jamiek
(Jamie)
March 30, 2019, 1:27pm
21
If you are using dual endstops, the wiring is independent, so it’s neither series nor parallel. I couldn’t be sure exactly which sentence you’re referring to, but it does imply that you should use series, or dual.
But dual is independent, not parallel.
jamiek:
There are now two wiring choices. I highly recommend you start with the series wiring kit. The dual kit adds complexity with that complexity you gain accuracy and precision. More dual endstop information
here .
Probably didn’t edit that sentence from when we started. We used to run the steppers in parallel, then it was found that series was better.
