LR4 with JackPot 1 Auto launching the WebUI
On a coupe notebooks when I switch wifi to FluidNC they automatically go through a routine I have not caught as it flashes something like “MFST…” ? not sure the I get Captive Portal and WebUI opens on my browser. Pretty automatic.
On my desktop, which is 30 feet away, I easily have to start to type in the browser 192.168… then it auto shows the V1 logo and the full string and I just easily hit enter and the WebUI opens.
Just curious. What this automatic mode is versus manual entry? Is there was to control it?
Thanks.
Os and Browser for each?
On a desktop, the captive pop-up should have a link that you can click. It is pretty easy.
On a mobile, that popup link doesn’t work for, and you usually have to tell it not to fall back to real internet. Then manually open a new real link (I use a bookmark on the screen after I “use network as is”)
I don’t understand why, I have been told a bunch of times, but it never sticks.
The other way that it can be different is if the only automatic network is fluidnc then things can be a little easier, but can also cause problems if it keeps trying to auto-connect and crashes the esp32. For the most stable experience never auto-connect.
Microsoft Windows 11 and Microsoft Edge browser.
Thanks. I connect okay usually but just was curious.
Okay figured this out with help for @Terry_O_Sullivan
I previously stupidly switched my wifi SSID to FluidNC and then opened MM.
Instead I tried opening MM then change to FluidNC and it work perfect!! :+1:
I assume by switching to FluidNC they were fight against WebUI.
