No printer attached (All parts from V1)
I guess I am joining the “no printer attached” club. When I power up the system, I get the no printer attached message.
Shows the initialization sequence
Wiring on the LCD
How the cables are connected
In the control box
Close up of the serial connection
I flashed the firmware on the controller and tried on the touch screen but it doesn’t do anything when I try to do it on the touch which I guess makes sense if it’s not communicating with the board.
In the video above, your “No Printer Attached” message actually goes away after about 10-15 seconds. This is normal.
Then it shows a “TFT in Listening Mode” message. This is not normal, and I don’t exactly know what that means (perhaps someone else can chime in, or a google search may help).
Does that message clear if you wait for a minute or so?
Could you post a picture of the startup screen showing the TFT firmware and the V1CNC firmware versions? That may provide some troubleshooting info to help us guide you.
Edit - try this link to clear the “TFT in Listening Mode” issue…
Excellent! That worked!
I had been having other issues, so I assumed this was a symptom of the initial issues I had been having.
Glad that it solved your issue! If you click on the “Solution” button on that post, it will flag it as helpful for future readers with a similar issue.(and get me one step closer to another forum badge). Cheers!
