Octoprint Plugin for Chamber temperature control
For those that use Octoprint to control your 3d printers, I finally have my plugin (mostly) finished.
This plugin allows for a chamber heater and exhaust fan that can be controlled by the raspberry pi. It will monitor the chamber temperature and turn either the heater or fan on to try and keep the chamber temp between two set points.
You can find more details here:
Here’s a screenshot of the temperature being controlled.
It’s nice and chilly in the shop today, so the chamber heater helps pre-heat the chamber.
I will say that the heated bed does a really good job of warming up the chamber too.
i2ctempControl
Congratulations!
Running OctoPrint Version 1.11.2.
As I wanted to have heater and fan in my chamber, I came across your post here and hence on gitHub for the plugin itself.
Trying to install the plugin in OctoPrint, I noticed it was (no longer?) in the repository. So I installed it via the URL. Plugin installs but is disabled. Enabled it, rebooted but plugin is still/again disabled.
Tried again after uninstalling it and installing it from a local copy of the plugin zip file. But no change and plugin does not become active.
So what is the status of your plugin?
abandonware. I’m moving all my printers to Klipper where I can more easily setup chamber temp control.
