Hello all,
I use aspire 10.512 i have a marlin machine
i did install the marlin pp from this forum
strange thing is my machine dont start
the gcode produced :
; grof 3
; Safe Z height: 5.000
; Tools: 1 = Vlakke frees (3 mm)
; Notes:
; Generated Sunday April 07 2024 08:35 PM
G90
M84 S0
M03 S16000
G21
G00 X0.000 Y0.000 Z0.000
G1 Z5.000
G1 X0.000 Y0.000 F889.0
; Tool 1: Vlakke frees (3 mm)
; Path: grof 3 G:\edwin\test\grof 3.gcode
G0 X-21.393 F2000 Y-58.644 F2000 Z5.000 F500
G1 Z-13.000 F254.0
G1 X-21.597 Y-58.524 F889.0
G1 X-22.037 Y-58.198
G1 X-22.410 Y-57.845
G1 X-22.795 Y-57.371
G1 X-22.938 Y-57.136
G1 X-23.055 Y-56.886
G1 X-23.144 Y-56.626
G1 X-23.221 Y-56.272
G1 X-23.255 Y-55.911
G1 X-23.259 Y-55.306
G1 X-23.244 Y-54.912
G1 X-23.170 Y-54.415
G1 X-23.073 Y-54.112
G1 X-22.935 Y-53.826
G1 X-22.709 Y-53.484
G1 X-22.364 Y-53.084
G1 X-21.951 Y-52.722
G1 X-21.731 Y-52.570
G1 X-22.557 Y-51.699
G1 X-22.956 Y-52.013
G1 X-23.341 Y-52.450
G1 X-23.869 Y-53.122
G1 X-24.231 Y-53.988
G1 X-24.331 Y-54.295
G1 X-24.403 Y-54.608
G1 X-24.477 Y-55.156
G1 X-24.468 Y-56.387
G1 X-24.419 Y-56.668
G1 X-24.342 Y-56.945
G1 X-24.216 Y-57.280
G1 X-23.999 Y-57.752
G1 X-23.829 Y-58.076
G1 X-23.700 Y-58.284
G1 X-23.551 Y-58.483
G1 X-23.304 Y-58.767
G1 X-22.792 Y-59.278
G1 X-22.474 Y-59.071
G1 X-22.263 Y-58.980
G1 X-22.041 Y-58.916
G1 X-21.812 Y-58.881
G1 X-21.583 Y-58.875
G1 X-21.393 Y-58.644
G0 F2000 F2000 Z5.000 F500
G0 X-16.213 F2000 Y-57.518 F2000 F500
G1 Z-13.000 F254.0
G1 X-15.990 Y-57.677 F889.0
G1 X-15.792 Y-57.866
G1 X-15.730 Y-57.937
G1 X-15.431 Y-57.429
G1 X-16.213 Y-57.518
G0 X-21.393 F2000 Y-58.644 F2000 F500
G1 Z-14.000 F254.0
G1 5.000 ;goto safe z
the postprocessor:
+ G Code - Vectric machine output configuration file
+ History
+ Who When What
+ MikeK 13/12/2015 Written
+ JohnP 02/03/2017 Added multi-tool with pause
POST_NAME = "Marlin (mm) (*.gcode)"
FILE_EXTENSION = "gcode"
UNITS = "MM"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"; [TP_FILENAME]"
"; Safe Z height: [SAFEZ]"
"; Tools: [TOOLS_USED]"
"; Notes: [FILE_NOTES]"
"; Generated [DATE] [TIME]"
"G90"
"M84 S0"
"M03 [S]"
"G21"
"G00 X0.000 Y0.000 Z0.000"
"G1 Z[SAFEZ]"
"G1 [XH] [YH] [F]"
"; Tool [T]: [TOOLNAME]"
"; Path: [TOOLPATH_NAME] [PATHNAME]"
"; [TOOLPATH_NOTES]"
+ Commands output for rapid moves
begin RAPID_MOVE
"G0 [X] F2000 [Y] F2000 [Z] F500"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"G1 [X] [Y] [Z] [F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"G1 [X] [Y] [Z]"
+ Commands output for tool changes
begin TOOLCHANGE
"; Tool change:"
"M05"
"M25"
+ Commands output for toolpath changes
begin NEW_SEGMENT
"M03 [S]"
+ Commands output at the end of the file
begin FOOTER
"G1 [SAFEZ] ;goto safe z"
annyone anny idea?
thx in advance
