Preferences.json help
I’m using a JP 1 board, upgraded to WebUI 3.0.0-5.FluidNC and running FluidNC v3.9.9.
Everytime I boot up the board I get this:
Now, everything else seems to work, but I’m not sure what the issue is with my preferences.json file.
This is what the file contains (from flash)… What am I missing? :thinking:
 "settings": {
  "language": "default",
  "theme": "theme-FluidDark",
  "autoload": true,
  "mobileview": false,
  "audio": false,
  "hapticfeedback": false,
  "audiofeedback": false,
  "showmachinesettings": false,
  "disconnectonotherlogin": true,
  "enableautorepeat": false,
  "enableshortcuts": false,
  "autorepeatdelay": "500",
  "emergencystop": "#SAFETYDOOR#",
  "fixedpanels": true,
  "panelsorder": [
    "id": "Jog",
    "name": "jog",
    "value": "jog"
    "id": "Terminal",
    "name": "terminal"
    "id": "Status",
    "name": "status"
    "id": "Files",
    "name": "files"
    "id": "Macros",
    "name": "macros"
    "id": "Notifications",
    "name": "notification"
    "id": "Probe",
    "name": "probe"
    "id": "Overrrides",
    "name": "overrides"
  "enablepolling": true,
  "pollingcmds": [
    "id": "7p0cztkr0",
    "name": "Auto-Reporting",
    "cmds": "$Report/Interval=100",
    "refreshtime": "0"
  "showterminalpanel": true,
  "openterminalonstart": true,
  "verbose": true,
  "autoscroll": true,
  "MaxTerminalMessages": 400,
  "showfilespanel": true,
  "openfilesonstart": true,
  "filesfilter": "g;G;gco;GCO;gcode;GCODE;nc;txt;cnc;ngc",
  "flashfs": true,
  "sort_flashfs_files": true,
  "directsd": true,
  "sort_sd_files": true,
  "default_filesystem": "DIRECTSD",
  "showjogpanel": true,
  "openjogonstart": true,
  "homesingleaxis": true,
  "homecmd": "$H#",
  "zerocmd": "G10 L20 P0 #",
  "jogstopcmd": "#JOGCANCEL#",
  "showx": true,
  "showy": true,
  "showz": true,
  "showa": false,
  "showb": false,
  "showc": false,
  "showu": true,
  "showv": true,
  "showw": true,
  "xyfeedrate": "4000",
  "zfeedrate": "1200",
  "afeedrate": "1000",
  "bfeedrate": "1000",
  "cfeedrate": "1000",
  "ufeedrate": "1000",
  "vfeedrate": "1000",
  "wfeedrate": "1000",
  "jogdistancedefault": "100",
  "zjogdistancedefault": "10",
  "keymap": [
    "id": "btn+X",
    "name": "btn+X",
    "key": "ArrowRight"
    "id": "btn-X",
    "name": "btn-X",
    "key": "ArrowLeft"
    "id": "btnHX",
    "name": "btnHX",
    "key": "X"
    "id": "btnZX",
    "name": "btnZX",
    "key": "1"
    "id": "btn+Y",
    "name": "btn+Y",
    "key": "ArrowUp"
    "id": "btn-Y",
    "name": "btn-Y",
    "key": "ArrowDown"
    "id": "btnHY",
    "name": "btnHY",
    "key": "Y"
    "id": "btnZY",
    "name": "btnZY",
    "key": "2"
    "id": "btn+Z",
    "name": "btn+Z",
    "key": "PageUp"
    "id": "btn-Z",
    "name": "btn-Z",
    "key": "PageDown"
    "id": "btnHZ",
    "name": "btnHZ",
    "key": "Z"
    "id": "btnZZ",
    "name": "btnZZ",
    "key": "3"
    "id": "btn+axis",
    "name": "btn+axis",
    "key": "/"
    "id": "btn-axis",
    "name": "btn-axis",
    "key": "*"
    "id": "btnHaxis",
    "name": "btnHaxis",
    "key": "A"
    "id": "btnZaxis",
    "name": "btnZaxis",
    "key": "4"
    "id": "btnHAll",
    "name": "btnHAll",
    "key": "Home"
    "id": "btnZAll",
    "name": "btnZAll",
    "key": "0"
    "id": "btnaxisSel+",
    "name": "btnaxisSel+",
    "key": "Control+0"
    "id": "btnaxisSel-",
    "name": "btnaxisSel-",
    "key": "Control+0"
    "id": "btndistSel+",
    "name": "btndistSel+",
    "key": "+"
    "id": "btndistSel-",
    "name": "btndistSel-",
    "key": "-"
    "id": "btnStop",
    "name": "btnStop",
    "key": "Control+s"
    "id": "btnEStop",
    "name": "btnEStop",
    "key": "Delete"
  "shownotificationspanel": true,
  "opennotificationsonstart": true,
  "notifautoscroll": true,
  "showmacrospanel": true,
  "openmacrosonstart": true,
  "macros": [
    "id": "ksq7ju9bc",
    "name": "Probe Washer",
    "icon": "Download",
    "action": "zwasherprobe.gcode",
    "type": "FS",
    "key": ""
    "id": "v0xj4iwu6",
    "name": "Z-Probe",
    "icon": "Download",
    "action": "zprobe.gcode",
    "type": "FS",
    "key": ""
    "id": "rvqcgxzfm",
    "name": "Save Config",
    "icon": "Save",
    "action": "$CD=config.yaml",
    "type": "CMD",
    "key": ""
    "id": "xsht27tfi",
    "name": "Disable Motors",
    "icon": "ZapOff",
    "action": "$MD",
    "type": "CMD",
    "key": ""
  "showextracontents": false,
  "openextrapanelsonstart": true,
  "extracontents": [
    "id": "gm5zcj8z7",
    "name": "Hold Monitor",
    "icon": "PauseCircle",
    "target": "panel",
    "source": "holdmonitor.html",
    "type": "extension",
    "refreshtime": "0"
  "showstatuspanel": true,
  "openstatusonstart": true,
  "showprobepanel": true,
  "openprobeonstart": true,
  "probefeedrate": 20,
  "maxprobe": 15,
  "probethickness": "1",
  "proberetract": "5",
  "probepostcommand": "G10 L20 P0 #selected_axis##probe_thickness#",
  "showlaserpanel": false,
  "openlaseronstart": false,
  "lasertest": 10,
  "lasertestprecent": 20,
  "lasermax": 1000,
  "showspindlepanel": false,
  "openspindleonstart": true,
  "spindlespeed": 1000,
  "showM4ctrls": true,
  "showCoolantctrls": true,
  "showMistctrls": true,
  "showM7ctrls": true,
  "showoverridespanel": true,
  "openoverridesonstart": true
You should be able to just replace it with the preferences file in the github packet you downloaded for the update. Release 3.9.9 w/ UI v3 · V1EngineeringInc/FluidNC_Configs · GitHub
ok. Thanks. It got ride of that error. Now I just have to put things back the way I had them (macro’s, dark mode, etc.). Now worries. Looks like I need to update the WebUI to the -6 version (vs. the -5 version I have installed).
