OK, so I have found some posts/threads to start working on getting the laser up and working properly.
Laser Specs:
And plugged into the SKR Pro V1.2
I have found that Ronald had the same issue with light burn so thankful for his thread and experience.
So, I set up my device as a Marlin, shown below. I exported the gcode after following the comments from the above thread. Commands are “Inline” and I made the S factor 1000 and Fast Whitespace Scan to 1600mm/min. Gcode script to include M3 I at the start.
I drew a simple square to cut out with the below settings. I saved the Gcode as per below and plug the SD card into the TFT for printing.
Trial.gcode (322 Bytes)
; LightBurn 1.6.00
; Marlin device profile, current position
; Bounds: X0 Y0 to X19 Y19
;USER START SCRIPT
M3 I
;USER START SCRIPT
G21
G91
; Cut @ 150 mm/min, 80% power
M8
M05
G0 X19 Y0 F1600
; Layer C00
G1 X-19F150 I S800
G1 Y19 I S800
G1 X19 I S800
G1 Y-19 I S800
M9
M05 P1
; return to starting pos
G0 X-19 Y0 F1600
Result
It did not cut through all the way. So I will try with 2 passes
Trial_2_passes.gcode (418 Bytes)
In the end I did 8 passes to almost cut through.
Next, I slowed the speed to 110mm and up the power to 85%. @ 2 Passes
Results: Instantly better, only 2 passes!!
Thats about all I can do for the day. Will definitely be doing some more exercises tomorrow now that I have been able to cut through.
Heading into watch the NRL, Broncs vs Sharks, should be a bit of a match as Origin was on Wednesday and some of the main stars are out.
