Glad to see you’re getting it cat scanned before assembly…
That looks really cool. Great part to use rainbow on. The angle of the print makes it look awesome.
Core and plates assembled. Should’ve painted/sealed YZ MDF before assembly, but planning on swapping for 200mm rails depending on how that goes for others.
Rolling with synthetic motor noise test worked . So, onto “Beam assembly”, currently figuring out size needed to accommodate 49"x97" MDF stock. Digging thru calculator and forum posts…
Sharing zipped .3MF containing Cura 5.0.0 profile I used to print the Core in 14h 40mins. Am no 3D printing expert, have seen folks on this forum get great prints much faster. My relatively stock Ender 3 Max, 0.6mm nozzle, 0.32mm layer height. Been couple of weeks now, but for infill, think I used doc recommendations +10%.
For smaller non Core parts I printed with faster profile. Used Cura test cubes, retraction/temp towers, CNC Kitchen, Chep, Maker Muse, Thomas Sanladerer, Teaching Tech’s https://teachingtechyt.github.io and other helpful resources.
220707_lr-core.zip (508.4 KB)
Hope that helps. Cheers!
Beam assembled. Wired. Using @DougJoseph’s nifty SKR Pro + TFT enclosure.
Goal is to get LowRider rolling and throwing chips like a high roller throwing chips at a club. Jankiest of janky tables, here we come…
For table ideas, consider a torsion box something like this, covered with a thin skin on the bottom, and perhaps a thin skin plus MDF spoiler board on top.
This image came from https://thewoodwhisperer.com/viewer-projects/kens-mobile-torsion-box-assembly-table/
Or of course you could build two torsion boxes like I did, and bolt them together on a base. Plans and pics of my table are in my LR2 build thread. I can link if you cannot find it.
Cheers @DougJoseph! Appreciate the guidance and sharing your table build journey. Have already bookmarked your Doug Joseph (Design8Studio) Full-Sheet LowRider 2 "Build on a Budget" - #10 by DougJoseph and bunch of other great designs different folks have been coming up with.
Excited to see what you come up with for a table.
Yep, me too. Excited to see what you come up with for your table.
Janksy’s 1st crown attempt!
Am pleased considering the shortcuts I took… Paper was taped to decrepit damp swollen bent loosely laid chip spoilboard, resting on cambered 2x4s. Pen was loose (recommend 3 zip ties), neat idea to mount pen to vac holder. Still need to do Initial Squaring and level/tram with a surface bit. Core rail tensioners are loose, etc…
Again, love and appreciate the design. I keep discovering, realizing and appreciating details, e.g. like how the X Belt Tensioner profile/design’s tight tolerance allows barely sliding behind the Core. Cool engineering!
Short clip (~27s) @ LowRider V3 CNC build — Janksy's 1st crown - YouTube
Janksy currently rides on not a table legless flat surface. Copied and tweaked some forum ideas:
No legs, probably getting short term casters. Still figuring out how to hoist onto side against the wall when not in use.
Next steps:
Cheers!
've had worse ideas, thinking Harbor Fright’s $15 rope and tackle usually used to hang your meat, is worth trying out on my LowRider not a table surface.
Suspending using E-Track to split load across multiple joists, and provide options later for easy overhead vac/power.
Really like super strut, but don’t like how a complete system prices out to. So, doing best I can by frequently asking myself WWMD? (What would Macgyver do).
Created a video… Hope this helps folks figuring out whether, and how to build their LowRider 3!
Feedback appreciated, cheers!
Went a bit nuts on the indexing. My thinking is that this approach helps make info more discoverable.
00:00 - Intro and video goals
00:48 - WHAT’s a LowRider CNC for? Answer: Subtractive Manufacturing
01:30 - WHY build a LowRider? Answer: Step up from my baby CNC, right balance of quality and price for me.
02:20 - MPCNC is good, but I want a LowRider 3
02:43 - Pick your own size, or sizes even…
04:51 - Using Controller+TFT case by V1E Community member Doug Joseph
04:55 - Hassle free kits and parts available from https://shop.v1engineering.com, Controllers come with software preloaded.
05:48 - Parts printed, milled and delivered
06:24 - Unboxing V1E LowRider 3 Kit. Woot!
