Millmage Spetool .tools library
For everyone who is using Spetool bits, Claude converted the CSV’s for me so they are easy to use in Millmage:
can you share the source data you used for this?
I have 3 SpeTool bits and 2 of the 3 I have look to be defined incorrectly.
For example, W01003 is:
TOOL SPECS: Solid carbide, up-cut spiral with 3.2 degrees, 0.75mm tip radius, 1/8" shank, 15mm cutting length, and 1-1/2" overall length.
But the included .tools file has it defined incorrectly
Changing a few numbers based on the site description makes it look like this:
Hi @Michael_Melancon ,
I used the CSV’s for Carbide3D from the Spetool website: CNC Tool File Database for Downloadable Tool Files | SpeTool
I’ll check if or why this wasn’t converted right.
Ok, @Michael_Melancon new version now committed. Could you check?
There are also some notes in the readme file.
