Tried modifying the firmware with your edits and it will not compile now. Not sure how to apply the .patch and google is getting me nowhere. Ideas on what I may be doing wrong?
getting Arduino: 1.6.7 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
In file included from sketch\Marlin.h:21:0,
from sketch\Marlin_main.cpp:30:
sketch\Marlin_main.cpp: In function ‘void process_commands()’:
fastio.h:45: error: ‘DIOX2_ENABLE_PIN_RPORT’ was not declared in this scope
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
sketch\fastio.h:68:23: note: in expansion of macro ‘_WRITE’
#define WRITE(IO, v) _WRITE(IO, v)
sketch\Marlin.h:117:61: note: in expansion of macro ‘WRITE’
#define enable_x() { WRITE(X_ENABLE_PIN, X_ENABLE_ON); WRITE(X2_ENABLE_PIN, X_ENABLE_ON); }
sketch\Marlin_main.cpp:1939:9: note: in expansion of macro ‘enable_x’
enable_x();
fastio.h:34: error: ‘DIOX2_ENABLE_PIN_WPORT’ was not declared in this scope
{DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); }\
sketch\fastio.h:45:80: note: in expansion of macro ‘_WRITE_C’
enable_x();
fastio.h:34: error: ‘DIOX2_ENABLE_PIN_PIN’ was not declared in this scope
sketch\fastio.h:17:26: note: in definition of macro ‘MASK’
#define MASK(PIN) (1 << PIN)
enable_x();
fastio.h:39: error: ‘DIOX2_ENABLE_PIN_WPORT’ was not declared in this scope
{DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }\
enable_x();
fastio.h:39: error: ‘DIOX2_ENABLE_PIN_PIN’ was not declared in this scope
enable_x();
fastio.h:30: error: ‘DIOX2_ENABLE_PIN_WPORT’ was not declared in this scope
#define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch\fastio.h:45:105: note: in expansion of macro ‘_WRITE_NC’
enable_x();
fastio.h:30: error: ‘DIOX2_ENABLE_PIN_PIN’ was not declared in this scope
enable_x();
enable_x();
enable_x();
fastio.h:45: error: ‘DIOY2_ENABLE_PIN_RPORT’ was not declared in this scope
sketch\Marlin.h:130:61: note: in expansion of macro ‘WRITE’
#define enable_y() { WRITE(Y_ENABLE_PIN, Y_ENABLE_ON); WRITE(Y2_ENABLE_PIN, Y_ENABLE_ON); }
sketch\Marlin_main.cpp:1940:9: note: in expansion of macro ‘enable_y’
enable_y();
fastio.h:34: error: ‘DIOY2_ENABLE_PIN_WPORT’ was not declared in this scope
enable_y();
fastio.h:34: error: ‘DIOY2_ENABLE_PIN_PIN’ was not declared in this scope
enable_y();
fastio.h:39: error: ‘DIOY2_ENABLE_PIN_WPORT’ was not declared in this scope
enable_y();
fastio.h:39: error: ‘DIOY2_ENABLE_PIN_PIN’ was not declared in this scope
enable_y();
fastio.h:30: error: ‘DIOY2_ENABLE_PIN_WPORT’ was not declared in this scope
enable_y();
fastio.h:30: error: ‘DIOY2_ENABLE_PIN_PIN’ was not declared in this scope
enable_y();
enable_y();
enable_y();
sketch\Marlin.h:118:61: note: in expansion of macro ‘WRITE’
#define disable_x() { WRITE(X_ENABLE_PIN,!X_ENABLE_ON); WRITE(X2_ENABLE_PIN, !X_ENABLE_ON); axis_known_position[Y_AXIS] = false; }
sketch\Marlin_main.cpp:2697:30: note: in expansion of macro ‘disable_x’
if(code_seen('X')) disable_x();
sketch\Marlin.h:131:61: note: in expansion of macro ‘WRITE’
#define disable_y() { WRITE(Y_ENABLE_PIN,!Y_ENABLE_ON); WRITE(Y2_ENABLE_PIN, !Y_ENABLE_ON); axis_known_position[Y_AXIS] = false; }
sketch\Marlin_main.cpp:2698:30: note: in expansion of macro ‘disable_y’
if(code_seen('Y')) disable_y();
sketch\Marlin_main.cpp: In function ‘void manage_inactivity(bool)’:
sketch\Marlin_main.cpp:4359:9: note: in expansion of macro ‘disable_x’
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
sketch\Marlin_main.cpp:4360:9: note: in expansion of macro ‘disable_y’
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
sketch\Marlin_main.cpp: In function ‘void kill()’:
sketch\Marlin_main.cpp:4464:3: note: in expansion of macro ‘disable_x’
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
disable_x();
sketch\Marlin_main.cpp:4465:3: note: in expansion of macro ‘disable_y’
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
disable_y();
exit status 1
This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.
