I know this can be a lot of different sizes, but what is a good length to cut the various pipes for about a 24"x24" version that the bundled parts will build. This includes the lengths for short pipes on the Z-axis.
I bought 2 - 3/4"x10’ pipes from Home Depot. The 3/4" pipes at the Lowes near me seemed to be closer to a .88" O.D. They were also 30 cents less expensive at Home Depot for each pipe.
I just finished printing the corner blocks and bought 25mm tube with 2mm thickness. what size table is recommended… i cut my tubes in 4 x 120mm and i noticed a little bending while pushing into the tube.
Is a little bending ok or should i make it smaller.
1200mm? Try it out, when it’s all put together the rigidity increases a bit and you can easily go smaller. Rigidity needed comes down to what you plan on cutting with it. That is probably much to long for aluminum, but maybe in a corner it would be fine. You can also put supports under the outside tubes to help it out a bit.
I’d say finish it, send in some pictures, and let us know how it goes.
i guess i will try that if it doesnt work out just need to dismantle and cut… and it seems like u are right, it seems more sturdy after its put together… if someone could draw some supports to print it would be great… thanks
