I don’t know if they fit in the roller f’s or in some pockets. If I go to the hardware store that carries the metric stuff I can take a look, but I went off another users translation of the list and I have not heard any complaints. But when you take a look at it a #6-32 is really close to an M3.5 not an M4.I would say if the m4 lock nut fits in the roller f you will be fine.
I used M4 screws and nuts. They fit in most places without issue, but I had to do a little filing on a small few slots. I just gave each hole a run through with a 4mm drill bits for the screws. Standard M4 (not nyloc) may fit ok in the slots where the nyloc nuts were too thick to fit.
Thank you both, Ive got some m4 nylocs to try, if they fit I’ll order some more and drill the holes for 4mm.
I was sourcing my conduit the other day and realised that the place where I get my conduit for basically no cost, stocks all its conduit in imperial sizes and I have printed the IE. My question is whether 1" conduit will work in an international machine, on paper it’s .4mm between them.
Another question I have is what is the preferred material for conduit? I can get either aluminium or steel, but I am leaning towards the steel as my instinct says its more “linear”.
