I’d recommend adding the resistor to the Jackpot itself. Then you don’t have to worry about it if you later change the ESP32.
Also, if your current ESP32 is the same one that came with the Jackpot, you shouldn’t need it. I didn’t run into this issue until I changed my ESP32.
