Working on x/y cable chain
I meant filling the angle with material, like a large radius rounding of the corner, so the force of the screw head / nut is lead into the ring more evenly / smoothly.
Okay I understand. I could add a small amount of material above and below the screw, minimal. The Nut is already buried so it could also get a bit of material. In the end it takes very little screw tension to keep it in place. If there are any issues I can add a small amount (and still be printable without support).
makita being second best
What does the change in cutting area look like with the makita as compared to the dw660?
And is there a 1/8th inch collet you would recommend for that router like the one you sell for the dw611?
Posted this the other day. Works great for minimizing waste I whatever length stock you have. Tubing Cut Length Optimization Calculator - optiCutter
I understand. I almost got the makita, but I already had a 611 on the lowrider, and because redundancy, lol.
The teeny tiny is almost certainly going to get a primo rebuild, so if I haven’t gotten into the pid by then, maybe I’ll spring for a spindle. I still don’t have too many routers, although the wife might say I have enough
Finished printing the core after 16 hours. 0.6 nozzle @ 0.3mm layers with the 70/30/70 infill. Hot glued the base just out of paranoia of bad bed adhesion.
Hey Xeno, nice to see your build. What caught my eye were your x/y tubes sticking further out than on Ryan’s build, so it seems to me that not every mm counts there? It could be a few mm longer, right?
I always wonder what people who can’t express what they think so precisely would do in such a situation … LOL ROTFLMAO
(I won’t quote my wife’s usual remarks here
In the previous versions, my RT 0700 is held by a more embracing holder which works very well too. But more screws to release for a tool change or MPCNC generation upgrade.
(to be found on thingaverse)
Or outdoors printing? ;^/ Looks a bit like a sail in a gentle breeze.
I was just assembling mine today and got the same thing. About 1/4" sticking out on each side of every tube. I followed the calculator dimensions exactly.
Nice build BTW!
I miscalculated the positions of the legs on the aluminum extrusion. I don’t mind the stick out. Maybe one day I’ll cut them down a bit
Good to know, thanks. I have to cut them with a hacksaw.
Makita has been added to the calc, zero offset on any axis, but it does stick out 8mm or so further from the gantry than the 660.
I should have them the beginning of next week if not a bit sooner.
Longer is no big deal, on any axis.
That isn’t good. 1/2" off one every tube? Did you use the metric or Imperial calc?
seem to be limited how deep I can go by this. Is this installed correctly?
Turn the base 90 degrees. I should have a note on the tool mount page. Take off the 4 screws and position the lock button on the same face as the dewalt logo. Don’t pull it all apart though just take out the 4 screws and rotate it and put them back.
This turned out too pretty not to post.
The 660 is still the best option with the good import spindle and the makita being second best. After that I do not really recommend anything else.
How is run-out on the dadelus bl spindle you linked? I have the super cheap DC spindle now and the low noise is pretty important for not pissing off the family. Yup, worth 3x price if it means I can run it when I have time (at night usually).
I just realized what I did. I transposed a couple measurements. At least I cut my tubes right. ![]()
Newbie here. I’m still waiting for the full kits (I wanna buy parts and printed parts from store)… Hopefully, soon?? But in the meantime, should I purchase anything alongside the tubing and router?
