New Jackpot controller and very old iPad
Hi all,
Working on my LR3-LR4 conversion and I’m having trouble connecting to the Jackpot via an old iPad Mini. I can see the SSID and connect to it. If I go to Safari and type in 192.168.0.1, I get the ESP3D tool page. If I reset and connect via my PC, I see the correct UI. My iPhone display mostly correct UI but I get a server error. I’m not worried about that one as that won’t be a normal use case. Once I’ve tried to connect with my iPad, I’ll get the tool page on all devices. A reset is require to make it work on the PC again. I’m guessing there’s something that the UI requires that’s not in the old iPad. Any ideas what that might be?
Thanks,
Steve
How old is your ipad and what browser and browser version is on it?? Can you update either, you should? Use a different browser? The answer is yes at some point there is a cutoff but I am not really sure how old it can be. Sounds like you might be there but it would be great to find out.
Did you get the JP3 from v1e.com or elecrow?
Hi Ryan,
Super job on the LW4! I did get the JP3 from you. The iPad is an iPad Mini running 9.3.5. It can no longer be updated. I can’t complain we were given iPads at the Apple Christmas party when the mini came out. I was just hoping that it might be a setting.
Thanks,
Steve
That is pretty old, bummer though we need such min specs to view a simple page.
I had the same issues with old iPads, it just is what it is unfortunately.
Thanks Guys. I just thought it might be a way to recycle an old piece of equipment. I have lots of other choices.
