I have an LR4 I made the pendant. I can hook it up via the RJ45 connector to my Jackpot V3 board. It powers on and I get the menu but nothing else seems to work. Think I am missing a step somewhere. Any ideas?
Welcome in.
Did you edit the config.yaml to enable the pendant?
Negative. What do I need to change? i was looking and so something about that just wasn’t sure and before I edit a config file I like to know
Remove the # preceding each line. This is at the bottom of the config. Don’t delete the one in front of Pendant (#Pendant:)
#uart2:
# txd_pin: gpio.15
# rxd_pin: gpio.12
# rts_pin: NO_PIN
# cts_pin: NO_PIN
# baud: 1000000
# mode: 8N1
#uart_channel2:
# report_interval_ms: 75
# uart_num: 2
# message_level: Verbose
Thank you
