So, decided to try and make this a bit more Portable friendly.
Download the Zip file from here https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.0.0
64bit or 32bit
Extract it to a folder (you can call it anything you want (PrusaSlicer2 will work)
Open that folder and run prusa-slicer.exe
Do the initial setup
Close the application
Go to C:\Users\YOURPROFILENAME\AppData\Roaming
Copy and paste the whole folder PrusaSlicer to PrusaSlicer2 folder
Download the cmd file PrusaSlicer2-Run.cmd.txt
Save it to the root of the PrusaSlicer2 folder
Rename it to PrusaSlicer2-Run.cmd
Run PrusaSlicer2-Run.cmd
You can then copy and backup your profiles more easily.
This allows you to run the application from anywhere or USB stick.
Your PrusaSlicer2 folder should look like this
[attachment file=“PrusaSlicer2 Root folder.jpg”]
ECHO DISCLAIMER*************************************
ECHO ***** You use this batch file from this post at your own risk. *
ECHO ***** I make no claims that it will run perfectly every time. *
ECHO ***** I do not provide any warranties of any kind from your using this file. *
ECHO *******************************************************************************
PrusaSlicer2-Run.cmd_-1.txt (2.98 KB)
