First pieces jpeg.
Start went well, then the x axis broke down, restart arduino, then the y axis broke down.
1 of 2 attempts no problem
Laptop and arduino stood three meters away from the plasma cutter.
Anyone have an idea what I can do about this?
Arduino in an iron box?
Shielded cables for motors? (Now used ordinary UTP cable)
Kind regards Marc A
Are you sure the issue is the plasma? Just to be sure can you run a long file without the plasma on then it only messes up with the plasma on? Using an LCD controller or a laptop?
A few other things it could be but never know.
Someone else just grounded all his metal tubes in the forums, this might help. The wires are shielded, the connections on the solder less mount’s aren’t ideal in this case, maybe solder them up, a metal box for the arduino couldn’t hurt.
We use a laptop, no lcd at the moment.
We will ground the tubes, put the arduino in a metal box and get some shielded cables for the motors.
We have drawn your logo four times with a pencil connected to the cnc without any problems.
We have run each cut without the plasma cutter turned on and we never had any problems.
When we ran the cuts with the plasma cutter on however sometimes one of the axis stopped working, exept for the Z-axis, this one never failed.
Apparently, only the activated axis fails when the plasma ignites.
As soon as we rebooted the arduino everything worked again.
I have some picture of how I grounded mine in this post. I did this more for static electricity.
The white cables are shielded and you would need to bond the shielding to the ground. Also for your setup, connect it to a electrical system ground, like through grounded power supply.
I think you have all covered the possible noise generated by the plasma.
Plasma tends to draw a goodly amount of current, could it be causing some sort of brownout situation?
Cool. How do you ensure the D9 output isn’t PWMing? Is M106 enough, or do you need to specify “M106 S255”?
For the flaky electronics, you could try adding filters to your power supply – ideally monitor the 12V line with a scope and then select capacitors to filter out the frequencies you are seeing. Or just take a guess; put at least one nice big electrolytic cap across your 12V/ground rails in case you are getting brownouts.
What brand of plasma cutter are you using. I just finished building a cnc plasma table. I tried using a older Esab but the HF start jammed up my electronics. I know allot of the
Chinese plasmas put out some nasty frequency’s as well.
Do you have any more details on how to hook up the relay, and the wiring for swapping out the torch? I’m brand new to plasma torches, and haven’t really used relays very much.
So for you plasma guys out there… what would be the “ideal” plasma cutter for using for cnc? I cancelled my order on my unit I ordered since it was High Frequency start, and I’m trying to find a unit that is a pilot arc start, to be easier on the electrical trouble shooting. The problem I’m having now, is finding something affordable, that is pilot arc. The more and more I thought about it, the chinese plasma cutters scare me.
So really what I’m asking, is which torches has anyone found that is pilot arc? All the product descriptions around the internet are pretty vague on details… I’m trying to keep this semi affordable
