I made all configuration in configuration.h and configuration_adv.h (see attached) and Compilation send me these errors. I dont understand and I spend a long time on this issue. Can you help me ?
The 2.0 firmware is still very much in flux. It’s not a beta test or anything. It’s in development and frequently broken. Even if you got it to compile, there might be major flaws with the code. I think you should wait until it becomes more stable. At some point, it will get merged into 2.0 or the dual endstops should get merged into 1.1.x. When that happens, Ryan will have a preconfigured, building version here with some instructions (hopefully).
I’m sorry you’re having a difficult time. This firmware should get you going until that becomes at least testable:
If you really want to try it I have a 1.1 version linked and it has been merged into the new 1.1 bugfix branch. 2.0 only works sometimes with platform.io right now. It is under too heavy of development to bother with at the moment.
I have my instructions almost finished I need to add a lot of pictures yet, but when I do I will have an updated firmware if you could wait a day or two.
I just apply my parameters to “Marlin-MPCNC_T8_16T_Ramps_LCD_32step_DualEndstop” branch.
When I compile I’ve an error : “avr-gcc: error: CreateProcess: No such file or directory”” u8glib is included to my project, all seems OK and I’m a newbie ? …
Marlin 2.0 is still a bit wonky with the current arduino IDE. Try moving your firmware folder to the root of a separate drive, even a flash drive if you have to. it is something to do with how long the file tree is on the temp compiler folder. If not try the arduino beta. I checked the exact file just before closing up last night ( when I just updated it) it works fine for me but I am not sure if any arduino tweaks are leftover in my build.
@Jeffeb3 : I’m using the Arduino 1.8.5 (Windows Store 1.8.10.0) (dont’t know why there is not the same release number)
@Ryan : I try to move “marlin” path to the root of “d:” and I obtain the next error message :
Archiving built core (caching) in: C:\Users\Yann\AppData\Local\Temp\arduino_cache_656766\core\core_arduino_avr_mega_cpu_atmega2560_a94ab6aaf61dfb93b4a8079c694a14c2.a
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Mega or Mega 2560
