Anyone tested their maximum pulling force? Mine can pull ~56 Newton with the Y-axis and ~86 Newton with the X-axis measured at the rails.
I love tests!
Can you see any reason it is so lopsided? It should be very similar numbers, even if your build is not square.
Unless the vref is different they really should be closer than that.
