I just updated my MPCNC Burley from the mini rambo board to the Jackpot from V1. I configured Estlcam from the V1 site and copied and pasted the start ,end and tool change routines. I recreated a simple image on estlcam(one that i had carved before with the old board). When I go to run the gcode I get this message. One time it performed the probe ofset and the stoped but usually it just does nothing?
Oh I think 3.7.17 might be one of the ones that, unfortunately, has issues.
FluidNC Firmware - The Current tested and confimed FluidNC version is 3.9.1 , use anything newer than this with caution. 11/1/2024- Configs updated as well, good idea to update them as well. Be sure to test homing after updates as some of the numbers have changed, also take note of your pull off values to keep things level and square after an update.
If the ESP32 is mounted to a Jackpot, then ensure Jackpot’s main 24V power supply is powered OFF before connecting a USB cable between the ESP32 and computer. The ESP32 can be updated while mounted, or removed from the Jackpot board.
If/when removing the ESP32 from Jackpot for flashing, be careful to not bend, or apply force to the ESP32’s integrated antenna.
