My problem/issue right now is building the table to put my MPCNC. (well other issue is spindle, but will post in separate section).
I have completed the print of all the parts, assembled all the bearings/bolts and put it all together. (see attached).
I have the 25mm (OD) tubing (from bunnings) (see attached) and all the feet/corner/etc fit.
I have cut the Z length (not shown) and legs (see attached) using a 3D printed dremel cutting attachment. This actually worked great each leg come out 138mm exactly.
My problem right now is I am trying to build the underneath of the table and I cant seem to get my 2x4 (well 45mm x 90mm) lengths square, so I can drill/put in the 125mm wood screws to join them in a quick/dirty but joint. I think plan to screw down a pre-cut sheet of MDF (16mm) as the first layer of my table.
Any suggestions on how to keep them square as I drill/screw?
-Fermata
