okay for travel moves. This again points to using non-standard parts.
Hi Ryan,
In the original post in the thread, I had listed I’m running a Jackpot 3 supplied by yourself. Apologies if this has got lost as we moved on.
In the terminal the code I am using is “G28 X1000” if it’s not one your familiar with G28 is quite handy, it’s moved to a predefined position (in this case 0,0,0).
My issue comes in that regardless of how I move the machine, even if I just use the jog buttons via my laptop, if I move out 1m and return 1m the machine believes it has returned to the same place but has actually ended negative of where it has started.
The confusion comes that the error is repeatable and consistent, effecting both X and Y axis. If the error were simple scaling the machine should return to the same zero point.
I don’t believe I’m missing steps, the level of consistency would also suggest this is not the case. I’ve made numerous changes to the Yaml with no gain of improvement today, it also seems very strange given generally everyone seems to get this right as is, out the box.
Thanks for any help, perhaps a video might be in order to see if I can explain it better.
Yup I missed that, apologies on my end. What about the steppers?
I have never used that. I am reading that like move to x=1000, not 0,0,0. But I have not used this in fluidnc, maybe a bug. I would suggest trying regular travle moves to be sure.
Someone else had this with a 3 mm difference. I cannot remember what the solution was.
Are you sure you are setting the machine and workspace coordinates to 0, on all axis? The predefined firmware does not start at zero, that gets some people.
What firmware are you running, and what UI and version?
So a bit more about the machine:
Steppers - I believe are a direct match for yours datasheet at https://files.omc-stepperonline.com/17HS19-2004S1_Full_Datasheet.pdf 24v 2.0A with a holding torque of 0.59Nm
PSU - I’ve already upped this from a 10A to 15A to try to ensure running is not dragging it down. Multimeter shows no instability in supply however I appreciate sampling rates of these may not be fast enough.
I’m using the Web UI version 3.0.0.6, Firmware version 3.9.9
Re-loaded the config.yaml on the Github (downloaded again today) to ensure a clean starting point. the only item I have changed is the homing/mpos_mm on the X and Y axis to match my table, my axis are slightly oversized to the cut area so I can send the cutter past the edge of the bed.
I’ve zeroed the coordinates to the same zero mostly so I can’t confuse myself whilst trying to resolve this, so workspace and machine co-ordinates are reading the same.
In an attempt to ensure its no code type error, sending the X axis to 1000mm in 10 x 100mm increments with the jog buttons and then joggin back 10 x 100mm increments takes the machine to a measured position of X-12.
Re-homed the machine, G0 X0 to check machine gets correctly to 0 which it does G0 X1000 followed by G0 X0 and the machine crashes into the Xmin end of the gantry.
Re-homed the axis. Reduced the maximum speed of the axis to 3000mm/min, G0 X1000, G0 X0 actual machine position then X-6.
I’ve spent hours now playing with the config file, I keep reverting back to the stock file to ensure its not me adding more errors. The only flag the machine raises is there is no SD card mounted as there’s not one in the slot yet.
We use about 1.5A at full chooch all 5 steppers at once. so no issues here.
You might as well update both of those. Links are on the jackpot instructions page.
What exactly did you change them too? In my oppinion you should leave them just clearing the endstop reset click, all the rest is changed on every job.
try
G10 L20 P0 X0 Y0 Z0
G1 x1000 f4000
G1 x0
What changes?
No issues with this.
Update to 4.1.1 and 3.0.11 (of figui) and see if this keeps happening.
We’ve updated to the latest firmware, so now running FluidNC 4.1.1 and WebUI V3.0.11
Still overtravels on the return by around 3mm
y mpos_mm: -27.500000
x mpos_mm: -12.750000
Will try the Gcode you just sent
Did I need to turn on figui on the firmware upgrade? I only did webui3 per the instructions
Try this before figui.
The next thing to try is Use cam to make a square. 1000mm on each side. lets see what happens. I just have a gut feeling it is some odd starting condition.
So it ended up back at -6mm from the start point with that command set
What happens when you run the test crown?
I am trying to determine if the jogging is just bugged or not. I jog to a start postion and run gcode, never have any issues. I have never jogged back and forth and measured it.
Or do a small test cut square, just find out if the actual part is messed up or just jogging.
Slowing the feed rate to 2000, the overshoot on the return to 0,0 is around 1mm, but that’s cumulative over several runs as it no longer knows where physical 0 is. Can’t run the test crown/other gcode as we don’t have a compatible SD card - it’s on order!
Found an SD in a drawer, ran the crown grbl and it has overshot the start point by a couple mm in both axes.
Did the crown look fine?
Does this happen on Y and Z as well?
I am at a complete loss, honestly. I have no idea how all the code functions fine, yet somehow coming back to 0,0 doesn’t work.
Are you sure the belt is on the pulley correctly, not upside down or slipped off the top?
The Y axis is two steppers, for them both to be doing the exact same thing is really throwing me for a loop, as they are separate drivers so the controller is telling them both to do the same exact thing. if both sides were coming to a different point this would make way more sense. Or if only one stepper was doing this it would be another issue but for both your X and Y to be messed up exactly the same points to code.
Are your steppers warm after being on for 20 mintues?
Turn up the current to
run_amps: 1.000
homing_amps: 1.000
hold_amps: 1.000
for all 5 steppers. save config, reboot.
If your steppers are 2.0A, they’re not a direct match. Ryan’s are rated at 1.7A, and 1.8 Ohms/coil.
The stepper online parts you posted a link to are rated 2.0A and 1.6 Ohms/coil. That may seem a minor difference, but it is noticeable.
You will likely need to to increase your current (Ryan mentions this above). I think you may need to go a bit over those set points.
Our assumption thus far is that it’s losing steps for some reason as it’s off in both x and y. z appears to be ok but it’s obviously a smaller dimension, so any losses would be much less visible.
The steppers are not warm at all. I’ve increased the current as suggested and re-run the crown, it’s come back to a point 2mm outside the edge of the table, from a starting position dead on the corner.
