Smart controller is hooked up and working. I can control all axis from the controller. It recognizes my SD card and shows me the files on it. But when i try to run a gcode file it doesn’t do anything. What am I missing?
How did you generate the gcode file? Are you sure the gcode file is good and has actual movements in it? Try a simulator like rep host or an online one like https://nraynaud.github.io/webgcode/. Is there any error displayed on the LCD? Can you paste in all or part of the gcode? Are you running marlin/ramps or another controller?
I’m running marlin/ramps. I have a min heat error. But no 3d printer head installed yet.
Just some gcode i snagged off the forums here.
G01 X0 Y0
G01 X0 Y10
G01 X10 Y10
G01 X10 Y0
G01 X0 Y0
G01 X0 Y0 Z1
G01 X30 Y30 Z1
G01 X30 Y30 Z0
G01 X30 Y30
G01 X30 Y40
G01 X40 Y40
G01 X40 Y30
G01 X30 Y30
G01 X30 Y30 Z1
G01 X0 Y0 Z1
G01 X0 Y0 Z0
G01 X0 Y0
G01 X0 Y10
G01 X10 Y10
G01 X10 Y0
G01 X0 Y0
G01 X0 Y0 Z1
G01 X30 Y30 Z1
G01 X30 Y30 Z0
G01 X30 Y30
G01 X30 Y40
G01 X40 Y40
G01 X40 Y30
G01 X30 Y30
G01 X30 Y30 Z1
G01 X0 Y0 Z1
G01 X0 Y0 Z0
G01 X0 Y0
G01 X0 Y10
G01 X10 Y10
G01 X10 Y0
G01 X0 Y0
G01 X0 Y0 Z1
G01 X30 Y30 Z1
G01 X30 Y30 Z0
G01 X30 Y30
G01 X30 Y40
G01 X40 Y40
G01 X40 Y30
G01 X30 Y30
G01 X30 Y30 Z1
G01 X0 Y0 Z1
G01 X0 Y0 Z0
G01 X0 Y0
G01 X0 Y10
G01 X10 Y10
G01 X10 Y0
G01 X0 Y0
G01 X0 Y0 Z1
G01 X30 Y30 Z1
G01 X30 Y30 Z0
G01 X30 Y30
G01 X30 Y40
G01 X40 Y40
G01 X40 Y30
G01 X30 Y30
G01 X30 Y30 Z1
G01 X0 Y0 Z1
G01 X0 Y0 Z0
G01 X0 Y0
G01 X0 Y10
G01 X10 Y10
G01 X10 Y0
G01 X0 Y0
G01 X0 Y0 Z1
G01 X30 Y30 Z1
G01 X30 Y30 Z0
G01 X30 Y30
G01 X30 Y40
G01 X40 Y40
G01 X40 Y30
G01 X30 Y30
G01 X30 Y30 Z1
G01 X0 Y0 Z1
G01 X0 Y0 Z0
G01 X0 Y0 Z0
G01 X10 Y10 Z0
G01 X0 Y10 Z0
G01 X10 Y0 Z0
G01 X10 Y10 Z0
G01 X5 Y15 Z0
G01 X0 Y10 Z0
G01 X0 Y0 Z0
G01 X10 Y0 Z0
G01 X10 Y0 Z1
G01 X20 Y0 Z1
G01 X20 Y0 Z0
G01 X20 Y0 Z0
G01 X30 Y10 Z0
G01 X20 Y10 Z0
G01 X30 Y0 Z0
G01 X30 Y10 Z0
G01 X25 Y15 Z0
G01 X20 Y10 Z0
G01 X20 Y0 Z0
G01 X30 Y0 Z0
G01 X30 Y0 Z1
G01 X40 Y0 Z1
G01 X40 Y0 Z0
G01 X40 Y0 Z0
G01 X50 Y10 Z0
G01 X40 Y10 Z0
G01 X50 Y0 Z0
G01 X50 Y10 Z0
G01 X45 Y15 Z0
G01 X40 Y10 Z0
G01 X40 Y0 Z0
G01 X50 Y0 Z0
G01 X50 Y0 Z1
G01 X60 Y0 Z1
G01 X60 Y0 Z0
G01 X60 Y0 Z0
G01 X70 Y10 Z0
G01 X60 Y10 Z0
G01 X70 Y0 Z0
G01 X70 Y10 Z0
G01 X65 Y15 Z0
G01 X60 Y10 Z0
G01 X60 Y0 Z0
G01 X70 Y0 Z0
G01 X70 Y0 Z1
G01 X80 Y0 Z1
G01 X80 Y0 Z0
G01 X80 Y0 Z0
G01 X90 Y10 Z0
G01 X80 Y10 Z0
G01 X90 Y0 Z0
G01 X90 Y10 Z0
G01 X85 Y15 Z0
G01 X80 Y10 Z0
G01 X80 Y0 Z0
G01 X90 Y0 Z0
G01 X90 Y0 Z1
G01 X100 Y0 Z1
G01 X100 Y0 Z0
G01 X100 Y0 Z0
G01 X110 Y10 Z0
G01 X100 Y10 Z0
G01 X110 Y0 Z0
G01 X110 Y10 Z0
G01 X105 Y15 Z0
G01 X100 Y10 Z0
G01 X100 Y0 Z0
G01 X110 Y0 Z0
G01 X110 Y0 Z1
G01 X120 Y0 Z1
G01 X120 Y0 Z0
G01 X120 Y0 Z0
G01 X130 Y10 Z0
G01 X120 Y10 Z0
G01 X130 Y0 Z0
G01 X130 Y10 Z0
G01 X125 Y15 Z0
G01 X120 Y10 Z0
G01 X120 Y0 Z0
G01 X130 Y0 Z0
G01 X130 Y0 Z1
G01 X140 Y0 Z1
G01 X140 Y0 Z0
Got a little frustrated and put it away for a few days. I’m at work right now but, I will get a copy of the gcode when I get home. I coppied the code from a test that someone posted on here. The one where it drew two square boxes and alternated between them. I did try sticking the code in a web simulator and it didn’t show anything either. Could’ve been my lack of knowledge on how to run the page. I’ll try your example tonight.I have a Min Heat Error. But I don’t have a 3D printer head installed yet. Was just looking to make it move first.
I appreciate your help.
You need the resistor on pin T0 to get rid of the min temp error, then you can visualize the gcode, kinda, in repetier by checking the show movements box.
I knew I forgot something! Thanks, vicious!
