Working on MPCNC C-23.5m - and when I put the c-rollers onto the 3/4 conduit they go on relatively easy but when you try to move by hand they are hard to move and feel a bit choppy. Not sure how else to describe it.
I am using the correct hardware - 5/16 bolts with 608 bearings.
These are the bearing I am using off of amazon - https://www.amazon.com/gp/product/B073ST742Z
Perhaps I have the bolts too tight. If I loosen it gets better and if that is the issue — what is the ideal resistance or how tight should the bolts be?
Thx.
