PRINT & CUT In FluidNC Plugins Share
:rocket: FluidNC PRINT & CUT Plugin
Hi everyone,
I’m looking for a Print & Cut / Registration Mark Plugin for FluidNC.
The main idea is to use FluidNC for a DIY print-and-cut machine with features like:
- :page_facing_up: Printed sheet loading and positioning
- :bullseye: Registration mark detection
- :camera: Camera or sensor-based mark scanning
- :triangular_ruler: X/Y offset correction
- :counterclockwise_arrows_button: Rotation / skew correction
- :straight_ruler: Scaling correction if required
- :scissors: Automatic corrected cutting
- :1234: Multiple registration marks for accurate alignment
- :repeat_button: Support for repeated sheets / batch cutting
- :gear: Compatible with ESP32 + FluidNC
Question to the FluidNC community:
Has anyone already developed a Print & Cut / registration / camera alignment plugin for FluidNC?
If anyone has made a plugin, experimental version, code, or working project, please share it here so we can test and improve it together.
Even an early/experimental V1 plugin is very useful.
My goal is to develop an open DIY solution for 13×19 print & cut, similar to the workflow used in professional cutting plotters.
If anyone is interested in collaborating, please share your ideas, source code, GitHub/project link, or implementation details.
Thank you! :folded_hands:
printing ia the hard part, not any of the rest.
I am looking for developers who have already created or are working on a Print & Cut / Registration Plugin for FluidNC.
:bullseye: Main Concept
The machine should automatically find 4 L-shaped registration marks on a printed sheet using a probe/sensor or camera.
Workflow:
1. :page_facing_up: Place the printed sheet on the cutting bed.
2. :house: Machine moves to the defined starting/search area.
3. :magnifying_glass_tilted_right: Probe scans and finds Corner 1 – L Mark.
4. :magnifying_glass_tilted_right: Finds Corner 2 – L Mark.
5. :magnifying_glass_tilted_right: Finds Corner 3 – L Mark.
6. :magnifying_glass_tilted_right: Finds Corner 4 – L Mark.
7. :round_pushpin: Save the exact X/Y position of all 4 marks.
8. :triangular_ruler: Calculate the actual sheet position.
9. :counterclockwise_arrows_button: Automatically calculate rotation / skew angle.
10. :straight_ruler: Calculate X/Y scaling or print stretch, if required.
11. :bullseye: Calculate the required X/Y offset.
12. :open_file_folder: Load the original SVG or DXF cutting file.
13. :counterclockwise_arrows_button: Automatically transform the SVG/DXF according to the measured registration marks.
14. :gear: Generate the corrected G-code.
15. :outbox_tray: Send the corrected G-code directly to FluidNC.
16. :scissors: Start the cutting job automatically.
17. :repeat_button: After completion, optionally return to the loading position for the next sheet.
:triangular_ruler: Four-Corner Correction
The plugin should use:
P1 = Top Left
P2 = Top Right
P3 = Bottom Right
P4 = Bottom Left
From these four points, the software can determine:
- X offset
- Y offset
- Rotation
- Skew
- Scale X
- Scale Y
- Overall print/cut registration error
The cutting path should then be transformed to match the actual printed sheet, rather than simply cutting using the original machine coordinates.
:open_file_folder: File Support
The plugin/software should support:
- SVG
- DXF
- G-code
SVG/DXF → Registration Correction → G-code → FluidNC
:robot: Fully Automatic Workflow
The final goal is:
Load Sheet → Find 4 L Marks → Calculate Correction → Transform SVG/DXF → Generate G-code → Send to FluidNC → Cut
No manual coordinate calculation should be required.
:wrench: Hardware Concept
Possible hardware:
- ESP32 + FluidNC
- Probe/sensor for L-mark detection
- OR ESP32-CAM / USB camera
- X/Y stepper motors
- Drag knife / tangential knife
- Vacuum bed
- Limit/home switches
:test_tube: V1 Development
For the first version, even a simple implementation is enough:
4-point L-mark detection → X/Y offset + rotation correction → corrected G-code → FluidNC
Later versions can add:
- Perspective correction
- Non-uniform scaling
- Camera-based detection
- Automatic sheet loading
- Automatic unloading
- Batch print & cut
- Multiple copies/nesting
- Advanced registration algorithms
If anyone has already developed a FluidNC plugin, WebUI plugin, external application, Python tool, or G-code-based solution for this type of workflow, please share it.
I would like to test it on a 13×19 print-and-cut DIY machine and contribute feedback/improvements.
Anyone interested in developing this together is welcome to share code, GitHub projects, ideas, or existing solutions. :folded_hands:
There are none here as there are no printing options available in any way.
I mean pre-printed sticker sheets. The printing is already finished on a separate printer. I only need FluidNC to detect the 4 corner L registration marks, calculate offset/rotation/scale, correct the SVG/DXF contour path, generate G-code, and cut the already-printed sheet automatically.
CONTOUR VINYL CUTTING
No printing function is required in FluidNC.
Okay. Fluidnc is not going to do any of that. You will need a system/software to measure and alter your gcode. Fluidnc is just motion control. Doing it that way means any firmware would work.
The idea is great but this is a very odd style of post for this forum.
It would be great to be able to do this but please take it easy on reposting AI responses here.
Please make it clear if you are actually working on this yourself, or you are looking to hire someone.
Sorry Ryan. My English is not very good, so I use AI to help me write my posts and explain my idea clearly.
Understood, but we are all starting to reach an AI sensitivity, to gain the most eyes, the response need to be more human.
Are you working on this or looking to hire someone?
Now I am making but more failures and any hire if available message me
As I understand it you want to stick a drawing to a piece of wood and have it automatically cut it out. While this is possible and some laser cutters have this supported. It is not the normal process for CNC work.
The alternative is to load the drawing into a CAM program and then select the lines and apply tool operations. You need to set things like bit to use, speed and feed of the bit, depth of cut and thickness of material. None of these could be automatically determined from just looking with a camera at a print. But maybe I am not fully understanding what you are trying to achieve.
ai:dr (AI: didn’t read).
