M4 Screw Hole Diameter
Hello!
I have problems getting the M4 screws through the holes in the parts. Right now I want to assemble the base (feet), but there is just no way I can get the screw tightened up through both parts (Bottom_Corner and Lock_Corner) with some glue in between in a timely manner. The screws are basically acting as thread cutters with a lot of resistance. I tried measuring the hole diameter in Meshmixer and I get exactly 4mm. I don’t think this is possible with M4 screws. So do I have to order different screws? It seems that getting the imperial sizes is quite complicated in Europe.
Thanks a lot in advance for your help!
Kind regards from Germany,
Jonas
Thread them through a few times, drill them out a bit, skip the glue, all options that will work.
Thank you for your quick response! I was hesitant about drilling because I thought I would lack the needed precision. I used a 4mm wood drill and now everything fits and is glued and screwed together. Nice!
Thank you!
It’s not too unusual to see that if the printer is oozing a bit, it’ll print the holes just a smidgen too small.
