I have completed my build, and am now at the point of testing out the electronics / steppers. I am just attempting to get the machine moving and will eventually use it as a CNC router, and do not currently have plans to use it as a 3D printer.
All the stepper motors are wired up correctly as far as I can tell. When i open up Repetier-host, and attempt to use the manual controls from the “Print Panel”, I am able to successfully send the X, Y and Z to “home” by pressing the home button for each axis. However, when i attempt the to do incremental steps (0.1, 1, 10, 100) nothing happens and I get this error in the console log:
< 12:32:19 PM: Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Here is my log when Repetier-host initially connects. NOTE at the end there is a temperature error here as well:
12:43:13 PM: Attempting to connect to printer
12:43:13 PM: Connection opened
< 12:43:22 PM: start
> 12:43:22 PM: N1 M110 *2
< 12:43:22 PM: echo:Marlin1.0.2
> 12:43:22 PM: N2 M115 *4
< 12:43:22 PM: echo: Last Updated: Jan 20 2016 9_06_1511:47:29 | Author: PID, ALLTED
< 12:43:22 PM: Compiled: Jan 20 2016
> 12:43:22 PM: N4 M111 S6 *67
< 12:43:22 PM: echo: Free Memory: 5441 PlannerBufferBytes: 1232
> 12:43:22 PM: N5 M111 S14 *113
< 12:43:22 PM: echo:Hardcoded Default Settings Loaded
< 12:43:22 PM: echo:Steps per unit:
< 12:43:22 PM: echo: M92 X200.00 Y200.00 Z4535.44 E200.00
< 12:43:22 PM: echo:Maximum feedrates (mm/s):
< 12:43:22 PM: echo: M203 X9000.00 Y9000.00 Z3.00 E25.00
< 12:43:22 PM: echo:Maximum Acceleration (mm/s2):
< 12:43:22 PM: echo: M201 X700 Y700 Z100 E800
< 12:43:22 PM: echo:Acceleration: S=acceleration, T=retract acceleration
< 12:43:22 PM: echo: M204 S700.00 T800.00
< 12:43:22 PM: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< 12:43:22 PM: echo: M205 S0.00 T0.00 B20000 X4.00 Z0.40 E5.00
< 12:43:22 PM: echo:Home offset (mm):
< 12:43:22 PM: echo: M206 X0.00 Y0.00 Z0.00
< 12:43:22 PM: echo:PID settings:
< 12:43:22 PM: echo: M301 P12.03 I0.60 D60.60
< 12:43:22 PM: echo:Filament settings: Disabled
< 12:43:22 PM: echo:Z-Probe Offset (mm):
< 12:43:22 PM: echo: M851 Z0.00
< 12:43:22 PM: Error:0
< 12:43:22 PM: : Extruder switched off. MAXTEMP triggered !
< 12:43:22 PM: Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
< 12:43:23 PM: FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:MPCNC EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
I have tried the same thing in Pronterface and Simplify3D, and all give me the same errors. I have also tried on windows and mac with same result, so i assume it is a configuration i am unaware of, but i am not sure if it is a Marlin firmware config, or a setting in Repetier-host or something else. I am also not sure if I was supposed to hook up the resistor on the RAMPS board that came in the kit, even though i am not intending to do 3D printing?
I purchased the hardware/electronics kit from this site, and printed my own parts. The kit was purchased about 2 weeks ago.
Any assistance is greatly appreciated! This is my first CNC build, and am new to the software and firmware.