06:28 - Assemble LR3 Core
06:36 - Ream holes, reverse drill helps screws slip in tight
06:54 - Assemble X Drive
07:12 - Mount X Drive
07:15 - Stare at your Core for a bit, it’s so pretty
07:16 - Mount X endstop to Core
07:25 - Assemble Y Steppers
07:51 - Soldered Z endstops, too tight for spade connectors
07:56 - XZ Lead screw stubs. Reverse drill with 13/32 bit
08:02 - Assemble XZ plates
08:24 - Marry XZ to YZ plates
08:34 - Marry XZ to YZ plate rails
08:45 - Mount Z drive to YZ plate
08:55 - Wiring Z endstops, solder
09:03 - Wiring Z endstops, test
09:08 - Assemble Z endstops
09:16 - Mount Z endstops
09:18 - Adjust XZ plate, was binding
09:26 - Mount Z endstops
09:31 - Mount Y Drive
09:42 - Wiring Y endstop, solder
09:50 - Mount Y endstop, wiring routing
09:55 - Wiring routing
09:57 - Mount Y endstop, wiring routing
10:00 - Assemble wheels
10:05 - Mount wheels to YZ plate
10:10 - Assemble and mount Rail Rollers
10:19 - Assemble Beam, strut order… 1) Front, 2) Bottom, 3) Back
10:21 - mount braces
10:25 - LR3 Calculator, pipe and table size
10:28 - Front, loosely insert screws
10:36 - Bottom, loosely insert screws
10:41 - Rear, loosely insert screws
10:51 - Front, check straight, snug clamps
10:58 - Mount core
11:00 - Mount YZ plate
11:10 - Assemble X Belt
11:10 - Insert X Belt
11:12 - Mount X Belt holder
11:15 - Check X Belt end not blocking Z axis motion
11:17 - Mount X belt tensioner
11:28 - Fix for if X Belt stub is too loose
11:31 - Attach PETG tool mount
11:38 - Attach Vac hose mount
11:40 - Wiring SKR Pro 1.2 Controller
11:40 - Bend/clip diag driver pin
11:45 - Change jumpers
11:48 - Mount drivers
11:54 - Remove JST shields
12:03 - TMC2209 driver pinouts
12:05 - Wiring 〉 Route and Sleeve (1/2" wrap)
12:05 - Left YZ sleeve
12:15 - Routing right YZ
12:24 - Extend right YZ, use solder butt connectors
12:54 - Right YZ, 1/2" sleeve wrap
12:59 - NOT using cable gland, case holes too small
13:05 - Extend wires for X axis
13:16 - Wire X axis, test endstop
13:23 - Wire X axis routing and 1/2" sleeve
13:46 - X axis, verify range of motion. Router cord blockage
14:06 - Wire X axis, cable management
14:20 - Case wiring, routing power
14:42 - Controller wiring, driver endstops
15:03 - Wiring controller, fans and TFT
15:37 - Build minimum viable Sled. Use LR3 Sled edition to finish LR3!
17:12 - Motion test, FAIL - Y stepper wiring reversed
17:21 - Motion test, SUCCESS - Homed and move as expected
17:28 - Crown Test, SUCCESS, kinda…
17:47 - Struts 〉 Initial squaring
17:48 - Attach pen to Core
17:50 - Generate test gcode
17:51 - Connect via Repetier
17:53 - FAIL, relative positioning was set
17:54 - Typed gcode for corner moves
18:02 - Measure squareness
18:05 - Config homing offsets M666
18:07 - Z Leveling
18:19 - Struts 〉 Design
Calc size, download files
Use OpenScad & Estlcam to prepare gcode
18:31 - Struts 〉 First cut ~56mins
18:31 - Fasten spoilboard and stock
18:40 - Cut first strut
18:47 - Post cleanup, too long
18:54 - Struts 〉 Second cut ~42mins
19:02 - Post cleanup, Remove/trim debris, sand, vac
19:09 - Paint it black
19:16 - Surfacing Spoilboard
19:16 - Create toolpath
19:17 - Cut ~0.5mm in ~61mins
19:25 - Struts 〉 Make custom front strut
19:25 - OpenScad 〉 Customize, export .SVG
19:26 - Estlcam 〉 Create and Preview toolpaths
19:28 - Repetier 〉 Load .gcode
19:28 - Carve and cut 42mins
19:35 - Struts 〉 Paint 〉 2nd coat, protect via Shellac/Polycrylic
19:37 - Final Assembly - Mount struts to beam
19:40 - Temporarily disassemble beam
19:57 - Mount bottom strut
20:02 - Mount front strut
20:07 - Mount YZ plates and rear strut
20:17 - Wrap up
Future upgrades - Table, Vac, drag chain and more…
Check out https://forum.v1engineering.com
Thank you! Want to see more?
Some Endstop wiring length info for my build, with 49-1/2" (1257mm) usable cutting width.
Sharing details since I asked during my build, and @KL2001 asked similar question today.
Didn’t have this info for my build, and extended endstop wires by soldering butt connectors (fast video clip, don’t blink!). Used a mix of 3x extension wiring kits from V1E Shop and some 22AWG wiring I happened to have.
Knowing what I know now, would’ve cut the following endstop wiring lengths upfront during initial build to help save some splicing/soldering time.
End stop | Length to Controller Box | Total (includes 400mm for 2x Box length) |
X/touchplate | 1900mm | 2300mm |
Y1 | 550mm | 950mm |
Z1 | 700mm | 1100mm |
Y2 | 2000mm | 2400mm |
Z2 | 2000mm | 2400mm |
Yes, I have one Hall effect switch for each stepper motor (or, 2 for each of the X and Y axes, and one for the Z-up) and I have to say that after a year of using the machine, they work very reliably. You don’t have to worry about bumping them, or any effects of dust. Here is a video about them: https://youtu.be/ztcMPmEYCmw?t=763
I carefully measured their repeatability and it came out to about 15 microns. The standard microswitches actually came out a bit better, about 10um. (standard deviation of many measurements using a digital micrometer to trigger them.)
“True Level” will have to remain a fantasy, for now.
Have procrastinated, overly deliberated and navel gazed on the ideal ‘medium sized work’ workbench. Am just going to quickly throw something together, will look something like below, with casters. I can always add levels and lasers later…
Sizing surface for cutting 2’x4’ stock. Clear front makes this a usable regular bench. Will overhang top surface enough to enable clamping various things. Finished surface will be 36" high, with adjustments to account for floor level and earth’s curvature. Standardizing on 36" height for misc tool stands.
Me: Progress! Today, I’ve decided how wide to make my mostly LR3 workbench.
A few minutes later…
ColinFurze: Progress! Today, I’ve finished initial build out of the ultimate DREAM workshop, and dropped a kick-arse YouTube video…
Me: Wow! Time for me to listen to Amazon.com again…
Yeah. Colin Furze has no fear and so much talent.
