When using Estlcam my cut speeds were acceptable but i kept getting electromagnetic interference errors relating to my USB cable (?). I switched to Repeater and now the cut speeds are so slow they are unusable. where do I look or what do I need to change? the Config/printersettings/travelfeedrate is 4800 mm/min in repetier
the CAM file was created in Estlcam with a tool feed rate of 1.5mm deep, 20.0mm/s (xy) g code attached.
Thanks for the help.
don’t judge it’s legal here
I had the same issue a few days ago, turns out I changed the unit in Estlcam without paying attention.
Go to Parameters --> basic settings and check that the Feed Unit is set to mm per minute.
The resaon it was slow was that I’ve changed it to mm per second. Any basic cut would take hours.
