Racking in Y Axis Travel
Can we see a picture of your board wired up please.
I am not sure how this can even happen. How are you testing the offset, how exact are you able to be?
Does the crown look okay? As in does the sketch slowly skew or is the returning to zero the only issue?
Know what I’d like to see? Get a fine point pen mounted to your machine.
Create an X and Y ruler with Jamie’s test pattern generator.
Run that file multiple times and the machine should be re-drawing the ruler in the same place. It will show a fair amount about the errors you’re seeing.
Hardware - pulley belt issues could be fairly consistent.
  • loose pulleys typically move under 4mm.
  • we have had a single user with mismatched belts and pulleys that do not mesh correctly. This gets a missed step pretty consistently.
  • cords snagging
Electronics - esp32 issues should be completely random and effect everything or just one axis. I can’t see a way 3 out of 5 steppers are being odd, consistently.
Code - I can send over code I have run that resulted in “perfect parts” that we could measure. The crown has old starting and ending gcode so new fresh code would be a good idea.
project.gcode (1.1 KB)
This has a touchprobe starting gcode.
