Just a note, I have already started to try rectify the offset issue, I have moved the Rail Runner, Rail side inwards 10mm so there is currently no overhang.
- Image to show 0 overhang on the outside for reference.
- Taking the above mentioned 10mm into account I have for these test purposes set the rail to 51.75mm instead of the 61.75mm to give us the same net result.
*X-Min Approx 25mm in from the edge of the spoil board or on the edge of the rib.
*X-Max Approx 30mm past the edge of the spoil board or 60mm past edge of the rib.
